How to **REPAINT** bike DIY?
hall3_x
PostPosted: 22:43 - 13 Oct 2003    Post subject: How to **REPAINT** bike DIY? Reply with quote
Any experienced bikers here who did that for his own bike and would like to share some experience?
I'm thinking to do one for my own bike, but i dont know what kind of spray paint i should buy. Any suggestion would be welcome.
I know spray painting technique, juz that i didnt spray a vehicle before. I think i'll need a thing that can remove the old paint(or worned out painting), some kind of paint for the base, and color paint on the upper layer, and finally the outer most is the shining/colourless paint. Am i right?
Thanks.
You tame a dog with food.....
???You tame a man with money.....
??????But there's nothing you can tame a BUMORI~!
PostPosted: 23:44 - 13 Oct 2003    Post subject: Reply with quote
Blimey,
Are you looking for torture or what?
You'll have to get a compressor and some professional liquid paint, because I don't think that spray cans can provide the consistency needed to respray an entire bike and have it look good. You'll need to rub down the entire bike and put undercoat on it, you'll need to strip all of the paint if the bike is a dark colour already...
Other than that ask Dusty, he resprayed his TZR 125 (although he had a brand new fairing - and he sprayed it black which has better consistency of tone) Confused Its a big job.
ilovens125f's
PostPosted: 00:21 - 14 Oct 2003    Post subject: Reply with quote
Hi i don't agree with the guy above
spray cans will do fine you have to
heat up the garage and keep it at
about 25c and spary in light coats
(don't just press and hope for good
results Sad ) build them up slowly and
eventally it will look as good as new!!!
Once you started to spray one coat
finsh it don't stop in the middle of spraying!
spray about 8 inches away.Also make
sure the place you are spraying in is
as dust free as possable
Hope this helps
Kev
Kev the Ns125F lover!!
!!!Dont ignore me!!!
one1895
I liked BCF so much I made my own copy
PostPosted: 00:26 - 14 Oct 2003    Post subject: Reply with quote
Best regards,
Eric
But there's no way you can tame a MUBORI~!
Is it me or did you change your signature back? Confused
Hull & Yorkshire Bikers - Sheffield & Yorkshire Bikers - Manchester Bikers - Nottingham Bikers
kev
I Hump Things
PostPosted: 08:22 - 14 Oct 2003    Post subject: Reply with quote
The spraying is the easy bit, its the rubbing down which take the time.
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
hall3_x
PostPosted: 08:42 - 14 Oct 2003    Post subject: Reply with quote
MarJay wrote:
Blimey,
hm......i've all the things required, as i can get a car workshop here(one of my relative owns it) and they do have compressor and stuff that allow me to remove and respray.
All i need to know is what are the paint that's recomended?
results ) build them up slowly and
Hope this helps
Kev
Well, hate to say this, but the one you're mentioning is about normal spraying technique. I knew all those as i mentioned.
But still thanks for your kindness for replying here.
one1895 wrote:
Best regards,
Eric
Well, i've no idea why i keep losing my signature....maybe the MOD/ADMIN of the forum can tell me why...
hall3_x
PostPosted: 08:43 - 14 Oct 2003    Post subject: Reply with quote
Kev,
yea, totally agree with ya, that's why i said i need a kind of spinning plate machine that can rub off paint.
Thanks for you guys' concerned~
Hex
Party Boy
PostPosted: 09:26 - 14 Oct 2003    Post subject: Reply with quote
If you have access to a paint shop, ask your relative on the best way to use the equipment.
As for what paint to use, I would just get some automotive paint that your relative uses in his paint shop.
They will probably get it cheeper than you could, and it should produce a good finish if done correctly.
Because it breaks the signature rules, your sig can only be 3 lines long.
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
hall3_x
PostPosted: 22:30 - 14 Oct 2003    Post subject: Reply with quote
Hex>
thanks for all the info....
BTW, can you tell me how you put a logo on yr signature?
i would like to ahve one on mine too, can you help me hosting it?
It'll be a very little GIF file with is about 300kb.
Thanks in advance~!
G1_
PostPosted: 22:48 - 14 Oct 2003    Post subject: Reply with quote
As a general rule of thumb, you can't have a picture in you signature. However if it is very small and your on the good side of korn he may let it slip.
btw isn't 300kb huge for a gif file Confused
Hex
Party Boy
PostPosted: 09:02 - 15 Oct 2003    Post subject: Reply with quote
Yeah mines like 2k odd and I think thats part of the reason korn allows it - that and the fact he loves me Wink - oh and it still keeps my signature to the 3 lines long rule. Wink
To be honest you'll probably find it ends up been removed.
hall3_x
PostPosted: 12:55 - 15 Oct 2003    Post subject: Reply with quote
what will be removed?
Hex
Party Boy
PostPosted: 13:03 - 15 Oct 2003    Post subject: Reply with quote
A picture in your signature if you put one in.
cagiva gezzer
PostPosted: 17:26 - 15 Oct 2003    Post subject: Reply with quote
Are you on about you frame or fairing?
Have you thought about powder coating the frame?
My local place blasted and coated a pair of wheels for £40.
Valentino Mossy
PostPosted: 21:43 - 15 Oct 2003    Post subject: Reply with quote
done my bike up,complete rebuild,repaired the cracked fairings, £90 quid for the paint for the compresser flippy/candy deep red colour ,pucca job, really tidy better then the tired old look,brought it up the garden,up a few steep steps,then it slipped !......
Three people on the bike and it f**king slipped !
one week later....
Repaired the CRACKED fairings,took it for a spin,and dropped it !
New clutch handle,new indicator,more touch up on the paint,+ new oil because it pissed its self over the road !
MUPPET !
the moral of this story...... leave the bike alone !..Its going to cost you more money !
hall3_x
PostPosted: 21:52 - 15 Oct 2003    Post subject: Reply with quote
You see....that's why i wanna save the money up for a DIY thingly...
Mr. Green Mr. Green Mr. Green
hall3_x
PostPosted: 21:56 - 15 Oct 2003    Post subject: Reply with quote
Thanks for reminding, but i'm going to touch up in the fairing only...
The last post was made 22 years, 310 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 99.6 Kb
