| alex_t |
 alex_t Nitrous Nuisance
 Posted: 20:49 - 30 Apr 2006 Post subject: derestricting XT125 X |
just brought an '06 XT125 X which is still running in but seems to top at 47mph :S has done just under 600miles but still wondering y so slow.... anyone got instructionsa on takign the restrictor off the carb and exaust and recommendations for smaller sprocket as no haynes manual out yet so dont ahve a clue  |
| Brava210 |
 Brava210 Crazy Courier
 Posted: 21:06 - 30 Apr 2006 Post subject: |
probably as fast as it will go  ____________________ Honda Novio, Puch Grand Prix, Suzuki AP50, CZ 125, Wassell 125, Montesa 348,Honda 125TDC, Suzuki 100ER, Suzuki GSF650 Bandit, Aprillia Pegaso, Honda PCX125, Honda Forza300, BMW G310 GS, Suzuki SFV650, Honda CB500X
CHARLEY SAYS " ALWAYS TELL YOUR MUMMY BEFORE YOU GO OFF SOMEWHERE" |
| edd |
 edd Nearly there...
 Posted: 22:08 - 30 Apr 2006 Post subject: |
Im absolutely sure it should do more than 47 mph.
Do you know that the carb is definitely a point of restriction? im not sure but id imagine they would restrict the carb with a washer type restrictor that you would have to remove the carb to get to. As for the exhaust id guess you'll have a cone restrictor at the manifold end of the pipe. These are usually held in place with 2 spot welds just drill these out and the cone should just drop out. take your pipe off and have a look.
good luck  ____________________ Bluespark Automotive - Diesel Tuning for Performance and Economy |
| The Tot |
 The Tot World Chat Champion
| alex_t |
 Posted: 09:44 - 01 May 2006 Post subject: |
probably still needs a little more running in, not to worry who chaning the size of the sprocket help u think get a little more out of it? |
There is a gap of 1 year, 53 days between these two posts... |
| 108dave |
 108dave L Plate Warrior
| Resurrection |
 Resurrection Ballast Boy
| Finglonga |
 Finglonga World Chat Champion
| Faraz |
 Faraz Nearly there...
| nasht98 |
 nasht98 L Plate Warrior
| mistman |
 mistman Nova Slayer
| smithy1219 |
 smithy1219 Two Stroke Sniffer
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 08:25 - 12 Apr 2008 Post subject: |
There is a gap of 1 year, 273 days between these two posts... |
| misterdave |
 misterdave Renault 5 Driver
| hmmmnz |
 Posted: 23:21 - 10 Jan 2010 Post subject: |
i said it before....
this post is years old
they are no know factory restrictor kit,
the bike is designed to get to 60 and thats about it,
a few things may help, change the carb to one larger,
change out the exhaust to something free'r flowing,
advance the timing by a couple of degree's
you could get more if you were willing to do a cam grind
port the inlet and exhausts, increase the compression or fit a bigger bore
there are also different cdi's avalable
https://www.procycle.us/bikepages/ttr125.html
all the stuff is available for the ttr125 which shares the same bore and stroke,
you can get a 150cc kit complete with cams for not alot of money, couple that to a decent carb probably around a 26-28mm carb
and a new exhaust and you should be away laughing,
people report a 40% increase in power, not that its much 8 hp to 13 better than zip though ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| misterdave |
 Posted: 11:15 - 29 Jan 2010 Post subject: |
Thanks for the reply this may seem like a silly question (excuse me if it is) but would the majority of the parts on the procycle website
( https://www.procycle.us/bikepages/ttr125.html#exhaust ) fit the xt125x?
and how hard / easy is it to fit the BBR big bore kit, I am a complete novice but have a friend who has a bit of experience in motor repairs and such, also my little brother is a semi trained mechanic
[gosh weird looking to my little brother for help, how times have changed ] ____________________ Squires. Yamaha XT125X - sold. Yamaha DT125R ['97] |
| plazydays |
 plazydays L Plate Warrior
 Posted: 21:39 - 01 May 2010 Post subject: Derestrict Yamaha XT125 |
I know this is an old post but I thought I would add my 2pence worth for others to see.
The exhaust has a Cat at the bottom. Take off the exhaust, grind the Cat over and remove the inserts. Weld it back up and you'll end up with an increase in performance and even better, use less fuel.
The Cat only works well when really hot but is still restricting the flow of gases from the exhaust. Easy fix and will not cost the earth. you could then follow up with an after market rear can. This will also inprove the BHP of the bike and give it a more throaty sound. Stick to the road legal versions though as any increase from the standard 12BHP on L Plates, if proven could invalidate the insurance. ____________________ Previous Bikes: We all start somewhere: Fz50, FS1e, RS100, TS100, MTX125, XT250, XS250,CB250, GT250, GT380, Z250, Z400, GS550, KLR650, KLE500, GP100, GSX250, GS500, GSX600f, XL1000, Zr750, RF900, |
| P. |
 P. Red Rocket
| TUG |
 TUG World Chat Champion
| plazydays |
 Posted: 09:38 - 02 May 2010 Post subject: |
| TUG wrote: | Its not restricted. ITS A 4 STROKE!!!! ITS A 125!!! BUY A BIGGER BIKE! |
Beg to differ!!!!!!!! Its not restricted in the sense that it was designed with a larger BHP and then reduced. The four stroke on an XT was built with 12BHP in mind. Any vehicle with a CAT Converter on is restricted as it does not allow the engine to breath as well as it could. Although on a car, if you removed it, when it came to an MOT, the gases would would higher and you would face a failure, Bikes are not yet tested for emissions as far as I know so it would increase the BHP with any repercussions. Hence my post. I should know as I have currently just done one myself for a lad. ____________________ Previous Bikes: We all start somewhere: Fz50, FS1e, RS100, TS100, MTX125, XT250, XS250,CB250, GT250, GT380, Z250, Z400, GS550, KLR650, KLE500, GP100, GSX250, GS500, GSX600f, XL1000, Zr750, RF900, |
| P. |
 P. Red Rocket
| Kickstart |
 Kickstart The Oracle
| Paxovasa |
 Paxovasa World Chat Champion
| P. |
 P. Red Rocket
| plazydays |
 Posted: 17:26 - 02 May 2010 Post subject: No Argument |
As a trained mechanic since 1989 and working on them ever since, try this web site which backs up what I have already said:
https://en.wikipedia.org/wiki/Catalytic_converter.
Read the section about negatives which as well as the rest and you will clearly see that the Cat restricts. ____________________ Previous Bikes: We all start somewhere: Fz50, FS1e, RS100, TS100, MTX125, XT250, XS250,CB250, GT250, GT380, Z250, Z400, GS550, KLR650, KLE500, GP100, GSX250, GS500, GSX600f, XL1000, Zr750, RF900, |
The last post was made 15 years, 267 days ago. Instead of replying here, would creating a new thread be more useful? |
