derestricting XT125 X
alex_t
PostPosted: 20:49 - 30 Apr 2006    Post subject: derestricting XT125 X Reply with quote
just brought an '06 XT125 X which is still running in but seems to top at 47mph :S has done just under 600miles but still wondering y so slow.... anyone got instructionsa on takign the restrictor off the carb and exaust and recommendations for smaller sprocket as no haynes manual out yet so dont ahve a clue Smile
Brava210
PostPosted: 21:06 - 30 Apr 2006    Post subject: Reply with quote
probably as fast as it will go Smile
Honda Novio, Puch Grand Prix, Suzuki AP50, CZ 125, Wassell 125, Montesa 348,Honda 125TDC, Suzuki 100ER, Suzuki GSF650 Bandit, Aprillia Pegaso, Honda PCX125, Honda Forza300, BMW G310 GS, Suzuki SFV650, Honda CB500X
CHARLEY SAYS " ALWAYS TELL YOUR MUMMY BEFORE YOU GO OFF SOMEWHERE"
edd
PostPosted: 22:08 - 30 Apr 2006    Post subject: Reply with quote
Im absolutely sure it should do more than 47 mph.
Do you know that the carb is definitely a point of restriction? im not sure but id imagine they would restrict the carb with a washer type restrictor that you would have to remove the carb to get to. As for the exhaust id guess you'll have a cone restrictor at the manifold end of the pipe. These are usually held in place with 2 spot welds just drill these out and the cone should just drop out. take your pipe off and have a look.
good luck Thumbs Up
Bluespark Automotive - Diesel Tuning for Performance and Economy
The Tot
PostPosted: 22:10 - 30 Apr 2006    Post subject: Reply with quote
Have u run it in properly? I'd recommend adjusting the chain and just keeping it well maintained. Take it for it's first service. I'm liable to believe that that bike can show 65mph on the speedo. If not, it is one sickly sounding bike.
Yam XT is a 4 stroke, so before you ask if it can get derestricted, it can't. 60mph is about all you're going to do. They also don't provide haynes manuals for bikes like these because they're air cooled 4 strokers which are relatively robust and simple to maintain. You don't need nor want to fettle with a machine like this. Sorry to dissapoint you, you're going to have to grin and bear it. I had an XR for a year so i know how you feel.
Never argue with autism
alex_t
PostPosted: 09:44 - 01 May 2006    Post subject: Reply with quote
probably still needs a little more running in, not to worry Smile who chaning the size of the sprocket help u think get a little more out of it?
There is a gap of 1 year, 53 days between these two posts...
108dave
PostPosted: 01:59 - 24 Jun 2007    Post subject: speedo wrong on the xt125 Reply with quote
i had this with my xt it does more the the speedos rong take it to you dealer and say its wrong it happend to me and the use that dash on 2 bikes witch have diffrent size wheels so they set it wrong some times
ne one wanting to fix the problem themselvels all you have to do is tke your fuse out wait 5 seconds put it back in you das will flash endu or motd when it flashes on motd have the mode button for 5 seconds and it will reset the dash for the right tyres oh and your xt tops out at about 75 - 80 down hill and about 65 - 67 on the flat i get 60 with some one on the back lol
Resurrection
Ballast Boy
PostPosted: 03:45 - 24 Jun 2007    Post subject: Reply with quote
I'm sure hes ok now dave as the thread is well over a year old
Res
ZX9r
Finglonga
PostPosted: 11:00 - 24 Jun 2007    Post subject: Re: speedo wrong on the xt125 Reply with quote
And again in English please? Rolling Eyes
Andy Sez....
F.Y.Y.F.F.
Faraz
PostPosted: 14:19 - 24 Jun 2007    Post subject: Reply with quote
I have an '05 one and it does 65ish and has always done since my dad bought it new.
Faraz.
'56 Yamaha MT-01
'05 Nissan 350z Roadster GT
3 words dude.. Fvck. Yes.
nasht98
PostPosted: 10:40 - 11 Dec 2007    Post subject: Reply with quote
Iv got an o6 xt125x and got 64mph out of it last night on a flat road! Somethings wrong like people have said!
Tony
New to bikes, just brought a Yamaha XT125X, loving it!!
mistman
PostPosted: 11:46 - 11 Dec 2007    Post subject: Reply with quote
well with a 15 tooth sprocket on the front (rather than the 14 ) i have seen 74mph on the xt125r there are no restriction on the ike just replace the end can for that better sound o and about 1 hp more power output
2 wheels is freedom , 1 wheel is heaven
Theory Passed 3/04/08 das test passed 12/06/08
piaggio nrg 50cc-sold / yamaha xt125r -stolen / Yamaha XT660X
smithy1219
PostPosted: 18:55 - 11 Apr 2008    Post subject: Reply with quote
I have done 72 mph on my 57 xt125r. that was once it was run in so maybe there is something wrong or it just needs to be run in. Still would have thought it would do a bit more than 47mph though.
hmmmnz
PostPosted: 08:25 - 12 Apr 2008    Post subject: Reply with quote
this thread is years old
the humans are dead
I kick arse for the lord
There is a gap of 1 year, 273 days between these two posts...
misterdave
PostPosted: 21:58 - 10 Jan 2010    Post subject: Reply with quote
Hey seeing as this is a rather old post, is there a definitive yes or no to things such as;
Restriction
end can [speed increase]
making the bloody things move faster?
Squires. Yamaha XT125X - sold. Yamaha DT125R ['97]
hmmmnz
PostPosted: 23:21 - 10 Jan 2010    Post subject: Reply with quote
i said it before....
this post is years old Very Happy
they are no know factory restrictor kit,
the bike is designed to get to 60 and thats about it,
a few things may help, change the carb to one larger,
change out the exhaust to something free'r flowing,
advance the timing by a couple of degree's
you could get more if you were willing to do a cam grind
port the inlet and exhausts, increase the compression or fit a bigger bore
there are also different cdi's avalable
https://www.procycle.us/bikepages/ttr125.html
all the stuff is available for the ttr125 which shares the same bore and stroke,
you can get a 150cc kit complete with cams for not alot of money, couple that to a decent carb probably around a 26-28mm carb
and a new exhaust and you should be away laughing,
people report a 40% increase in power, not that its much 8 hp to 13 Very Happy better than zip though
the humans are dead
misterdave
PostPosted: 11:15 - 29 Jan 2010    Post subject: Reply with quote
Thanks for the reply this may seem like a silly question (excuse me if it is) but would the majority of the parts on the procycle website
( https://www.procycle.us/bikepages/ttr125.html#exhaust ) fit the xt125x?
and how hard / easy is it to fit the BBR big bore kit, I am a complete novice but have a friend who has a bit of experience in motor repairs and such, also my little brother is a semi trained mechanic
[gosh weird looking to my little brother for help, how times have changed Smile ]
plazydays
PostPosted: 21:39 - 01 May 2010    Post subject: Derestrict Yamaha XT125 Reply with quote
Very Happy
I know this is an old post but I thought I would add my 2pence worth for others to see.
The exhaust has a Cat at the bottom. Take off the exhaust, grind the Cat over and remove the inserts. Weld it back up and you'll end up with an increase in performance and even better, use less fuel.
The Cat only works well when really hot but is still restricting the flow of gases from the exhaust. Easy fix and will not cost the earth. you could then follow up with an after market rear can. This will also inprove the BHP of the bike and give it a more throaty sound. Stick to the road legal versions though as any increase from the standard 12BHP on L Plates, if proven could invalidate the insurance.
Previous Bikes: We all start somewhere: Fz50, FS1e, RS100, TS100, MTX125, XT250, XS250,CB250, GT250, GT380, Z250, Z400, GS550, KLR650, KLE500, GP100, GSX250, GS500, GSX600f, XL1000, Zr750, RF900,
P.
PostPosted: 22:57 - 01 May 2010    Post subject: Re: Derestrict Yamaha XT125 Reply with quote
plazydays wrote:
Very Happy
Upto 14.6hp will be fine..
Good luck getting it there..
TUG
PostPosted: 00:50 - 02 May 2010    Post subject: Reply with quote
Its not restricted. ITS A 4 STROKE!!!! ITS A 125!!! BUY A BIGGER BIKE!
Haz ER-5, innit!
plazydays
PostPosted: 09:38 - 02 May 2010    Post subject: Reply with quote
Beg to differ!!!!!!!! Its not restricted in the sense that it was designed with a larger BHP and then reduced. The four stroke on an XT was built with 12BHP in mind. Any vehicle with a CAT Converter on is restricted as it does not allow the engine to breath as well as it could. Although on a car, if you removed it, when it came to an MOT, the gases would would higher and you would face a failure, Bikes are not yet tested for emissions as far as I know so it would increase the BHP with any repercussions. Hence my post. I should know as I have currently just done one myself for a lad.
P.
PostPosted: 10:12 - 02 May 2010    Post subject: Reply with quote
But..it doesnt restrict the power..
Well not enough to cause a noticeable power increase.
PostPosted: 10:38 - 02 May 2010    Post subject: Reply with quote
A well designed cat shouldn't restrict flow at all, while taking the contents of the cat out will leave a bulge in the exhaust which could have some odd effects.
Paxovasa
PostPosted: 10:42 - 02 May 2010    Post subject: Reply with quote
UK 125's are restricted.
Some via ecu, some via exhaust, some via carb and some using all of them.
P.
PostPosted: 11:16 - 02 May 2010    Post subject: Reply with quote
Paxovasa wrote:
UK 125 2 strokes are restricted.
4 strokes are NOT restricted..
Its pitiful trying to think otherwise..
It will not go faster for much longer if you do start fiddling...
plazydays
PostPosted: 17:26 - 02 May 2010    Post subject: No Argument Reply with quote
As a trained mechanic since 1989 and working on them ever since, try this web site which backs up what I have already said:
https://en.wikipedia.org/wiki/Catalytic_converter.
Read the section about negatives which as well as the rest and you will clearly see that the Cat restricts.
The last post was made 15 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.13 - MySQL Queries: 13 - Page Size: 131.55 Kb
