| Ravo |
 Ravo Scooby Slapper
 Posted: 03:20 - 24 Jun 2007 Post subject: New rider's log - More half-wit and wisdom |
This is a new collection of things I'll jot down as I gain experience riding.
Clutchless shifting:
Today I learned how to shift without a clutch. I get up to speed / rpm, then upshift while letting off the gas. Doing both simultaneously let's me upshift smoothly without the clutch. If I get the timing or the rpm wrong, the bike refuses to shift. Neutral can get in the way of shifting into second without the clutch, and I'm going slow anyway so I just use the clutch going from first to second. If I fail to shift on the first try, I just shift with the clutch instead. After learning by using the clutch, it's not really a natural motion to shift without the clutch.
Awareness:
The other day my dad got his CL350 out on the road. I followed him to be safe. Sure enough, a mile out the bike sputters and dies. Having not been ridden for 16 years, the bike hadn't had had a tank of gas put in it for 16 years. I had to pull him home with a quad. The moral of this story? Know when your bike needs gas, or any other mechanical fluid. Running out of gas is bad. Running out of brake fluid or oil is worse.
Keeping track of gas:
Most bikes don't come with fuel guages to tell you how much gas is in the tank. Instead I just reset the trip meter with each tank of gas. I know after roughly 120 miles on my bike my dash lights up saying the bike needs fuel. Using that, I can just look at the trip meter to tell how many miles the tank has left.
Wide turns:
If I take a turn too wide, I go with it. So what if I end up over the white lines on the side of the road? I'm much more likely to lay the bike down correcting a wide turn than I am flirting with the shoulder. I find this happens a lot when I stop at an intersection covered in gravel. I'll wait until I'm over the gravel and then do most of the turning. It doesn't leave me a lot of room to finish the turn. That's where practicing those tight u-turns and figure 8s comes in handy. |
| Nicky-Jano |
 Nicky-Jano Could Be A Chat Bot
| Ravo |
 Ravo Scooby Slapper
| ncrn |
 ncrn World Chat Champion
 Posted: 19:31 - 24 Jun 2007 Post subject: |
| Nicky-Jano wrote: |
I think you'll find most modern bikes actually do have fuel gauges.
Even my bf YBR has one! |
Meh not all bikes do, I'm sure there are quite a few modern bikes that don't. I hated the one I had on my moped, it had no concept of how much fuel I actually had.. And if I turned right the amount of fuel went up.
| Nicky-Jano wrote: | What's with the clutchless shifting?
Seems easier to use the clutch than bugger about with revs and timing  . |
You ride a cg125 right? If its anything like the sr125 I rode, clutch less shifts don't seem to work to well. I found that it didn't help the bike to gain much speed, and I was better off slipping the clutch a little bit.
On a faster paced bike you do notice the loss in power of pulling in the clutch. If you are out and about riding quickly it makes things easier to just let off the throttle and kick, it becomes second nature very quickly.
Sometimes I've found that I've made things awkward for myself, trying to co-ordinate grabbing the clutch, shutting the throttle, changing gear, and going again. Especially if I'm turning at the same time or overtaking.
Also thats another point you don't need to shut the throttle, so you lose even less time off the power. ____________________ Past: 55 Sym Jet, 91 ZZR250, 03 NSR125R. Present: 97 ER-5.
https://www.nsr125.co.uk - NSR Owners forum. |
| ilovensr |
 ilovensr Nitrous Nuisance
| ncrn |
| spooney |
 spooney Borekit Bruiser
The last post was made 19 years, 107 days ago. Instead of replying here, would creating a new thread be more useful? |
