Problem with the NC30
Deano
PostPosted: 18:38 - 14 Oct 2003    Post subject: Problem with the NC30 Reply with quote
Right took my tank, air filter off last nite and found petrol in the air box tray. Now I know for a fact that petrol shouldn't be their. So does anybody know what might of caused it and what i have to do about making sure it doesn't keep happening.
Dean Stone #777
EMRA 2012 final standings, Formula 600s 3rd, Superstock 600s 3rd.
www.triplesevenracing.co.uk: www.ljmotorcyclerepairs.co.uk www.gettaylored.co.uk BN RaceScience, Now officially run out of money to carry on racing Sad
Dr Nick
PostPosted: 18:40 - 14 Oct 2003    Post subject: Reply with quote
stop crashing it? Confused Laughing .
andrew
Mister Road Rage
PostPosted: 18:44 - 14 Oct 2003    Post subject: Reply with quote
Could be a loose pipe on the tank??
WildGoose
White Van Man
i found petrol/oil crap in my airbox more than once
never worried about it personally, but then i sold it to some sucker, so Razz
PostPosted: 20:04 - 14 Oct 2003    Post subject: Reply with quote
If its oil, it could be oil coming up the breather pipe which feeds into the airbox from the sump.
This is caused by one thing and one thing only:
Wheelies Very Happy
Stop wheelying is the answer to that.
If its petrol, then I'd be scared if I were you, cos if your tank has got a hole in it, you'll need to buy wa new one.
As Andrew said, it could be a loose hose, or it could indeed just be where you've taken the tank off, the hose has come loose and sprayed petrol into the airbox.
Find out if its oil or petrol. Stick yer finger in it, if it evaporates, its petrol, if not its oil. Cool
EuropeanNC30R...
Gay Hairdresser
PostPosted: 20:33 - 14 Oct 2003    Post subject: Reply with quote
How much petrol are you talking about?
PostPosted: 23:22 - 14 Oct 2003    Post subject: Reply with quote
Traces of petrol there are fairly normal. Large amounts are not. Some oil will get blown out of the breather hose, the more worn the piston rings are the more oil will get blown out.
PostPosted: 23:28 - 14 Oct 2003    Post subject: Reply with quote
MarJay wrote:
Wheelies
WTF kind of awnser is that to anything? Very Happy
Just not an option Razz.
Craig_
PostPosted: 23:59 - 14 Oct 2003    Post subject: Reply with quote
Small amounts are known from shut off and other various theings... but flooded with petty isnt normal.
VAG Cars - www.vagcars.co.uk - North East VAG Owners Club
Rossi_460
PostPosted: 02:14 - 15 Oct 2003    Post subject: Reply with quote
You could go to 400 grey bike forum, problems like this will be answered no problem. Are you not a member of it any way???
Heres the link, https://www.400greybike.co.uk/forum/
PostPosted: 21:16 - 15 Oct 2003    Post subject: Reply with quote
G wrote:
MarJay wrote:
Wheelies
I didn't mean ACUALLY stop doing wheelies, I meant if you want to stop having to drain oil from the airbox then stop wheelying.
Personally I'd rather do a little more maintenance plus a few more wheelies! Very Happy
Deano
PostPosted: 10:39 - 16 Oct 2003    Post subject: Reply with quote
Right, it's definately petrol, a small puddle in the tray, I did connect the hoses properly and the bike has been sitting still for the 4 weeks. I'm gonna check holes in the petrol tank but dout that thats whats causing it. My guess is that the carbs are squirting too much petrol or something.
And Rossi I am already a member of Greybike (control-007)
Dean Stone #777
Kickstart@Work
PostPosted: 11:05 - 16 Oct 2003    Post subject: Reply with quote
What happens is that the inlets to the carbs are a tuned length, and at certain revs the airflow will go through the carbs but then back through again in the opposite direction (collecting fuel on the way). Sometimes you can see this with the engine running, with a smallfuel mist being visable before the carbs. Depending on what you do with the throttle some of this fuel can then drop out of the airflow and then sit in the airbox.
So a thin coating is not unusual. A puddle would be unusual. But I suppose that depends on the shape of the airbox, etc, and how long it would take to collect. Might be worth checking the carb breather hoses if these vent into the airbox.
Atheism is a not for prophet organisation
Deano
PostPosted: 11:29 - 16 Oct 2003    Post subject: Reply with quote
Ok cheers, not something too much to worry about then but I'll certainly take note and try a few things so thanks guys.
Dean Stone #777
The last post was made 22 years, 305 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.36 - MySQL Queries: 13 - Page Size: 83.83 Kb
