| Ted |
 Ted World Chat Champion
 Posted: 10:32 - 05 Jul 2007 Post subject: Changing a front tyre? |
How difficult is it to change a front tyre (tubeless of course)? I've only ever changed pushbike tyres
I was going to take it to my local garage, but the tyre I want fitted is part worn, and he will only fit brand new ones!  |
| -Savage- |
 -Savage- World Chat Champion
| b-f-c |
 b-f-c Traffic Copper
 Posted: 11:50 - 05 Jul 2007 Post subject: |
Breaking the bead can be a bitch - 20st of fat barsteward wasnt enough, ended up popping into mates garage and using his car tyre gear to pop the bead.
Be sure to lube the new tyre up well and should pop on without too much of a problem.
You will need a compressor with a tank to get the speed/pressure of air in to snap the new bead back into place.
Oh... and watch your fingers  |
| Ted |
| b-f-c |
| Dazbo666 |
 Dazbo666 World Chat Champion
 Posted: 14:52 - 05 Jul 2007 Post subject: |
I'm sure I've seen a how-to video on YouTube in the last couple of days regarding changing a tyre.
The guy had built a hefty wooden structure pivoted to a bench to apply enough pressure to break the bead. And to be honest, it looks like a fairly difficult and frustrating job to do without the proper kit...
I'd look it up for you, but I'm at work with no access to YouTube at the moment ____________________ 1st bike (Sept'06 - May'10) : 1991 GPZ500S / Current bike (since Nov 2009) : 2003 Suzuki Bandit 600N
Word of the day : DILLIGAF |
| Ted |
| BlastThemAway |
 BlastThemAway Renault 5 Driver
| Ted |
 Posted: 16:57 - 05 Jul 2007 Post subject: |
Aye, it'll need a tube. Spoked wheels you see, there is a row of holes all the way round the wheel where the spokes attach. You have to use a tube otherwise all the air would piss out of the holes.*
Fitting a tubed tyre to a 125 is a piece of piss, you can almost push it on by hand. Failing that you can 'walk' it on using the heels of your boots. I just use normal household soap as a lubricant on the rim of the wheel.
Just make sure you don't nip the new tube between the rim and the bead.
You can take them off easily enough with a couple of tyre levers too, the bead can be broken down by hand.
Just like changing a push-bike tyre really, except you do need proper tyre levers to get it off, not your mums best spoon handles.
*Yes, I do know BMW spoked wheels are different but this isn't a BMW. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Ted |
 Posted: 17:09 - 05 Jul 2007 Post subject: |
Should have mentioned, you'll find fitting the new tube a lot easier if you partially inflate it first. Just a small amount of air in it gives you something to push against. You'll see what I mean when you do it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Ted |
The last post was made 18 years, 209 days ago. Instead of replying here, would creating a new thread be more useful? |
