Changing a front tyre?
Ted
PostPosted: 10:32 - 05 Jul 2007    Post subject: Changing a front tyre? Reply with quote
How difficult is it to change a front tyre (tubeless of course)? I've only ever changed pushbike tyres Embarassed
I was going to take it to my local garage, but the tyre I want fitted is part worn, and he will only fit brand new ones! Sad
-Savage-
PostPosted: 11:39 - 05 Jul 2007    Post subject: Reply with quote
Try a different garage then. Changing a tyre is a lot of work. Not too bad to take one off, but getting one on is another story. You need a very high PSI to get the beads in place, never mind the brute force to get it over the lip. I would say phone up a few places and see if they will do it for you.
b-f-c
PostPosted: 11:50 - 05 Jul 2007    Post subject: Reply with quote
Breaking the bead can be a bitch - 20st of fat barsteward wasnt enough, ended up popping into mates garage and using his car tyre gear to pop the bead.
Be sure to lube the new tyre up well and should pop on without too much of a problem.
You will need a compressor with a tank to get the speed/pressure of air in to snap the new bead back into place.
Oh... and watch your fingers Very Happy
Ted
PostPosted: 12:32 - 05 Jul 2007    Post subject: Reply with quote
Got a 150psi compressor at work, and I assume that'll do it. But how hard is it to get the old tyre off and the new tyre on the rim?
b-f-c
PostPosted: 14:27 - 05 Jul 2007    Post subject: Reply with quote
If you can botch up a piece of kit to apply a lot of pressure by the edge of the tyre, by the rim then that might do it.
In the past I've used a jack and an enclosed space to do it [between a workbench and a wall if I remember, it was a while since I dont that]
Rim protectors, levers and lots of lube, non oil based.
I have 2 rim protectors and 3 levers, having another rim protector would have made the last change easier. If your going to make a habit of changing tyres then buy or build a bead breaker.
Dazbo666
PostPosted: 14:52 - 05 Jul 2007    Post subject: Reply with quote
I'm sure I've seen a how-to video on YouTube in the last couple of days regarding changing a tyre.
The guy had built a hefty wooden structure pivoted to a bench to apply enough pressure to break the bead. And to be honest, it looks like a fairly difficult and frustrating job to do without the proper kit...
I'd look it up for you, but I'm at work with no access to YouTube at the moment
Word of the day : DILLIGAF
Ted
PostPosted: 15:56 - 05 Jul 2007    Post subject: Reply with quote
Cheers guys... I just took it to a tyre & exhaust place... and discovered it in fact had a tube in it... I'm sure it said tubeless on the tyre tho... and the tube is knackered, so they have given me the wheel back with the tyre half on it, and I've got to get a tube from somewhere... Nothing ever seems simple with me...
BlastThemAway
PostPosted: 16:11 - 05 Jul 2007    Post subject: Reply with quote
what tyre/wheel/bike is it?
Ted
PostPosted: 16:47 - 05 Jul 2007    Post subject: Reply with quote
'twas a Pirelli on there, not sure what this new (part worn) one is, can't remember! Tyre size is 100/80/17, its the front wheel, and its from an '02 Gilera Coguar 125cc...
PostPosted: 16:57 - 05 Jul 2007    Post subject: Reply with quote
Aye, it'll need a tube. Spoked wheels you see, there is a row of holes all the way round the wheel where the spokes attach. You have to use a tube otherwise all the air would piss out of the holes.*
Fitting a tubed tyre to a 125 is a piece of piss, you can almost push it on by hand. Failing that you can 'walk' it on using the heels of your boots. I just use normal household soap as a lubricant on the rim of the wheel.
Just make sure you don't nip the new tube between the rim and the bead.
You can take them off easily enough with a couple of tyre levers too, the bead can be broken down by hand.
Just like changing a push-bike tyre really, except you do need proper tyre levers to get it off, not your mums best spoon handles.
*Yes, I do know BMW spoked wheels are different but this isn't a BMW.
Ted
PostPosted: 17:03 - 05 Jul 2007    Post subject: Reply with quote
stinkwheel wrote:
...Spoked wheels you see, there is a row of holes all the way round the wheel where the spokes attach. You have to use a tube otherwise all the air would piss out of the holes....
Ah... why the hell didn't I cotton on to that!
Ok, thats cool, I think they have probably done the hardest bit for me... getting the old tyre off and putting the new one half way on!
I better start looking for an inner tube then...
PostPosted: 17:09 - 05 Jul 2007    Post subject: Reply with quote
Should have mentioned, you'll find fitting the new tube a lot easier if you partially inflate it first. Just a small amount of air in it gives you something to push against. You'll see what I mean when you do it.
Ted
PostPosted: 17:25 - 05 Jul 2007    Post subject: Reply with quote
Cheers mate, hopefully I'll get it right!
The last post was made 18 years, 201 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.69 - MySQL Queries: 13 - Page Size: 78.67 Kb
