Wheelies
dkurt535
PostPosted: 12:51 - 01 Jul 2007    Post subject: Wheelies Reply with quote
Hi guys,
Just after a bit of technical tuition, not listed in the driving manual, how to pull a wheelie. I have a restricted Kawasaki ER-5, is this powerful. I'm told you just put it in second, pull the clutch in, rev it and let it out. Is that right? How easy is it to correct, I'm worried I'll come off with some expensive repairs lol. Cheers, Dave
iloveriding
PostPosted: 13:11 - 01 Jul 2007    Post subject: Reply with quote
dont do, your bike is no designed for that and you could end up dead, or worse being drip fed for the rest of your life because when you came of the back you broke your neck that severed all the nerves running down your spine completely leaving you helpless. You will even need some one to change your granny nappy.
Tony,
Ride Safe, Stay Safe, Be Safe, Be Seen And See All Other Idiots on the road
iloveriding
PostPosted: 13:12 - 01 Jul 2007    Post subject: Reply with quote
Now if your off road with the right bike and RIGHT GEAR, go and have some funnnnnnn
Tony Laughing Laughing
Kal
PostPosted: 18:09 - 01 Jul 2007    Post subject: Reply with quote
More to the point your bike dosn't deserve it. Landings from Multiple wheelies can fuck up your headstock, too much air time can deprive the bike of oil and they don't handle as well on one wheel as they do on two.
If you really want to get yourself some decent gear and a cheap field bike you can afford to wreck.
Kal...
timjim
PostPosted: 20:25 - 01 Jul 2007    Post subject: wheelies Reply with quote
ditto..dont try it..just stay safe and alive .the bike was designed around two wheels..stay in control and keep them on the road! Thumbs Up
Jeneric
PostPosted: 21:57 - 07 Jul 2007    Post subject: Reply with quote
I really would advise against it, as above its really not worth the risk, watched a guy try and pull a wheelie next to me at a set of traffic lights and fall straight off the back... not pretty.
However... if you really want to... https://www.thewheelieschool.co.uk/prices.html £175 for a days tuition... and more importantly the chance to wheelie to your hearts content in a safe environment with the right training. Thumbs Up
faddius
PostPosted: 22:31 - 07 Jul 2007    Post subject: Reply with quote
And if you cock up like me when I tried doing a wheelie without proper practice, just a make it up as you go along plan, all you can smell for ages after is burning clutch Sad
alone
PostPosted: 11:30 - 08 Jul 2007    Post subject: Reply with quote
Usually said to cruise along about 25-30mph (I find a standing start , then doing the following as I reach that speed better), and in one quick motion, clutch in, revs up, dump the clutch, and keep turning that throttle.
Always keep your foot over the rear brake. Just don't stamp on it, cus the front will come down too hard.
Or, use the search option, there are loads of threads around on how to do it. Much better than my lame guide :p
Bikes; '06 Triumph Sprint ST 1050 (for sale) - '95 BMW R1100GS
PostPosted: 17:15 - 08 Jul 2007    Post subject: Reply with quote
Only on some bikes:
Nc30, FZR750.
Depends where the oil pick up is in the motor. Fazer thous, CBR600's will wheelie forever with no ill effects on the motor.
You won't be able to clutch up a restricted ER5 in second. First is more realistic.
I would suggest getting used to riding first. I assume you haven't been riding long if you're restricted. Wait until you get a full power bike and then start small by doing power wheelies. It comes up slower and is more controllable. Then move on to clutching it up.
The Tot
PostPosted: 17:45 - 08 Jul 2007    Post subject: Reply with quote
You can fit a larger sprocket on the back, install a "freestyle ingenuity" cage, straight renthal bars, adjust the freeplay on your clutch and throttle and you're set. 1st gear, rev to 9000 rpm and dump the clutch! The front should shoot off, and if you don't have your rear brake covered, you WILL land on your arse. Prolonging the wheelie distance can be done by finely balancing your weight and perfect throttle control. Shift into 2nd sans clutch and you can go for as long as you want.
But i'm just chatting out of my arse here.
Never argue with autism
gazzabo
PostPosted: 20:28 - 08 Jul 2007    Post subject: Reply with quote
On mine i wound on to 12000rpm then dumped the clutch it came up great and shot off .
my arse hurts like hell now and i haven't seen the bike since ? Shocked
{its a fazer 1000 by the way , silver, if anyone sees it } Embarassed
Razz Razz Razz Razz
RD50 < RD125 < 750 Zepher < Fazer 600 < FZ1000 , in silver/black , sex on wheels .
If you love your bike, set it free......
If it comes back you've high sided.
The last post was made 19 years, 64 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 70.18 Kb
