| aran2806 |
 aran2806 Nova Slayer
 Posted: 13:50 - 08 Jul 2007 Post subject: De-restricting a 50cc Moped. |
Hi all. I would like to de-restrict my moped. At the moment i can only get 32 mph out of it. Below is a link on a website which says i can derestrict it by cutting a wire near the battery conpartment. Is this correct or is there a different way to derestrict it correctly?
https://www.rockmopeds.co.uk/ContentPage.aspx?PageID=58
Many thanks for your time.
Aran. |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 14:09 - 08 Jul 2007 Post subject: |
you can all but try, that wire may be a wire from the speedo the limits it, being a 4 stroke you really arnt going to get much more out of it any way.
try it and see, if it doesnt work then reconnect the wire  ____________________ the humans are dead
I kick arse for the lord
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 14:11 - 08 Jul 2007 Post subject: |
there are many different types of restriction for mopeds, a CDI restriction is just one of them.
chances are you also would have an exhaust restrictor, maybe a carb washer restrictor and a drive belt restrictor.
research it a bit more thoroughly before you do anything.
what sort of ped is it? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Jamie S |
 Jamie S World Chat Champion
| aran2806 |
| Jamie S |
This post is not being displayed because it has a low rating (Confusing). Unhide this post / all posts.
 Posted: 14:29 - 08 Jul 2007 Post subject: |
hum , oil in petrol , = 2 stroke
no oil in 2 stroke = bang
Me=
Does it sound like the crazy frog ? Ringggggggggnning ning nign ?
Or sound like brrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr, pop, burrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr ? |
| aran2806 |
| MaybeGuy |
 Posted: 14:39 - 08 Jul 2007 Post subject: |
its a 4 stroke.
chances are its not restricted.
try farting and dry humping it at the same time for a few extra 0.1mph. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| mattjs895 |
 mattjs895 Spanner Monkey
| MaybeGuy |
| Jamie S |
| MaybeGuy |
 Posted: 15:18 - 08 Jul 2007 Post subject: |
and a snorkel  ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Jamie S |
This post is not being displayed because it has a low rating (Flame). Unhide this post / all posts.
| Teaman |
 Teaman World Chat Champion
 Posted: 15:24 - 08 Jul 2007 Post subject: |
as someone above mentioned, there are lots of different ways of derestricting mopeds.
A few people end up coming back to our shop complaining that someone else has done it but it hasnt made a difference.
a lot of fools think all you have to do is remove the O ring that stops the crank rollers coming all the way out (works in a way)
if you are deristricting something like a speedfight you need to blank off and chop/reweld certain parts of the exhausts, (this is where many fall fowl of knowledgeable policemen who can recognise this) then remove the ring washer then put in a bigger jet (not saying what size ) if only the exhaust is done the mixture will be wrong and eventually the bike will seize.
with some chinese bikes we sell the derestrict is usually at the top of the carb stopping the needle from going all the way up, we just remove it.
some again you have to cut a wire, (this is common with quite a few bikes, not just derestricting 50's)
if your bike is the same model as is sold by rock bikes the way they say should be right.
Personally you should listen to what there saying though because if your bike is derestricted you need a certificate saying so to validate your insurance.
that and the fact that when you sell it you have to sell it as a derestricted bike, no 16 year old can buy it and insure it legally and no 17 year old will want it when a 125 will go faster so your stuck with it.
hope that makes sence.
Stu
EDIT, just noticed that the bike in question is either a kinroad or a sukida.
if its a sukida try looking at the carb, if it has a large flat bras looking bit on top take that off, inside check to see if it has a screw thing on a post thingy attatched to the inside of the brasss type thing you removed, if so snap it off, throw away and put it back together, this whould make it do 35 mph at a push  ____________________ There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them. |
| hmmmnz |
 Posted: 16:45 - 08 Jul 2007 Post subject: |
| aran2806 |
| grassby2001 |
 grassby2001 Renault 5 Driver
| hmmmnz |
| aran2806 |
| Jamie S |
| aran2806 |
 Posted: 22:24 - 08 Jul 2007 Post subject: |
how do you know its not restricted then?  |
| Jamie S |
| aran2806 |
| Jamie S |
| Jamie S |
The last post was made 19 years, 99 days ago. Instead of replying here, would creating a new thread be more useful? |
