Gearing down R6 (one for dusty or G maybe?)
R1stu
Shrek!
PostPosted: 12:32 - 20 Oct 2003    Post subject: Gearing down R6 (one for dusty or G maybe?) Reply with quote
I love to pull wheelies on the ole R6. 1st gear are no problem, but 2nd and 3rd cant do very well at all.
I was going to stick a 50t renthal blue sprocket on the rear, but have been told that I would need to go down on the front.
Why? and what combination would you recommend for better take off and wheelies?
Twisted Evil Regards
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
Demonic69
The Pink Rhino
PostPosted: 12:35 - 20 Oct 2003    Post subject: Reply with quote
Gor for 2 down on the front, 2 up on the back. Korn figured that's one of the best combinations.
Back on a Blade. Just feels so right.
Luke_Retrofly
Silly Lesbian
PostPosted: 12:38 - 20 Oct 2003    Post subject: Reply with quote
hi
thats what i did, 2 up 2 down, increase the acceleration quite alot, and the top speed hasnt suffered that much, just got to rev it higher Very Happy
Luke
Flounced - Long overdue
Fuck you bitch I'm in the top 10 list I can do the what the fuck I want!
TiN
Pocket Tin
PostPosted: 12:39 - 20 Oct 2003    Post subject: Reply with quote
You'll want to lose some teeth from the front mainly so that your chain will fit/last longer...unless you're getting a new chain with your sprocket. Similarly, if you lose 2 teeth from the front (and not add any to the rear), you may need take a link out of the chain.
Korn went 2 down, 4 up, didn't he?
TiN
dotgems.net
R1stu
Shrek!
PostPosted: 12:40 - 20 Oct 2003    Post subject: Reply with quote
I would have thoulght that two up and two down would cancel each other out and give the same gearing?
Oh well what do I know? Confused
Korn
Admin
PostPosted: 13:06 - 20 Oct 2003    Post subject: Reply with quote
Not on the same sprocket Razz
3516 Miles, 11 Countries
Sparks!
Sir Tart-a-lot
PostPosted: 13:16 - 20 Oct 2003    Post subject: Reply with quote
hmm i just gone 14/47 on my zxr (15/45 standard) its restricted but will only really get to 95mph and you gotta rev the fuck out of it to get anywhere.
needless to say the restrictors are coming out next week. Twisted Evil
R1stu
Shrek!
PostPosted: 14:08 - 20 Oct 2003    Post subject: Reply with quote
Wouldn't I just be able to move the wheel forward in the swing arm, so that the chain is the right length? That way no need to change the front sprocket. Confused
PostPosted: 14:14 - 20 Oct 2003    Post subject: Reply with quote
Yes, but if you are increasing the amount of chain needed by that much, then you will need a smaller front. 1 down at the front is the same as 3 at the back as well (i think)
Demonic69
The Pink Rhino
PostPosted: 14:17 - 20 Oct 2003    Post subject: Reply with quote
Whatever you do don't just go one down at the front. I did and I got slower 1/4 mile times by .2secs. Probably due to the early gear-change needed. I only notice the front coming up easier in the powerband (or when I didn't want it to while dragging)
Dusty
King of the Rim
PostPosted: 15:12 - 20 Oct 2003    Post subject: Reply with quote
I'm running 14/50 520 sprockets at the moment, as opposed to the standard 16/48 532 settup. This combination keeps the total number of teeth the same, meaning the wheelbase is kept the same.
I have the 520 chain/sprockets because it reduces the rotational mass,- the first thing the engine has to move is the chain and sprockets, so by lessening their weight you allow the engine to spin up faster. This is a common mod done by racers. However it can make power delivery at low speeds a bit jerky.
Putting a 50t on the rear will not make much difference, dropping one tooth at the front will have more effect. Downgearing your bike will also make the speedo over read, and you will rack up more miles than you are actually doing, unless you correct it like Korn and TiN have done using a black robotics yellow box.
Gallery
The last post was made 22 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 71.32 Kb
