| Golden Valley |
 Golden Valley L Plate Warrior
| Skudd |
 Skudd Super Spammer
 Posted: 20:42 - 02 Aug 2007 Post subject: |
Which bit do you need. Pm me your address and I will send you a copy. Just bought the touring set myself.
Or this might work
https://i50.photobucket.com/albums/f324/skudd67/Cargo_sports.jpg ____________________ Famous last words of Humpty Dumpty. " Stop pushing me "
Petty Anarchists look at "1984".............. The Visionary looks at "Animal Farm". |
| Golden Valley |
| Itchy |
 Itchy Super Spammer
 Posted: 12:50 - 03 Aug 2007 Post subject: |
Get some electrical tape not gaffa fabric tape and cover up ALL the bits where the bungees and the straps will go , it'll save the bike tail pod from strap chaffing which my CBR has due to my french trip,
or since leccy tape wears through quickly put electrical tape down first THEN gaffa tape, gaffa tape leaves these horrible hard to get rid of sticky squares all over the tail pod. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| krebsy |
 krebsy World Chat Champion
 Posted: 13:41 - 03 Aug 2007 Post subject: |
You've got the same panniers as me then. . and the same bike.
Ok, first of all, do they have 3 velcro straps linking them or two?
fitting mine I first of all lift the seat off and then undo the straps bar the middle one. Hang the panniers over the rear with the middle strap in line with the middle of the rear seat section and make sure you put the "fat end" of the pannier at the front, otherwise it could foul on the exhaust.
the middle strap should be taut and when adjusted right, the panniers should sit against the rear plastics with the top pretty much level with the rear seat section. Don't worry for the moment if they sag down, just make sure they are clear of the exhausts.
Next, make sure the other straps are out of the way and pop the seat back on. Then fasten the other two sets of straps over the top of the rear seat section and keep adjusting them until all the straps are tight and the panniers aren't drooping down anymore. like I said, they should sit pretty much level with the rear seat section.
They're done now, but you may want to attatch a bungee through the front loop on each side and through the gap in the rear footpeg hanger. I also attatch bungees in a cross pattern across the seat between the paniers if I'm carying lots of stuff or through the handles on top of the bags.
Tighten up the straps on each bag and make sure the zips are closed to the rear of the bag/bike to stop them working themselves open as you ride.
as long as they are snugly fitted to the bike, evenly loaded and not getting in the way of yourself, the passenger and the exhausts then you should be fine. I've toured around with a rucksack, rear box, tank bag and panniers before on my ZZRand you don't notice they are there after a while.
K. ____________________ What's my New Year's resolution?
1280 x 1024. |
| Skudd |
 Skudd Super Spammer
| Golden Valley |
 Posted: 17:26 - 03 Aug 2007 Post subject: |
You guys are just quality  |
| mistergixer |
 mistergixer World Chat Champion
| Golden Valley |
 Posted: 23:30 - 03 Aug 2007 Post subject: |
Bought wonder web - didn't buy enough for the tank bag as well Going to get some more tommorrow + a new summer jacket & trousers. |
| krebsy |
| Colin G |
 Colin G Nova Slayer
| map |
 map Mr Calendar
 Posted: 12:03 - 06 Aug 2007 Post subject: |
From the RiDE magazine site there's this pdf guide on how to fit throw over panniers.
HTH  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| Golden Valley |
The last post was made 18 years, 250 days ago. Instead of replying here, would creating a new thread be more useful? |
