Sorry, another sprocket question
Quote Me Happy
PostPosted: 13:32 - 02 Aug 2007    Post subject: Sorry, another sprocket question Reply with quote
I was looking through my service manual on how to change the front sprocket. It all seems rather straight forward until I read the bit in bold below
Engine Sprocket Installation
•Replace the sprocket washer and axle cotter pin.
•Install the engine sprocket onto the shaft so that the mark
side [A] faces outwards.
•Apply molybdenum disulfide oil solution to the threads of
the output shaft and the seating surface of the engine
sprocket nut.
•After torquing the engine sprocket nut, bend the one side
of the washer [B] over the nut.
What is that stuff? A quick google unsurprisingly showed it's used for lubrication. Is this step essential and can anything else (more common) be used in it's palce?
Thanks.
T1z3R
PostPosted: 13:49 - 02 Aug 2007    Post subject: Reply with quote
copper grease
duck my sick!
Finglonga
PostPosted: 19:00 - 02 Aug 2007    Post subject: Reply with quote
T1z3R wrote:
copper grease
No its not, its grease with a graphite additive. Its a black grease basically used on CV joints etc. I wouldn't put copper grease on there.
Andy Sez....
F.Y.Y.F.F.
T1z3R
PostPosted: 19:43 - 02 Aug 2007    Post subject: Reply with quote
its what on all mine with no negative side-effects in that department.
duck my sick!
Quote Me Happy
PostPosted: 21:03 - 02 Aug 2007    Post subject: Reply with quote
Thanks guys. Any ideas where I could pick some of the graphite stuff up from? Any recommended brands?
instigator
PostPosted: 21:08 - 02 Aug 2007    Post subject: Reply with quote
I tend to use Copper Grease for everything too. No ill effects.
No doubt some rocket scientist will come along and prove why it's no good for this application though. Rolling Eyes Works fine por moi.
Davo
Davo To The Rescue!
PostPosted: 21:18 - 02 Aug 2007    Post subject: Reply with quote
I got some of that stuff in the shed, I normally get it from the local gun shop.
Have also used copper slip with no ill effect.
If you want the "proper" stuff I've found somehere
Quote Me Happy
PostPosted: 21:22 - 02 Aug 2007    Post subject: Reply with quote
Thanks Davo, looks like just the stuff Thumbs Up Plus being on Ebay it means I can get it from the comfort of my chair.
On a side note, are you going to make an appearance any time this year?
Davo
Davo To The Rescue!
PostPosted: 21:25 - 02 Aug 2007    Post subject: Reply with quote
Quite likely to be out for a little bit on Sunday, can't hang around too long as got to get the track suit fitted for Cadwell Park next week.
Finglonga
PostPosted: 21:26 - 02 Aug 2007    Post subject: Reply with quote
Thing is copper slip has tiny bits of copper in and they act as a grinding paste, not a very good one but over time they may cause problems. Its ideal for things like stopping squeal on brake pads.
Andy Sez....
F.Y.Y.F.F.
Quote Me Happy
PostPosted: 21:27 - 02 Aug 2007    Post subject: Reply with quote
I'm not out Sunday unfortunately. Have fun at Cadwell. I think we need to have another SE crew track day again soon.
tatters
Exxon Valdez
PostPosted: 04:11 - 03 Aug 2007    Post subject: Reply with quote
Copper slip prevents threads seizing from corrosion, plus how the hell can it act as a grinding paste on a non-moving surface of a output spline Rolling Eyes
Quote Me Happy
PostPosted: 10:47 - 03 Aug 2007    Post subject: Reply with quote
Well I got some of the stuff Davo pointed out, mainly out of laziness. Just need to wait for all my bits to arrive (if Royal Mail ever sort their lives out) and get cracking.
Keir
PostPosted: 10:52 - 03 Aug 2007    Post subject: Reply with quote
oh a tip for you....
do not jam the chain against the waterpump to get the front sprocket off. it makes a mess and you will need a new waterpump.... Embarassed
Current : '08 Yamaha FZ1s
veeeffarr
PostPosted: 10:55 - 03 Aug 2007    Post subject: Reply with quote
Don't use copper grease in moving applications, it's an abrasive
Use it to prevent galling
I'd use high temp lithium grease, but then I looooooooooooooove the grease
timjim
PostPosted: 21:50 - 03 Aug 2007    Post subject: grease Reply with quote
id avoid copper grease on or near the sprocket assembly,mainly due to the fact that over time it solidifies and attracts dust/rust/muck ,which in turn makes it abrasive as previously stated.Moly grease is widely available...Halfrauds will stock it along with any good motorist/car shop.good luck.tim Karma
Keir
PostPosted: 07:59 - 04 Aug 2007    Post subject: Reply with quote
a bit of copper grease on the thread of the spindle or the thread of the nut is not going to hurt. yes it may be slightly abrasive but the nut shouldnt be moving on the spindle anyway. no movement so no abrasive.
sickpup
Old Timer
PostPosted: 18:15 - 04 Aug 2007    Post subject: Reply with quote
Moly grease I believe also has the advantage or giving a small amount of protection against shock when used on splines. Seem to remember I saw that written somewhere.
The last post was made 19 years, 67 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 95.42 Kb
