How to oil foam air filter?
lugoismad
PostPosted: 07:37 - 03 Aug 2007    Post subject: How to oil foam air filter? Reply with quote
My bike has aftermarket foam airfilters that just tighten down onto the carbs.
I just washed them out in the sink, they were absolutely filthy. The guy I bought the bike from said I can either use special honda brand oil for them, or just use some motor oil.
How do I apply the oil? How much do I use?
Ichy
PostPosted: 07:44 - 03 Aug 2007    Post subject: Reply with quote
I use a spray on oil made by K&N so applying it is easy.
Don't use too much oil or you'll end up creating a restriction to the airflow.
The idea is that it creates a sticky surface over the filter to catch bits of dust.
lugoismad
PostPosted: 07:53 - 03 Aug 2007    Post subject: Reply with quote
Gotcha. I have a K&N Filter in my car, so I know how that works. I actually think I have some of the oil for it around, so I may just use that.
Tricolor Fan
PostPosted: 10:31 - 04 Aug 2007    Post subject: Reply with quote
I thought you weren't supposed to use the K&N Oil on anything other than their own gauze filters - Could be wrong! Confused
Motor oil is no good. I use silkolene, comes as a spray or in a bottle, pretty cheap.
I find the best way to oil the filter is to put a little oil in a zip-lock bag and spread it around so the inside of the bag is covered evenly. Filter goes in bag and gets pressed flat - nice even thin coat. Thumbs Up
EDIT: Right just noticed that they're not flat foam filters. Embarassed
Ichy
PostPosted: 11:21 - 04 Aug 2007    Post subject: Reply with quote
Any thin oil is ok. Just don't use loads.
Odie
PostPosted: 11:38 - 04 Aug 2007    Post subject: Reply with quote
Instructions for the use will be on the can or did you not think of that before you asked your question? Evil or Very Mad
You are so ugly when you were born the doctor said "I?m gonna drop it, if it falls is a rat, if it flies is a bat."
The last post was made 19 years, 66 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 46.93 Kb
