NSR started, then died, then never started
G-force
PostPosted: 16:47 - 03 Aug 2007    Post subject: NSR started, then died, then never started Reply with quote
Having the infamous nsr non-starting problem at the moment. I went for a lil ride and I stopped for a bit. When I wanted to start it again to come back, it wasn't starting, wasnt even turning over. I could hear a small buzzing sound when I was pushing the ignition switch. The lights on the dash were pretty much dim and then faded away after a few attempts at the ignition button.
Started it up again this morning, and it started fine. I leave it for 5 mins to warm up and then it just went off after a bit whilst stationary. Then, it wasn't starting up again making the same light buzzing noise until it wasn't responding at all.
I then connected it up with my car for a jump start. The dash lights became solid and it eventually started after a couple of tries. But once again it cut out itself and wasnt starting again.
I'm thinking this is probably the battery. But what do you guys think?
nick606
PostPosted: 17:10 - 03 Aug 2007    Post subject: Reply with quote
same as you really
test it with a multi meter if you can get hold of one
Jamie S
PostPosted: 17:15 - 03 Aug 2007    Post subject: Reply with quote
sounds like the battery , when was it last charged ?
Ichy
PostPosted: 17:19 - 03 Aug 2007    Post subject: Reply with quote
Its worth cleaning the battery terminals and connectors first, making sure the bolts are nice and tight when you fasten the cables back on.
G-force
PostPosted: 18:44 - 03 Aug 2007    Post subject: Reply with quote
It hasnt been charged at all really. If it is the battery, could I make it come back to life by charging it?
I've just done some searching on the forums and found the optimate 3 charger to be well worth getting. But this is around £35, and im thinkin I could get a new battery for this much??
I dont have a multimeter either, unfortunately.
Ichy
PostPosted: 19:15 - 03 Aug 2007    Post subject: Reply with quote
Yeah, its worth charging.
I use a oximiser(sp?). Cost me about £19 two years ago and works fine. Its worth investing in a charger rather than replacing the battery every time it goes flat
G-force
PostPosted: 23:45 - 03 Aug 2007    Post subject: Reply with quote
But I have the bike for sale and I didn't want the new owner to end up with a bike with a battery that needs charging all the time.
Is the charge required to be done every night then?? That would be a bit annoying wouldn't it. Or after one charge, the battery goes on again for some time?
Ichy
PostPosted: 23:48 - 03 Aug 2007    Post subject: Reply with quote
Assuming your charging circuit is working correctly the battery should only need charging when the bike hasn't been used for a bit of time.
alains
PostPosted: 09:14 - 04 Aug 2007    Post subject: Reply with quote
i think it's more a loose contact on the positive main line (red wire) check it from + battery to starter relay , then from starter relay to key switch . see the wiring diagram
G-force
PostPosted: 12:45 - 04 Aug 2007    Post subject: Reply with quote
But I have been using my bike like once or twice a week and hasnt had this problem so wouldnt be a case of it not being used for a bit of time.
I will take a look at this now. I think im gonna buy a multimeter. Would this help with my situation? Or eliminate one possibility for the problem?
Jamie S
PostPosted: 16:53 - 04 Aug 2007    Post subject: Reply with quote
Were they small journeys ??
Not if you don't know how to use one. Wink
G-force
PostPosted: 19:21 - 04 Aug 2007    Post subject: Reply with quote
Yes they have been small journeys. No more than 5 miles or so. I managed to bump start it and after that it worked fine. I went on a 17 mile round trip to get my hands on a multimeter.
Now I gotta figure out how to use the multimeter. I have not checked the wires yet for any loose connections.
What kind of readings should I expect from the multimeter? What should it not be under?
truslack
PostPosted: 20:07 - 04 Aug 2007    Post subject: Reply with quote
Well what's the reading from the battery?
alains
PostPosted: 23:25 - 04 Aug 2007    Post subject: Reply with quote
do an easy test . on your starter relay you've got 4 wires unplug red and red/white , now make contact between these 2 wires , if your starter does not work put your multimeter on 0-20Volts DC (or over if you have not this state) check voltage between red and ground battery . then a red wire run from the battery to the key lock , a black goes out . as show the wiring diagram you've got a connector under the key , most of bugs come from here . +12V direct is always the red , ground always the green . +12V going after the key lock is always black . so if you want to check a black , key must be on
The last post was made 19 years, 65 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 80.34 Kb
