GSXR400 gk76a electrical problem
21chappers
PostPosted: 16:43 - 10 Aug 2007    Post subject: GSXR400 gk76a electrical problem Reply with quote
heya, last week i sadly came off my bike at about 40 and the bike slid on its right hand side. tried having a quick ride on it last night and the starter doesnt work, just get a ticking noise under my seat. also when i use any of the lights and front brake it switches my engine off. would this mean i just need a new right hand switch gear or could it be worse?
cheers
adam
PostPosted: 20:09 - 10 Aug 2007    Post subject: Reply with quote
aha, but did the R&G's work?
The clicking is your starter solenoid going to work.
I honestly couldn't tell you much else though, sorry mate. Thumbs Up
numark1
Scared of girls
PostPosted: 20:40 - 10 Aug 2007    Post subject: Reply with quote
When i had my gsxr400 that clicking noise was a flat battery. Does the engine stop when you are riding it with the lights on or not??
I had loads of problems with my reg/rectifier and alternator. Basically the battery wasn't being charged so kept cutting the bike out.
21chappers
PostPosted: 13:55 - 12 Aug 2007    Post subject: Reply with quote
yeah the R&G's worked brill, saved the fairings well.
yeah if i use the lights it switches it off aswell. while the bikes running after being bump started that is as it wont put any power into the battery
PostPosted: 19:44 - 12 Aug 2007    Post subject: Reply with quote
If you've only just put a new battery into it then either you got a dud battery, or something's frying it, i.e. Reg-Rec, etc.
21chappers
PostPosted: 07:55 - 14 Aug 2007    Post subject: Reply with quote
charged my battery last nite and it started and all the electrics seemed to work fine. idle seemed a bit funny but aint used it in over a week so may just need runnin through. lets just hope its all sorted.
just need to get these rounded off bolts off now to replace my right hand rear set.
Jenks
PostPosted: 09:12 - 14 Aug 2007    Post subject: Reply with quote
Pop it down here sometime if you need a hand.
1978 MZ TS 250 1 Supa 5
1992 yamaha fzr1000 exup
1998 aprilia af1 sintesi
21chappers
PostPosted: 20:55 - 15 Aug 2007    Post subject: Reply with quote
well just got everything sorted on it and went for a ride to MFN and back. just as i get home the electrics start playing up again as the battery has been drained.
so from this im guessin its just not charging. what could it be?
cheers for any help
Adam
Jenks
PostPosted: 21:09 - 15 Aug 2007    Post subject: Reply with quote
reg/rec mate.
21chappers
PostPosted: 21:12 - 15 Aug 2007    Post subject: Reply with quote
thats wot im thinkin, cant find any on the bay but 1 ran out the other day with no bids on
21chappers
PostPosted: 17:17 - 20 Aug 2007    Post subject: Reply with quote
well just been lookin over the bike as its now sunny for a short while. lookin at the connectors for the reg/rec i find one is a bit dodgy.
https://i210.photobucket.com/albums/bb146/21chappers/DSC00538.jpg
https://i210.photobucket.com/albums/bb146/21chappers/DSC00537.jpg
its full of green stuff which im guessin is copper rust stuff. could this be the cause? wot would be the best thing to do?
cheers
adam
MaybeGuy
PostPosted: 17:20 - 20 Aug 2007    Post subject: Reply with quote
ladies nail file up it, cut it to size and give it a good fucking with it.
have you checked your solinoid? and that the battery is screwed on TIGHTLY???
if its a little loose it will do as you described.
Timmeh
PostPosted: 18:46 - 20 Aug 2007    Post subject: Reply with quote
that connector's a bit trashed dude. The corrosion is caused by age.
If I were you I'd cut them off and make a new connector using insulated bullets.
21chappers
PostPosted: 18:56 - 04 Sep 2007    Post subject: Reply with quote
well annoyingly it has started to do the same again. not want to work with the electrics on and will not charge the battery. the connection i soldered is still fine so have ordered a new reg/rec to see if this works. any ideas if it doesnt?
cheers
adam
The last post was made 18 years, 221 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.43 - MySQL Queries: 13 - Page Size: 80.55 Kb
