computer help!!
Jenks
PostPosted: 16:51 - 14 Aug 2007    Post subject: computer help!! Reply with quote
Just a quick one!
Basically, i have just gone to turn my second pc on - (Hasnt been used in about a month)
press on, and the fans turn once or twice, and then stop - same with leds.
so i swapped the power supply back for the old one (which i swapped over just before i stopped using it - but did test it and it was fine)
Now i turn it on, It all powers up... Mouse lights up... Nothing on screen...
Press on/off / reset and nothing, Try hard shutdown - hold off - nothing...
Have to turn it off via the plug!!!
Whats happening?
1978 MZ TS 250 1 Supa 5
1992 yamaha fzr1000 exup
1998 aprilia af1 sintesi
ken
PostPosted: 17:34 - 14 Aug 2007    Post subject: Reply with quote
Jenks have you got all the correct wires fitted to the motherboard not the big plugs them likkle black ones that are right cnts to fit with fat stubby fingers, It is a problem I faced and sorted with reading mobo instructions to get the right order.
latest bike 03 R1 in zee red and black
Jenks
PostPosted: 17:53 - 14 Aug 2007    Post subject: Reply with quote
yep as far as i know.
i havent touched them at all.
Just put the newer psu back in, and tryed it, and it does exactilly as before - Lights up, spins, and shuts off.
CortezTheKill...
PostPosted: 18:11 - 14 Aug 2007    Post subject: Reply with quote
I had exactly the same problem a couple of weeks ago when I installed some cheap RAM from E-buyer. The computer booted, the fans whirred then it shut off again.
Taking the RAM chips out restored it back to normal.
Not saying this is your problem necessarily, but whatever it is I think it's the BIOS detecting a pretty fundamental error and shutting off before the problem causes any damage.
SV650 - TRASHED
ZX636R C6F - SOLD
Current number of wheels: 0 (not including a bicycle).
Colin Edwards
PostPosted: 18:24 - 14 Aug 2007    Post subject: Reply with quote
Also had it if the fan on the cpu has become unplugged or is obstructed....
CE
Jenks
PostPosted: 21:08 - 14 Aug 2007    Post subject: Reply with quote
tryed either of the ram, and none, checked fan ect. nothing.
DEN MONKEY
PostPosted: 12:35 - 15 Aug 2007    Post subject: Reply with quote
Not suggesting this is your problem but had pretty much the same issue with a pc a while back and it turned out to be a blow cap on the mobo.
Maybe jump in with a torch and look for any swollen ones or burnt looking.
Hard to pick something like this unless you have other parts there ready to swap over and check them all out
meh
Colin Edwards
PostPosted: 20:42 - 15 Aug 2007    Post subject: Reply with quote
Can you enlighten me to what a "blow cap" is?
CE
DEN MONKEY
PostPosted: 09:07 - 16 Aug 2007    Post subject: Reply with quote
Sorry mate that was meant to be blown cap.
as in short for capacitor.
its there little bastards that are all over the motherboard.
https://www.atlascomponentes.com.br/images/html/resistoresardosia300pxw.jpg
I was just looking for an example of one thats shit itself and found this website.
Sounds just like what you are experiencing. so might be worth a look.
I didnt read it all though.
https://www.jebswebsite.com/IBM_bad_capacitors.htm
meh
The last post was made 19 years, 79 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 60.87 Kb
