Bike running bad after crash
numark1
Scared of girls
PostPosted: 20:00 - 14 Aug 2007    Post subject: Bike running bad after crash Reply with quote
I had an accident a while a go low speed, engine case (alternator side) cracked open and oil leaked out.
I got a new case today, put it on and tried to start the bike. Now it took a while to start and when it did it sounded like it was running on 3 cylinders. The starter motor was making a bit of a strange squeeling noise and it will not idle. It will run with the choke on and bogs down a bit if you rev it but as soon as the choke comes off it dies.
Not sure what to do. Crying or Very sad
Chriss
PostPosted: 20:01 - 14 Aug 2007    Post subject: Reply with quote
I had this with my Daytona 600, after changing the plugs, all was running fine, so I suggest the plugs. Smile
Can't really help with regards the stater motor though. Sad
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
numark1
Scared of girls
PostPosted: 20:02 - 14 Aug 2007    Post subject: Reply with quote
They are pretty much brand new plugs from a service though Confused
Chriss
PostPosted: 20:04 - 14 Aug 2007    Post subject: Reply with quote
Changed since going on the side?
numark1
Scared of girls
PostPosted: 20:13 - 14 Aug 2007    Post subject: Reply with quote
No, worth a try though i suppose Smile
Doubt anything got in. To be honest i'm not even sure if it is running on 3 or 4 cylinders. I cut the can down to a stubby and haven't really heard it properly before since the crash as it happend 2 minutes after i cut it Confused
numark1
Scared of girls
PostPosted: 20:39 - 14 Aug 2007    Post subject: Reply with quote
It does the same with with a full size can, it's deffo not running on all cylinders.
Phil_G
PostPosted: 20:52 - 14 Aug 2007    Post subject: Reply with quote
Check the plugs.
If its been over on its side, is it likely to have got oil where it shouldnt have it and fouled a plug?
good luck sorting it out Smile
1997 Kawasaki ER 500 A1:- Once again, Its merely crap Smile
numark1
Scared of girls
PostPosted: 21:07 - 14 Aug 2007    Post subject: Reply with quote
I think i will check the plugs first tomorrow, make sure they are all ok and all sparking then have to take it from there. Thanks
moonym20
PostPosted: 21:47 - 14 Aug 2007    Post subject: Reply with quote
not familliar on your type of bike,
i presume when the case cracked oil pissed out?
did you drain the sump and then do a full oil change? you might want to give that a thought because you don't want any nasty metal bits floating around the system.
Have you checked all the carbs to make sure they all operate full and free, no leaks or stuck valves?
Kickstart may be able to elaborate but it may be possible the bike is not firing on one cylinder because the ignition pickup has messed up. sheer speculation but its all worth a shot
its also possible the starter motor took a good knock when it hit the deck hence the squealing noise either that or mabye oil related?
hope it helps mate... good luck Karma
A scientist crossed a skunk with an owl. He's got a bird that smells but doesn't give a hoot Smile
Walloper
PostPosted: 22:55 - 14 Aug 2007    Post subject: Reply with quote
How long was it out of action?
What was the weather like on the day you parked it up?
Damp day may have allowed condensation to collect in the tank run down to the bottom then when you started the beast the shit got sucked down it's neck.
Try fresh fuel and a dash of Redex Snake Oil.
Sounds more fuel that spark/mechanical.
Starter noise may just be you hearing things.
(coz you're not used to strange noises of a living fire breathing iron dragon)
PostPosted: 23:08 - 14 Aug 2007    Post subject: Reply with quote
Most of the ignition system would take 2 cylinders out if damaged (and then it would be an absolute nightmare to start). If you get it running then carefully pat the exhausts from the head so you can see which are hot (be careful, easy to burn yourself) and so which cylinders are running. If a single cylinder is not firing then that counts out the pickups, cdi and coils. Could then be worth changing the plugs round and see if it moves cylinders (or see if that plug comes out hideously dirty).
How long ago did you drop it? How long has it been waiting to be fixed?
numark1
Scared of girls
PostPosted: 17:40 - 15 Aug 2007    Post subject: Reply with quote
It was out of action for about 10 days. I drained all the oil and put fresh new stuff in. I will pull out the plugs tonight and have a look and report back. Very Happy
PostPosted: 18:02 - 15 Aug 2007    Post subject: Reply with quote
Only 10 days counts out fuel age issues.
Take it the oil that came out was OK, and not stinking of petrol.
TUG
PostPosted: 18:04 - 15 Aug 2007    Post subject: Reply with quote
check your carbs are seating correctly, i had a spill and it was running on 2 and a half cos the carb wasnt on correctly.
Haz ER-5, innit!
bish777
PostPosted: 01:43 - 16 Aug 2007    Post subject: Reply with quote
You could try removing the starter motor and re instaling it, as it could be stuck in engagement, causing the bike to run like manure. Make sure you remove the starter motor and not the alternator...... Alternatively smack the starter with a soft faced mallet.
Also drain all the oil and change it. Turn fuel tap off, drain the float bowls and turn the motor over to help purge any excess petrol in the cylinders.
remove and clean the sparkplugs. Barring these its , like kickstart said, unlikely the ignition side is damaged.
GSXR1100J
b-f-c
PostPosted: 08:55 - 16 Aug 2007    Post subject: Reply with quote
When mine went over, the shit in the carbs moved and blocked one of the them.
Tried cleaning them out?
A blow through with compressed air cleaned mine up
numark1
Scared of girls
PostPosted: 20:35 - 16 Aug 2007    Post subject: Reply with quote
Right it's the 4th cylinder that isn't going. I have checked to see if it is sparking by taking the plug out and putting it against the frame and there is a spark however i don't know if it is weak or not.
I might try changing the ht lead. However i will try the other things mentioned on sunday when i get a chance. Thanks for all the help people Thumbs Up
By the way when i took all the plugs out none of them were dirty at all. Thanks
TUG
PostPosted: 20:53 - 16 Aug 2007    Post subject: Reply with quote
have you checked to see if your carbs are attached propperly it only taks a 0.5mm gap mate.
Haz ER-5, innit!
numark1
Scared of girls
PostPosted: 12:18 - 19 Aug 2007    Post subject: Reply with quote
The new oil i put in now has become milky so i am going to change it. (fucking expensive Sad ) I am also going to get new spark plugs and clean out the carbs. after that it's gonna have to go to a garage i think. I'm not sure where the coils are on my bike it seems the loom just connects on to the spark plugs so maybe the coils are in the plug holders???
Wish it would just work now Sad
PostPosted: 18:37 - 19 Aug 2007    Post subject: Reply with quote
Just sounds like water in it. Possibly just water from having stood. Possibly a blown head gasket. Possibly something in between.
Yes, coils built into the plug caps, so one coil per cylinder.
numark1
Scared of girls
PostPosted: 22:16 - 19 Aug 2007    Post subject: Reply with quote
Just for an update i wacked the carbs off and gave them a clean out. When inspecting them it looks like one of the fuel connectors on the 3rd carb has snapped off (metal) therefore not enough petrol getting to the 4th cylinder. I am going to try and fix it up and hopefully should be it.
Will upload a pic when i can
roach_101
PostPosted: 23:24 - 19 Aug 2007    Post subject: Reply with quote
yeah there really isn't any point in buying new ht leads and plugs. it is obviously the carb as you mentioned the fuel line being snapped. btw if the coils are built into the plug cap you should be able to tell as the cap is longer than usual caps Thumbs Up . also if you have only just changed oil and now it is a milky colour it cant be just from standing. it is definitely got a problem, probably the head gasket but you never know the crash could have made a small fracture between the water jacket and the cylinder/crankcase which could also be a reason for it running like shite. check you're coolant level. lets hope it isn't that serious Praying .
numark1
Scared of girls
PostPosted: 18:42 - 20 Aug 2007    Post subject: Reply with quote
that didn't fix it Sad sometimes it sounds like for a split second its firing on all 4. i think it must be electrical.
changed oil and its not watery any more. just running out of ideas?? Anyone know any mobile mechanics?? I can't get it to a garage at the moment Sad
Chriss
PostPosted: 10:33 - 23 Aug 2007    Post subject: Reply with quote
This is getting really desperate for ideas, but on my Daytona 600, I can unplug the coils from the leads, and swap them about, worth checking stuff like that and seeing if it moves cylinder.
The other problem I've had on the Daytona 600 was water was in one of the cylinders. I used compressed air to blow the water out, and ran fine after that.
Never was too sure how the water got in there... Thinking
sickpup
Old Timer
PostPosted: 14:04 - 23 Aug 2007    Post subject: Reply with quote
You can tell if the plugs are built into the coils as there's no HT lead so you can't replace it. Length of cap is irrelevant.
The last post was made 18 years, 235 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 131.25 Kb
