| map |
 map Mr Calendar
 Posted: 11:57 - 14 Aug 2007 Post subject: Quick brake banjo fitting question |
Sorting out the brakes and need some crush washers for the banjo bolts. Are they all the same?
I know they can be copper. Honda OE are aluminium I believe. Any difference?
Just going to pop down to the local bike shop for the bits (not Honda dealer) and this thought just popped into my head. maybe a stupid question but I don't want any hassle as I'd rather prefer my brakes to work correctly.
Thanks  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| Walloper |
 Walloper Super Spammer
 Posted: 15:08 - 14 Aug 2007 Post subject: |
My HELL braided hoses came with aluminiumummummum, but copper would possibly do.
It may depend on the loading that may act on the banjo. Copper is harder so would resit twisting and slackening off. Maybe.
A shower of contradiction should follow now..
I would go with the al-you-minimum. Or OEM spec.
The washers only help the sealing faces of the parts to conform to one and other. (As you are no doubt aware.)
But if you want to keep the weight down use aluminium.  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| Big Pete |
 Big Pete Spanner Monkey
| sickpup |
 sickpup Old Timer
| map |
 map Mr Calendar
 Posted: 23:37 - 14 Aug 2007 Post subject: |
Ok, another quick question.
I know the copper ones can be reused via the heating and cooling trick mentioned above.
Is there any way to reuse the aluminium ones?
Just thought I'd ask  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| Walloper |
| sickpup |
 sickpup Old Timer
| Walloper |
| sickpup |
 sickpup Old Timer
| Walloper |
The last post was made 18 years, 327 days ago. Instead of replying here, would creating a new thread be more useful? |
