Please help get me up to speed!
joseph.griffin
PostPosted: 12:57 - 15 Aug 2007    Post subject: Please help get me up to speed! Reply with quote
Hi. This is my Honda NSR 125 RX. It's a 1999 model.
https://i232.photobucket.com/albums/ee145/josephgriffin/nsr002.jpg
I'm hoping that someone will be able to tell me what's wrong with it (apart from the scratches). When I start it up in a morning it's ridiculously smoky and there is a major flat spot between 5000 and 9000 revs. This goes after a few minutes but could it be indicating a more serious problem?
Also, my top speed is about 65mph and 0 to 60 takes probably 12seconds, which seems slow when nsr125.com says is should be 100mph and 5seconds. The restricting plate in the intake tract has been removed and this is the exhaust...
https://i232.photobucket.com/albums/ee145/josephgriffin/nsr001.jpg
Am I right in thinking that it has been deresricted? I don't know about the reed valves and carb jets as there is no service history - will these make much difference? How much difference would drilling the airbox make, apart from noise? That's one thing i can do.
Around the exhaust there is sooty, oily deposits (you can see it on the picture). I guess this is probably related to the problem. The power valve seems to be OK - at least it seems to make the right movements.
Also, will the bike pass its MOT if it has been deresricted? It's coming up soon.
Joe
alun111
PostPosted: 13:46 - 15 Aug 2007    Post subject: Reply with quote
sounds like it's burning oil! If you're not great with mechanics i'd suggest taking it to a garage, or if you're careful and have a haynes manual i'd suggest giving it a go yourself aslong as you don't need the bike on a daily basis.
Best checking the pistons, piston ring and valve adjustment things like that i would have thought.
Someone else on here could probably give better advice, just thought i'd give you my two cents.
As with the m.o.t, i would imagine it would pass as i'm fairly sure you can ride derestricted after you've passed your test, and obviously the mot tester won't know this. Someone will probably correct me on this though.
andrew
Mister Road Rage
PostPosted: 13:51 - 15 Aug 2007    Post subject: Reply with quote
One thing i'd like to ask, why are there holes drilled into the end of the exhaust? Being a stroker i think that might be causing some problems... When i de-restricted my nsr exhaust i didn't end up with holes in the end of it..... Have they actually derestricted the exhaust properly or drilled some holes in the end of it?
Oh and it will pass an MOT despite being derestricted.
andrew
Mister Road Rage
PostPosted: 13:52 - 15 Aug 2007    Post subject: Reply with quote
That's what NSR's do! Very Happy
andrew
Mister Road Rage
PostPosted: 13:54 - 15 Aug 2007    Post subject: Reply with quote
Also, have you removed the restrictor on the carbs? It sounds to me like the bike just hasn't been derestricted properly/at all....
The oily sooty stuff on the exhaust is normal, well it was on my nsr and the 2 that my mates owned..... It burns the oil and makes a lot of smoke being a stroker so i think that's ok.
joseph.griffin
PostPosted: 13:55 - 15 Aug 2007    Post subject: Reply with quote
I don't know if the exhaust has actually been deresricted. How could i check? It's all been painted over so i couldn't take the end off without getting a hack saw on it.
andrew
Mister Road Rage
PostPosted: 13:58 - 15 Aug 2007    Post subject: Reply with quote
Well, if it's only going 65 mph then i'm guessing it hasn't been derestricted but it would be my guess that whoever has done that to the exhaust has knackered it.....
Have you taken a look at this sites NSR derestriction guide?
https://www.nsr125.com/derestrict.htm
Everything you need is in there. One thing to note, if your bike is an import you will more than likely have a restricted ECU, this can be a pain in the arse to replace.
Have you seen that guide though?
That guide derestricted my bike along with 2 others that my friends owned and we were all seeing 100mph indicated so it does work.
joseph.griffin
PostPosted: 14:00 - 15 Aug 2007    Post subject: Reply with quote
The gold plate behind the carb? it was never there - i took it all apart expecting to find it. Very disappointed when i found out.
veeeffarr
PostPosted: 14:04 - 15 Aug 2007    Post subject: Reply with quote
Of course it's burning oil you tit it's a two stroke...
Is that exhaust a drilled stock exhaust? Sounds like its restricted.
andrew
Mister Road Rage
PostPosted: 14:05 - 15 Aug 2007    Post subject: Reply with quote
Then your exhaust is still restricted... Do you know if your bike is an import?
joseph.griffin
PostPosted: 14:08 - 15 Aug 2007    Post subject: Reply with quote
I don't know whether it's an import. How would I tell that? I have the V5 and it says "declared new at first registration" - if it was imported would that be different?
Should I get my hack saw out? If so, where should i make the cut?
Yeah - nsr125.com's guide is great. That's how I found out about the carb restrictor. I just assumed that the exhaust was already derestricted.
Thanks for your help, by the way.
PostPosted: 14:13 - 15 Aug 2007    Post subject: Reply with quote
You need a lot of drills and a lot of time to take the restrictor out of the front of the exhaust. But even then it should do more than 65mph when restricted. You won't get it to 5 seconds 0-60. 7 to 8 maybe.
If you lift the seat up you should hopefully find a sticker with lots of country codes on it, one of which should have a hole punched in it to say which market it was built for.
andrew
Mister Road Rage
Make the cut? Everything you need is in that guide that Korn wrote. The is a restrictor at the beginning of the pipe that needs to be drilled out as well as one in the actual pipe i believe... Kornel derestricted mine so i can only tell you what i remember.....
No offence but you don't sound the most mechanically minded person, don't you have anyone who could help you do it?
It's quite easy to make a mess of these things.. Very Happy
joseph.griffin
PostPosted: 14:32 - 15 Aug 2007    Post subject: Reply with quote
The only codes under the seat say...
NSR125RX
COLOUR NH-1
CODE NH1E
Can you tell the country from that?
I'm not that bad with mechanics, but I don't know anyone who's any better - that's why I'm here.
andrew
Mister Road Rage
PostPosted: 14:39 - 15 Aug 2007    Post subject: Reply with quote
NSR125RX
COLOUR NH-1
CODE NH1E
Give Chiswick Honda a call, say you want to order some parts and ask if they can tell if your bike is an import from the bottom code or your reg?
Their number is 0845 338 6145, i'd ask to speak to the parts department.... If they can't help, hopefully somebody with an import will be along.... Very Happy
joseph.griffin
PostPosted: 14:41 - 15 Aug 2007    Post subject: Reply with quote
Is my exhaust standard? It doesn't look like this one in Korn's guide at the moment...
https://www.nsr125.com/zorstholes.jpg
Would i be right in cutting it along this line?...
https://i232.photobucket.com/albums/ee145/josephgriffin/Copyofnsr001.jpg
Surely then I would be able to see the restrictor. But there is another one aswell as this one mentioned in Korn's guide?
Joe
PostPosted: 14:44 - 15 Aug 2007    Post subject: Reply with quote
You are looking at totally the wrong end of the exhaust for the restrictor. It is in the down pipe where the exhaust leaves the engine.
joseph.griffin
PostPosted: 14:47 - 15 Aug 2007    Post subject: Reply with quote
Right. I'll have a look as soon as i get chance.
Thanks
Minty
PostPosted: 15:10 - 15 Aug 2007    Post subject: Reply with quote
Looks like someone has decided to drill the wrong end of the pipe, nice.
Way to fook a pipe.
My suggestion would be to get on ebay and buy another.
My fingers smell of your mum.
joseph.griffin
My exhaust has already been derestricted by the looks of it...
https://i232.photobucket.com/albums/ee145/josephgriffin/nsr007.jpg
I thought I was actually getting somewhere then.
Would the holes in the wrong end of the pipe have a detrimental affect on performance though?
Joe
P.S. It wasn't me who drilled those holes - it was like that when i got it.
joseph.griffin
PostPosted: 15:46 - 15 Aug 2007    Post subject: Reply with quote
Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile
Right.
I might as well start a new post! I now know that there is no intake/carb restrictor or exhaust restrictor, but I still don't know about the jets or valves.
I've just seen another post here that makes me think my bike is a French import (my serial number starts with ZDCJC22B...) So will my bike be electronically limited? If so, what's the best way to fix it? The problem in the linked post was that the servo wasn't working, but mine does.
Joe
PostPosted: 15:54 - 15 Aug 2007    Post subject: Reply with quote
While it might be restricted in another way it should still be doing more than 65mph.
To be honest first thing I would do is a compression check to check it is healthy (from memory it should be 128psi +/- 14psi).
andrew
Mister Road Rage
PostPosted: 15:58 - 15 Aug 2007    Post subject: Reply with quote
Right.
Joe
From what i can remember (it was 7 years ago), it's very rare to find somebody that has managed to fully derestrict a European import, i think the ECU's are restricted and i don't know if you can just swap it for a derestricted one. If you can you might be able to get a cheap one on ebay or by using the site in my sig.....
There were plenty of people on here who have owned European imports so hopefully you'll get a bit more help from them later on?
joseph.griffin
PostPosted: 16:57 - 15 Aug 2007    Post subject: Reply with quote
My compression is reading 105psi. The Haynes manual says 142 +/-28. (Kickstart - right numbers, wrong order, but not bad from memory!)
So mine is about 9psi below the minimum of 114psi.
It did stay at 105 for the couple of minutes that I left it, so that suggests to me it's not leaking, but I could be wrong.
Could this be the source of my poor performance? And what can I do about it? My bike was cold when I tested it - would this affect my compression much?
Thanks. Joe
PostPosted: 17:10 - 15 Aug 2007    Post subject: Reply with quote
It is down, and may well be worth a new set of rings / piston, but I would not expect it to be enough to loose you 30mph of top speed (assuming you are thrashing it, not jut sitting upright and opening the throttle a bit in top).
The compression tester will maintain its reading anyway, even without pressure in the engine.
The last post was made 18 years, 334 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 2.06 - MySQL Queries: 13 - Page Size: 137.83 Kb
