| joseph.griffin |
 joseph.griffin Renault 5 Driver
 Posted: 12:57 - 15 Aug 2007 Post subject: Please help get me up to speed! |
Hi. This is my Honda NSR 125 RX. It's a 1999 model.
https://i232.photobucket.com/albums/ee145/josephgriffin/nsr002.jpg
I'm hoping that someone will be able to tell me what's wrong with it (apart from the scratches). When I start it up in a morning it's ridiculously smoky and there is a major flat spot between 5000 and 9000 revs. This goes after a few minutes but could it be indicating a more serious problem?
Also, my top speed is about 65mph and 0 to 60 takes probably 12seconds, which seems slow when nsr125.com says is should be 100mph and 5seconds. The restricting plate in the intake tract has been removed and this is the exhaust...
https://i232.photobucket.com/albums/ee145/josephgriffin/nsr001.jpg
Am I right in thinking that it has been deresricted? I don't know about the reed valves and carb jets as there is no service history - will these make much difference? How much difference would drilling the airbox make, apart from noise? That's one thing i can do.
Around the exhaust there is sooty, oily deposits (you can see it on the picture). I guess this is probably related to the problem. The power valve seems to be OK - at least it seems to make the right movements.
Also, will the bike pass its MOT if it has been deresricted? It's coming up soon.
Joe |
| alun111 |
 alun111 World Chat Champion
| andrew |
 andrew Mister Road Rage
| andrew |
| andrew |
| joseph.griffin |
| andrew |
 Posted: 13:58 - 15 Aug 2007 Post subject: |
Well, if it's only going 65 mph then i'm guessing it hasn't been derestricted but it would be my guess that whoever has done that to the exhaust has knackered it.....
Have you taken a look at this sites NSR derestriction guide?
https://www.nsr125.com/derestrict.htm
Everything you need is in there. One thing to note, if your bike is an import you will more than likely have a restricted ECU, this can be a pain in the arse to replace.
Have you seen that guide though?
That guide derestricted my bike along with 2 others that my friends owned and we were all seeing 100mph indicated so it does work. |
| joseph.griffin |
| veeeffarr |
 veeeffarr Super Spammer
| andrew |
| joseph.griffin |
 Posted: 14:13 - 15 Aug 2007 Post subject: |
You need a lot of drills and a lot of time to take the restrictor out of the front of the exhaust. But even then it should do more than 65mph when restricted. You won't get it to 5 seconds 0-60. 7 to 8 maybe.
If you lift the seat up you should hopefully find a sticker with lots of country codes on it, one of which should have a hole punched in it to say which market it was built for.
| andrew |
| joseph.griffin |
| andrew |
| joseph.griffin |
| joseph.griffin |
| Minty |
 Minty World Chat Champion
| joseph.griffin |
 Posted: 15:10 - 15 Aug 2007 Post subject: |
My exhaust has already been derestricted by the looks of it...
https://i232.photobucket.com/albums/ee145/josephgriffin/nsr007.jpg
I thought I was actually getting somewhere then.
Would the holes in the wrong end of the pipe have a detrimental affect on performance though?
Joe
P.S. It wasn't me who drilled those holes - it was like that when i got it. |
| joseph.griffin |
 Posted: 15:46 - 15 Aug 2007 Post subject: |
Right.
I might as well start a new post! I now know that there is no intake/carb restrictor or exhaust restrictor, but I still don't know about the jets or valves.
I've just seen another post here that makes me think my bike is a French import (my serial number starts with ZDCJC22B...) So will my bike be electronically limited? If so, what's the best way to fix it? The problem in the linked post was that the servo wasn't working, but mine does.
Joe
| andrew |
 Posted: 15:58 - 15 Aug 2007 Post subject: |
| joseph.griffin wrote: | Right.
Joe |
From what i can remember (it was 7 years ago), it's very rare to find somebody that has managed to fully derestrict a European import, i think the ECU's are restricted and i don't know if you can just swap it for a derestricted one. If you can you might be able to get a cheap one on ebay or by using the site in my sig.....
There were plenty of people on here who have owned European imports so hopefully you'll get a bit more help from them later on? |
| joseph.griffin |
The last post was made 18 years, 337 days ago. Instead of replying here, would creating a new thread be more useful? |
