carb screws
lwoboy35
PostPosted: 17:47 - 15 Aug 2007    Post subject: carb screws Reply with quote
hi
just wondering what the difference is between the air screw and the throttle stop screw. Its because my 50 has poor idle speed and cuts out when lights are switched on
TUG
PostPosted: 18:07 - 15 Aug 2007    Post subject: Reply with quote
you need to read the manual and turn the air mixture screw to the stated amount, the throttle stop screw will set your idle, set the idle with the lights on Wink Very Happy
Haz ER-5, innit!
lwoboy35
PostPosted: 18:12 - 15 Aug 2007    Post subject: Reply with quote
i didnt get a manual with it what should i do now to set it right
TUG
PostPosted: 18:15 - 15 Aug 2007    Post subject: Reply with quote
what bike is it?
Haz ER-5, innit!
lwoboy35
PostPosted: 18:21 - 15 Aug 2007    Post subject: Reply with quote
it's a yamaha yq50 aerox
TUG
PostPosted: 18:42 - 15 Aug 2007    Post subject: Reply with quote
well without me having a manual i cant tell you what to do, all you can do is turn the throttle screw to adjust your idle, set the idle with a hot engine about half way on the gauge to get a good reading, and set your idle with your lights on etc, then when your happy it will do, problem is tho, you dont know what to set it to do you? if i was you i'd buy a manual of find one on the net. Very Happy
Haz ER-5, innit!
lwoboy35
PostPosted: 18:56 - 15 Aug 2007    Post subject: Reply with quote
just got a workshop disk of a mate and found the settings but i can't quite understand i took a screenshot and attached it
TUG
PostPosted: 19:30 - 15 Aug 2007    Post subject: Reply with quote
ok well i think that they stand for countrys tbh with you, is there no key in the file? to tell you what it stands for? if i was you i'd turn it out 1 and 3/8'th of a turn what you have to do is tighten it until its just seated, so not too tight then turn it back out 1 full turn and 3/8ths so like just under half a turn. understand now mate? Very Happy
Haz ER-5, innit!
TUG
PostPosted: 10:28 - 16 Aug 2007    Post subject: Reply with quote
did you sort it out?
Haz ER-5, innit!
lwoboy35
PostPosted: 10:26 - 17 Aug 2007    Post subject: Reply with quote
yes thanks it starts and ticks over fine now so it must be set up right cheers
TUG
PostPosted: 18:57 - 17 Aug 2007    Post subject: Reply with quote
no worries mate, nice one Very Happy
Haz ER-5, innit!
The last post was made 18 years, 328 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.21 - MySQL Queries: 13 - Page Size: 64.75 Kb
