KMX125 Chain and Piston Calculations
rallymark1
PostPosted: 23:51 - 19 Aug 2007    Post subject: KMX125 Chain and Piston Calculations Reply with quote
Hi,
Trying to nail two birds with one stone in this topic.
1st What size chain does a 125 KMX have?
2nd For measuring the CC (power) for a motorbike what calculations do you have to do for the measuring of the piston and isn't there something to do with the stroke?
I am trying to calculate the CC size of my KMX field bike as it has been overbored and it is no longer a 125...
Thanks
Suzuki TS185 (1978), Yamaha YZ125 (1989)
alien.46.uk
PostPosted: 00:15 - 20 Aug 2007    Post subject: Reply with quote
IIRC the size of the overbore is normally stamped on top of the piston. Thumbs Up
2007 Kawasaki ZX10R :: 1998 Kawasaki ZX-9R - SOLD
1998 Yamaha FZS600 Fazer - SOLD :: 1994 Aprilia Pegaso 125 - SOLD
rallymark1
PostPosted: 09:50 - 20 Aug 2007    Post subject: Reply with quote
ideal, ill have a look later today, also while bike is running the KIPS is leaking a small amount of oil out of the cover.
Could this mean that the rings on the piston are worn and theres oil passing up through? The bike seems to go well enough and doesn't seem to lack power.
Liamo
PostPosted: 11:53 - 20 Aug 2007    Post subject: Reply with quote
Which side is leaking?
rallymark1
PostPosted: 14:32 - 20 Aug 2007    Post subject: Reply with quote
If your looking at the rear of the bike its the left hand side, its the side with the KIPS cover on, not the exhaust side with the powervalve linkage.
Liamo
PostPosted: 15:49 - 20 Aug 2007    Post subject: Reply with quote
KIPS is the powervalve BTW (Kawasaki Integrated Powervalve System
Take the cover off, remove any traces of the old gasket (if there is any) from the cover and from the engine, and cut out a new gasket from paper gasket cover. Also, I dont think that there should be excessive ammounts of oil in this cover so if its really p1ssing out, you have some engine problem. a small bit stuck to the cover etc, is fine.
Liamo
PostPosted: 16:43 - 23 Aug 2007    Post subject: Re: KMX125 Chain and Piston Calculations Reply with quote
According to the Haynes manual for this model:
Chain Size: 428 (1/2 x 5/16)
No. Of Links: 124
20-Link Length: 254.0 to 254.6 mm (10.000 to 10.024 in)
Service Limit: 260mm (10.24in)
Hope this helps Very Happy
The last post was made 19 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 53.31 Kb
