Laptop Memory Upgrade - Not going to plan.
Evo
PostPosted: 19:09 - 21 Aug 2007    Post subject: Laptop Memory Upgrade - Not going to plan. Reply with quote
OK sick of it now.
Only got 512mb in at mo, 256mb x 2. 200pin sodimm, 333mhz(PC2700).
Right first purchased 2 x 1GB sticks. When both installed, screen wouldn't boot, CPU booted but no screen response. If i put 1 of the old 256 sticks in with 1x 1gb then screen would boot aswell but BIOS asks me to accept the new memory configuration of 256mb.
So i thought the 1gb must be too large for the motherboard or shagged.
Purchased 2x 512mb sticks by Infineon. Same results as above.
So again though just to make sure they arent shagged too, ill get some more.
Purchased 2 x 512mb Crucial sticks. Yet again same results.
I know how to install memory, get rid of static energy through a grounded object(radiator) with feet firmly on floor.
Don't know what to do, some of these sticks must work. All are brand new.
Can anyone help me ?
Thanks,
Bikes owned
1989 VFR 400 RR NC30
T1z3R
PostPosted: 19:31 - 21 Aug 2007    Post subject: Reply with quote
have you confirmed your laptop can handle sticks larger the 256MB?
duck my sick!
Evo
PostPosted: 20:21 - 21 Aug 2007    Post subject: Reply with quote
Can handle 1GB on the motherboard.
Bikes owned
T1z3R
PostPosted: 20:25 - 21 Aug 2007    Post subject: Reply with quote
natively or after a BIOS update?
its unlikely that all the sticks are faulty so either theres something wrong with the mobo/BIOS settings or a BIOS update is needed.
whats the make and model?
duck my sick!
Evo
PostPosted: 20:38 - 21 Aug 2007    Post subject: Reply with quote
Natively/Bios = Over my head.
And HP Compaq NC4000
Bikes owned
Stevie GooGs
PostPosted: 20:47 - 21 Aug 2007    Post subject: Reply with quote
You might need to update the BIOS on your laptop so that it can see the higher memory. Check to see if there is any bios updates for your mobo.
Evo
PostPosted: 20:59 - 21 Aug 2007    Post subject: Reply with quote
Ran a driver check program and only thing remotely hardware that needs update was:
IDE ATA/ATAPI controllers.
Though i don't know whether the program checks the BIOS.
How do i check what version BIOS drivers i have to compare to whats available on net ?
Bikes owned
T1z3R
PostPosted: 21:21 - 21 Aug 2007    Post subject: Reply with quote
checked the HP site and it shouldnt need a BIOS update.
crucial suggest P/N CT526688 or CT526689 512MB sticks for that model. is that what you bought?
duck my sick!
Evo
PostPosted: 21:24 - 21 Aug 2007    Post subject: Reply with quote
No i've got 2 sticks of This
Bikes owned
T1z3R
PostPosted: 21:25 - 21 Aug 2007    Post subject: Reply with quote
its the same spec so should be working.
duck my sick!
Evo
PostPosted: 21:32 - 21 Aug 2007    Post subject: Reply with quote
God knows, Just doesn't recognise it.
Bikes owned
Stevie GooGs
PostPosted: 11:05 - 22 Aug 2007    Post subject: Reply with quote
Does it recognise any of the memory sticks including the original?
sickpup
Old Timer
PostPosted: 11:52 - 22 Aug 2007    Post subject: Reply with quote
The memory crucial recommend is a specific compaq memory. That's probably the problem.
-Elliot-
PostPosted: 15:48 - 27 Aug 2007    Post subject: Reply with quote
did u remove the laptop battery before installing as this can affect the memory.
remove battery
install memory
reinsert battery
turn on
The last post was made 19 years, 40 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 78.82 Kb
