Weird noise comming from engine ?
firefox
PostPosted: 21:47 - 21 Aug 2007    Post subject: Weird noise comming from engine ? Reply with quote
Hey i rebuilt my dt today, got the head skimmed as it was warped, now the bike has a vibration noise/ rattling noise comming from it really really loud, does anyone know what could cause this sort of noise ?
ill record the sound tommorrow.
thanks
dodge
bye bye gti <^>( ' . ' )<^>
*officer* what caused the crash ? *firefox* you see that wall up there sir ?
*officer* yes what about it *firefox* i tooted my horn but it refused to move i had to teach it a lesson.
roach_101
PostPosted: 21:57 - 21 Aug 2007    Post subject: Reply with quote
hey how much did it cost ya for the skim as i will need mine done sometime. was it only the head that you took off and nothing else coz it sounds like something is loose or worn. i wouldn't start it again as it could be something serious just take it back apart and check everything is on properly.
Jamie S
PostPosted: 22:02 - 21 Aug 2007    Post subject: Reply with quote
Most machine shops charge around £20 - £30 for a head to be skimmed
@ Fire fox , is the noise a "clunk" or a tap or what ?
From what you have said it sounds like it could be the big end.
How much of the engine did you strip ?
firefox
PostPosted: 22:09 - 21 Aug 2007    Post subject: Reply with quote
Head skimmed, barrel a little skim ( very little ) top of barrel skimmed ( 20 quid ) i replaced the bearing ( piston one ) piston, rings barrel, head sorted, its like a tapping noise very loud. sounds like something could be loose but nothing is from what i can see. is there anyway to see if the main bearings are gone ?
Jamie S
PostPosted: 22:12 - 21 Aug 2007    Post subject: Reply with quote
Only if you strip the engine back down.
firefox
PostPosted: 22:13 - 21 Aug 2007    Post subject: Reply with quote
well do tell how far back down, pot back off ? ect
Jamie S
PostPosted: 22:15 - 21 Aug 2007    Post subject: Reply with quote
Engine out ,Head off, barrel off and check for side to side movement of the con rod.
firefox
PostPosted: 22:17 - 21 Aug 2007    Post subject: Reply with quote
well there always gonna have 1 or 2 mm, as theres a gap either side of the rod, thought it was up or down movement ? im confused Sad
roach_101
PostPosted: 22:24 - 21 Aug 2007    Post subject: Reply with quote
did it sound fine before the top end rebuild? if the barrel has been bored have you put oversized rings in as the piston could be slapping. but anyway from what you describe noise to be it is more of a rattle and not a slap which could be the bearings but could be something just loose. you should really check everything is definitely on properly.
firefox
PostPosted: 22:27 - 21 Aug 2007    Post subject: Reply with quote
started a while ago very quietly but is getting louder Evil or Very Mad
roach_101
PostPosted: 22:33 - 21 Aug 2007    Post subject: Reply with quote
well in that case i think it must be your big end bearing as you said you have just replaced the small end bearing. does the noise get louder or quieter when you rev it. normally with big end bearings the noise doesn't go away when revving engine whereas small end bearings normally do. i would definitely check big end bearing. when jamie said check side to side movement i think he might have meant side to side angular movement as when the bearing wears there is more free play between the two surfaces.
befdelta7
PostPosted: 19:50 - 22 Aug 2007    Post subject: Reply with quote
yep sounds like the big end bearing to me. happened to me 3weeks ago. had a little ticking noise for ages that got louder very very quickly, untill the engine just was too loud to run, this is with 2headphones in and music up to volume limit. then i had extreme engine braking when coming off the throttle. so i took the head off, barrel off and piston off and had a feel of the conrod and sure enough there was loads of angular side to side movement. so i just bought a second hand 9,oookm engine, just waiting for it to arrive should be here friday Praying then we'll see how it goes.
but yea, i personally think you big end bearing has had it.
Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine.
firefox
PostPosted: 21:14 - 22 Aug 2007    Post subject: Reply with quote
When i ride and put the power on the sound totaly goes, few of the bikers i know think the power valve is rattling around ?
befdelta7
PostPosted: 22:36 - 22 Aug 2007    Post subject: Reply with quote
are you sure the noise just goes, and isnt masked by the noise of the engine as you accellerate?
Jamie S
PostPosted: 22:40 - 22 Aug 2007    Post subject: Reply with quote
Get a long screwdriver and put your ear on the handle end , then put the "pointy" end on the barrel and have a listen to see if it's still there when you rev the bike..
st3v3
PostPosted: 22:42 - 22 Aug 2007    Post subject: Reply with quote
Might be your rings not quite the right size for the barrel? Need to hear it. I can't see it being the big end unless someone has let some crap in there.
thegubner
PostPosted: 22:45 - 22 Aug 2007    Post subject: Reply with quote
As daft as it sounds.........is it possible you have left a nut or bolt loose to rattle round in there when taking it apart/putting it back together?
befdelta7
PostPosted: 22:49 - 22 Aug 2007    Post subject: Reply with quote
does the bike run fine apart for the rattling noise?
firefox
PostPosted: 22:56 - 22 Aug 2007    Post subject: Reply with quote
runs fine, noise goes got standard pipe on can barely hear the noise of the engine.
befdelta7
PostPosted: 23:03 - 22 Aug 2007    Post subject: Reply with quote
my advise, as my grandad told me, if you hear a strange noise turn the music up(ipod in my case) and carry on. if the bike stops running then come to me.
basically dont worrie about the noise, but then when or even IF a problem arrises... start to worrie LOL.
should be fine, just put your mind at ease and take the barrel off, check the conrod for excessive play, then recheck the work you've done already. you'l probably find its something stupid and worried for nothing.
st3v3
PostPosted: 23:05 - 22 Aug 2007    Post subject: Reply with quote
That's not good, it'd like hiding a fault.
It'll get worse and bite you in the ass when you least expect it to.
Get to the source of the issue now Imo.
firefox
PostPosted: 23:08 - 22 Aug 2007    Post subject: Reply with quote
gonna drop the engine if it aint the powervalve and give the shop it to fix full engine rebuild 90 quid then parts on top.
befdelta7
PostPosted: 23:09 - 22 Aug 2007    Post subject: Reply with quote
i get paronoid about the smallest of noises, maybe he got fed up of me asking what that noise could be, what this noise could be Confused LOL
its hard trying to diaognoise a 'noise' over the internet, you got that recording yet firefox?
firefox
PostPosted: 23:10 - 22 Aug 2007    Post subject: Reply with quote
an woops ill get one 2 morrow, if anyone wants to add me to msn to give me your wonderful help. my msn is [email protected]
befdelta7
PostPosted: 23:13 - 22 Aug 2007    Post subject: Reply with quote
ill add ya if you dont mind, but im only on it every now and again. msn names the same as on here.
The last post was made 19 years, 51 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 130.72 Kb
