electrical problem
lee8040
PostPosted: 08:23 - 22 Aug 2007    Post subject: electrical problem Reply with quote
bike is in the shop now with some sort of fault but thought id see if you guys could think of the cause so i can see if the shop can think of all causes.
the bike is a kymco zing 125. it has had 2 new batteries the first one put in this morning, fully charged. the problem is that the indicators either flash really fast when riding or when stopped and brake is applied they stop flashing until either the brake is released or the revs are increased. also the horn doesnt work it appears there isnt enough power getting to the horn as it does one pathetic sound then stops working.
anyone think of a cause?
cheers
Cigaro
PostPosted: 08:28 - 22 Aug 2007    Post subject: Reply with quote
Sounds like the regulator might have gone?
lee8040
PostPosted: 08:44 - 22 Aug 2007    Post subject: Reply with quote
expensive to replace?
lee8040
PostPosted: 10:10 - 22 Aug 2007    Post subject: Reply with quote
SHOP says it the main fuse holder is at fault so they put a new one on. does this sound like it could be the cause?
hmmmnz
PostPosted: 10:52 - 22 Aug 2007    Post subject: Reply with quote
you can basically use a regulator/rectifier from any bike.
heres a wiring diagram for you bike that i have done
https://images6.theimagehosting.com/albums/27345/kymco.zing.th.jpg
and heres a kymco reg on ebay
or contact these guys
they supply original equipment for kymco bikes
i hope that helps ya Mr. Green Thumbs Up
good luck Thumbs Up
remember to go over your bike and look at all the connections and see if one has come loose or is corroded
the humans are dead
I kick arse for the lord
lee8040
PostPosted: 11:17 - 22 Aug 2007    Post subject: Reply with quote
can that cause the above symptoms even with a full battery?
hmmmnz
PostPosted: 11:30 - 22 Aug 2007    Post subject: Reply with quote
aha, your bike produces a ac (alternating current) from the alternator/generator its usually around of 50v, the rectifier/regulator
changes the said ac voltage of around 50v to a dc (direct current) voltage of about 12-15v
the battery stores the voltage and smoothes off the excess peaks and troughs from the ac-dc conversion.
if your reg isnt woring correctly then obviously you could be getting spikes of voltage of 50 or so volts.
resulting in blowing bulbs and possibly stuffing your cdi in the long run.
there are plenty of articles on the web of how regulator/rectifiers work,
which, no doubt will be clearer than my explanation.
good luck Thumbs Up
the humans are dead
Walloper
PostPosted: 14:45 - 22 Aug 2007    Post subject: Reply with quote
Bad Negative connection between frame and Negative battery post. has same effect as it 'regulates' power to some extent. In a way.
Electrics (like girls) are not always simple.
Most of it is hardware and energy transfer the remainder is magic which even electricians don't fully comprehend. Razz
They'll only ever master this 'Black Art' in an effort to baffle mechanics and laypersons. (Supervisors too.) Cool
I hope this helps you. Karma
garyd
PostPosted: 18:03 - 22 Aug 2007    Post subject: Reply with quote
Yep clean up ALL the earth points on bulb holders ,horn,frame etc. Thumbs Up
The last post was made 19 years, 66 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.30 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 59.73 Kb
