Honda C90, i have spark, i have fuel, will not run...
DKG40
PostPosted: 20:08 - 22 Aug 2007    Post subject: Honda C90, i have spark, i have fuel, will not run... Reply with quote
howdy
had this engine on my go kart, it ran fine, then stopped working, found the stator was naffed, got a replacement, put back together, still doesnt want to work...
before the stator went we had no spark...
new stator, we now have spark...
fuel seems to be feeding fine....
it just wont start!
any ideas, something i am missing???
thanks
Dan
Jamie S
PostPosted: 20:09 - 22 Aug 2007    Post subject: Reply with quote
Timing ?
DKG40
PostPosted: 20:18 - 22 Aug 2007    Post subject: Reply with quote
how is the timing set? ive adjusted everything that can be adjusted but still nothing...
Jamie S
PostPosted: 20:19 - 22 Aug 2007    Post subject: Reply with quote
C90 hum...........................Points I think.
DKG40
PostPosted: 11:33 - 23 Aug 2007    Post subject: Reply with quote
anyone any ideas?
the timing i have checked all way through, just nothing, i definate spark tho!
DKG40
anyone any ideas?
rsooty
PostPosted: 11:39 - 23 Aug 2007    Post subject: Reply with quote
Is it starting and dying or can you just hear the starter motor ticking over? It could be too much or too little fuel. Not too sure about the C90, is it carb or injection? And is it 2 stroke or 4? Could be 1 of many things.
DKG40
PostPosted: 15:00 - 23 Aug 2007    Post subject: Reply with quote
you kick it and just nothing, i will let the pictures try and explain a little on the engine, its off a honda cub i do believe...
https://img518.imageshack.us/img518/1156/dsc01275fi6.jpg
(ignore the car battery it is mearly a support lol)
Jamie S
PostPosted: 15:36 - 23 Aug 2007    Post subject: Reply with quote
well for starters there should be a cover over that Stator and the stator should run in oil. Confused
DKG40
PostPosted: 16:07 - 23 Aug 2007    Post subject: Reply with quote
its cdi i do believe, isnt it in the coil bit? ive checked the timing all over no sign of anything, it is an odd one for sure...
baldy
PostPosted: 20:03 - 23 Aug 2007    Post subject: Reply with quote
Hi, that looks like the points model, its under the round cover, take out the long bolt on the square bit at the other side of the engine, the round cover will come off.
check the points gap and the timing, if that fails, a valve might be sticking, check the clearences on the tappets, there under the 2 round covers on the head.
One day i will rule the world, just not today.
DKG40
PostPosted: 20:28 - 23 Aug 2007    Post subject: Reply with quote
cheers baldy, well i popped that cover off, and all i can see is the face of a cog with 3 bolts on it, nothing to really adjust or check
how do you actually check the points gap and timing?
valves look to be moving fine... Mad
DKG40
PostPosted: 20:34 - 23 Aug 2007    Post subject: Reply with quote
yeah i just realised now what the point is, you can adjust it through the holes on wheel on pic, ive adjusted it everywhich way yet nothing...
DKG40
PostPosted: 20:42 - 23 Aug 2007    Post subject: Reply with quote
well got a spare coil coming so im hoping that fixes it, as that was the first bit that went, then the strator, continuity checked that and it fine...
cheers guys
The last post was made 19 years, 67 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 90.19 Kb
