So called easy job fucked up
Marcg868
PostPosted: 18:20 - 23 Aug 2007    Post subject: So called easy job fucked up Reply with quote
The age old adjust and lube the chain has turned into a disaster!
It didnt start well, the axel bolts were stupidly tight, done by the monkeys at regent no doubt and not at the correct torque setting.
So i kept plodding on, and eventually heard a crack, and then it loosened off pretty much normally. So i got the chain adjusted all good. Started to tighten it up its not tightening, take the bolt off and fine a shard of metal, on the bolt.
Now basically have i shagged the bolt or have i completely trashed my spindle?
JACK, MISS YOU LOADS YOU LEGEND.
Lanny
PostPosted: 18:27 - 23 Aug 2007    Post subject: Re: So called easy job fucked up Reply with quote
If you`re talking about the wheel spindle itself, then I suggest you replace it, together with the nut
It shouldn`t cost too much - If you know your local bikeshop at all, I`m sure they`d be able to sort you with a spindle from a similar bike
The trick is to grease the new spindle so that this doesn`t happen to ya again
The Bloke from Stoke
Kiss_My_Rs
PostPosted: 18:27 - 23 Aug 2007    Post subject: Reply with quote
Well it depends on if you shreded the thread on the bolt or the spindle.
Http://www.manchesterbikers.net
Marcg868
PostPosted: 18:42 - 23 Aug 2007    Post subject: Reply with quote
It looks like the bolt, it came off the bolt. So i imagine its that.
veeeffarr
PostPosted: 19:02 - 23 Aug 2007    Post subject: Reply with quote
Need pictures mate
Does it have threadlock on it?
T
deanoet
PostPosted: 19:20 - 23 Aug 2007    Post subject: Reply with quote
Is the metal "shard" like a short peice of ribbon?
Prob just stripped the thread
Check the bolt, is any of the thread missing:
If it is, it is the bolt that has stripped and all you need is a new bolt
If it isnt, the bit it screwed into has had the thread stripped.
Dependant on the tollerances on the part you can re-drill and re-tap the thread bigger then buy a bigger bolt to fit. Or just buy a new bit.
konsoli
PostPosted: 19:52 - 23 Aug 2007    Post subject: Reply with quote
I had a similar fuck up, took my suspension off, getting it back on was a lot harder, I got the bolt somewhat in, hit it with a hammer for ages and tried to get it all the way in with no success. I was bending the metal plates at the bottom because i didn't line the bolt up properly.
I looked where the bolt screwed in and the thread was completely fucked. I couldn't replace it either because the nut was wielded into the suspension piece.
What I had to do was simply use a smaller bolt & a nut. Just whacked it through, tightened it as hard as I could. I think it's strong enough to support the weight. =]
Marcg868
PostPosted: 19:53 - 23 Aug 2007    Post subject: Reply with quote
Took it off and basically found out that the bolt has no thread, the spindle thread looks fine.
I think a mechanic has done a shoddy shitty job, and helicoiled the fucker or something and no told me.
ZRX61
Victor Meldrew
PostPosted: 19:59 - 23 Aug 2007    Post subject: Reply with quote
Throw your tools in the nearest river, seriously.... Rolling Eyes
Quote Me Happy
PostPosted: 20:02 - 23 Aug 2007    Post subject: Reply with quote
You are seriously retarded. I'd like to think you're a clever forum troll but unfortunately I don't think you are. Do what ZRX61 says before you kill yourself. Although you killing yourself through your own stupidity is only natural selection at work I suppose.
konsoli
The last post I made where I showed that I didn't fully understand something, you ripped on me too. I know a lot about computers that you will never understand but I wouldn't take the piss out of you. I'm learning. And you don't understand Razz I tried to screw it in for a very long time, trying to line it up, but it wasn't working so I tried hammering it through while I held it in place, but I couldn't get it to go through. So I resorted to the only thing I could think of to get my bike working again without buying a new rear suspension.
Quote Me Happy
PostPosted: 20:03 - 23 Aug 2007    Post subject: Reply with quote
konsoli wrote:
I know a lot about computers that you will never understand .
How many people have died from bodging a computer program?
konsoli
PostPosted: 20:05 - 23 Aug 2007    Post subject: Reply with quote
My bike weighs 87kg dry, I weigh 11 stone.
The bolt is quite secure I must say. You havn't seen it so you cannot comment.
It's just a few mm smaller than the previous one so it's still thick and strong. It holds my weight as it did before. It's the same thing basically just a fraction smaller bolt.
Finglonga
PostPosted: 20:10 - 23 Aug 2007    Post subject: Reply with quote
They are made a certain size for a reason, doesn't matter on the weight of the bike or you, its still going to hurt alot if it fails. Get it repaired properly before you become a statistic.
Andy Sez....
F.Y.Y.F.F.
deanoet
PostPosted: 20:13 - 23 Aug 2007    Post subject: Reply with quote
Yup, just go and buy a new bolt. If you dont know what size it is just take it into a car / bike shop and ask for a non broken one while handing the broken one over.
In my experiance it does tend to be the bolt that strips and not the nut, no idea why. (tool maker, never worked on a bike)
When you get the new bolt try it in, but dont force it if it is tight straight away, there is a chance it could have damaged the thread in the spindle(??). If it feels overly tight when screwing it in go to a local friendly garage and ask if they can run a tap through the spindle for you just to clear the thread. 30 second job with the correct tools. Unlikely it has damaged it, but dont break another bolt forcing it. Smile
Marcg868
PostPosted: 20:24 - 23 Aug 2007    Post subject: Reply with quote
Aye going to try that tommorow! Get a new bolt first, and if i cant get that to work will take it to a garage.
Dont think the spindle's thread is damaged tho. Will take pictures tommorow, when its light. Thumbs Up
veeeffarr
Ok numbnuts tell me how much force is transmitted through the bolt when you hit a pothole at 70mph?
deanoet
PostPosted: 20:26 - 23 Aug 2007    Post subject: Reply with quote
U cant normally see the damage, as it can just slightly pull a bit of the thread up. Looks fine, but it is super tight screwing it in. All the tap does is re-align the thread, as well as remove any rough edges if there are any Smile
Good luck. Thumbs Up
PostPosted: 21:43 - 23 Aug 2007    Post subject: Reply with quote
Fifteen in one night springs immediately to mind.
That would be the night the new London ambulance service computer system went live. 999 calls scrolled off the top of the screen and there was no way of getting them back again.
tatters
Exxon Valdez
PostPosted: 21:53 - 23 Aug 2007    Post subject: Reply with quote
Does,nt matter how tight its is theres still going to be movement similar to a worn bush and it will fail at some point. Rolling Eyes
konsoli
PostPosted: 22:48 - 23 Aug 2007    Post subject: Reply with quote
the nut that is wielded inside where you insert the bolt is threaded. thats a new suspension.
veeeffarr
PostPosted: 22:51 - 23 Aug 2007    Post subject: Reply with quote
Oh right, yeah that'd be really expensive
You should just bodge the repair with a cheap part, I'm sure it'll be fine, but I don't care if you die, it's not my body!
T
konsoli
PostPosted: 23:01 - 23 Aug 2007    Post subject: Reply with quote
T
It's all I could think of to repair it as it was. I think it will hold until I can afford a new suspension. I cannot afford it yet but I need a ride. if I die it's my fault so don't worry about it. I know it will be fine though
konsoli
PostPosted: 23:02 - 23 Aug 2007    Post subject: Reply with quote
Well numbnuts, I'm not stupid enough to drive over potholes and my bike manages 60 maximum.
here's few pics of the bolt and nut. I think it will be safe until i get a new bike, either 125cc or -33bhp (very soon) =]
Philious
PostPosted: 23:05 - 23 Aug 2007    Post subject: Reply with quote
Back on topic,
Me and a mate replaced the chain and sprockets on my XR125 last night, didnt break anything taking it off. But when torquing up the front sprocket nuts one of them snapped the head off. Luckily i had a couple kicking around.
Must say now i've ridden it about abit its so much smoother when pulling away in first, i think the old chain and sprockets were so worn that the sprocket jumped a couple of teeth while pulling away.
Hope u get urs fixed Thumbs Up
*Edit*
Thanks to ggg__ for actually trying to help in the chat room last night angle grinder worked lovely. Thumbs Up
Previously; Honda XR125 - Yamaha DT125r - Aprilia Rs125 - Suzuki GS500e, Currently; Kawasaki ZX6R + ZX10R
Theory : Passed 28/7/09 Module 1: Passed 21/09/09 Module 2: Passed 23/09/09
The last post was made 19 years, 59 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 135.05 Kb
