| Simple |
 Simple World Chat Champion
| Ichy |
 Ichy World Chat Champion
| instigator |
 instigator Super Spammer
| veeeffarr |
 veeeffarr Super Spammer
 Posted: 22:40 - 28 Aug 2007 Post subject: |
By definition, a stage 3 kit requires pod filters.
Having messed about with those engines a fair bit, I would be loath to bin the airbox. The GPZ airbox is what gives it that banzai acceleration at high revs, there must be some serious pressure-wave action going on in there. My mate who knows about such things tells me it is not unusual for a well designed airbox to be scavenging 110% or more of the engine capacity. That means it'll suck in 10% more air with the airbox fitted than it would with open bellmouths.
I also know for a fact that Kawasaki spent a massive amount of their R+D budget on carburettion research during that era, that's how they made the GPZ900R (from which your bike is derived) into the first sportsbike to crack 150mph. I also know that they employed accoustic engineers to design the airbox for the ZZR1100 which was THE fastest bike you could buy for a considerable period.
Small things can make a big difference, ask anyone who decided it would be a good idea to cut the small plastic baffles off the inside of the airbox on their NC30 in an attempt to 'derestrict' it.
So, I would suggest going no further than stage 2 which would involve a K&N filter and sporty pipe.
In all honesty though, they are fast enough for the chassis they are in as standard. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Simple |
 Posted: 22:42 - 28 Aug 2007 Post subject: |
air filters we have sorted, exausts current best plan is to remove the rivets from the stock system and remove the baffles.
I dont think the motad system has much in the way of baffles left
I wont be fitting the kit just yet, leaving it stock for winter plodding about to uni and back, however for tracktime next year I'd like more oomph from the same 'shitter'. So contemplating the kit now as it's cheap.
Simple ____________________ Insta - FemFeral |
| Ichy |
| bish777 |
 bish777 World Chat Champion
| Simple |
| bish777 |
| Simple |
| bish777 |
 Posted: 02:28 - 29 Aug 2007 Post subject: |
I would say the stage 3 kit is to get a bike which has been screwed around with in other ways to run decently again, rather than something you fit and then screw around with the bike to get it to work.
Airboxes and inlets are designed just as carefully as decent exhausts. Dumping the airbox and hacking out the baffles is not likely to give you anything much at all.
| Simple |
| bish777 |
| Simple |
| Irezumi aka Reuben |
 Irezumi aka Reuben Carrot Top
 Posted: 02:40 - 30 Aug 2007 Post subject: |
The weight balance of the whole chassis is too biased towards the rear and there is too much flex sideways at the front of the bike.
If I was going to mod the bike I'd get a bar mounted between the two spars towards the front of the frame and perhaps fit some stronger (triple?) yokes. Try raising the rear and dropping the front as well.
Or just buy a better bike.
As Stinkwheel said do the suspension if your on the cheap. New shock and stiffer springs, or at least make sure you have 15W oil in the forks. ____________________ Pictorgraphicalfantastical |
| tsmith |
 tsmith Traffic Copper
| Simple |
The last post was made 18 years, 232 days ago. Instead of replying here, would creating a new thread be more useful? |
