Dynojet stage three gpz500s
Simple
PostPosted: 22:20 - 28 Aug 2007    Post subject: Dynojet stage three gpz500s Reply with quote
stop laughing I'm being serious,
anyone else done this? what air filters and exhaust did you have
I have the option of a stage 3 kit for the GPZ,
thoughts?
possible problems?
I have the options exhaust wise of stock system, a motad nexxus system and duplicates of each which can be customised.
Simple
Insta - FemFeral
Ichy
PostPosted: 22:31 - 28 Aug 2007    Post subject: Reply with quote
Stage three is generally with modified air filter, usually pods, and an aftermarket, free flowing, exhaust. Neither of the systems you mention really qualify although I guess you could try taking the baffles out. The Stage 3 will usually give a bit more top end but at the sacrifice of torque in the 2-4k area.
The jets are likely to be too big, although some kits come as stage one and three. If the kit is a real good price then you can buy the correct sized jets for a stage one kit from a K&N dealer for about £1.50 each.
The stage three and above that I've fitted have generally been a real pain to get set up correctly.
instigator
PostPosted: 22:34 - 28 Aug 2007    Post subject: Re: Dynojet stage three gpz500s Reply with quote
thoughts?
possible problems?
Simple
Someone on this forum, I believe, has a full race system made by Hindle (?) Do a wee search for it...it was a bargain and I don't believe they sold it either.
veeeffarr
PostPosted: 22:35 - 28 Aug 2007    Post subject: Reply with quote
Laser probably make a system for the GPZ
PostPosted: 22:40 - 28 Aug 2007    Post subject: Reply with quote
By definition, a stage 3 kit requires pod filters.
Having messed about with those engines a fair bit, I would be loath to bin the airbox. The GPZ airbox is what gives it that banzai acceleration at high revs, there must be some serious pressure-wave action going on in there. My mate who knows about such things tells me it is not unusual for a well designed airbox to be scavenging 110% or more of the engine capacity. That means it'll suck in 10% more air with the airbox fitted than it would with open bellmouths.
I also know for a fact that Kawasaki spent a massive amount of their R+D budget on carburettion research during that era, that's how they made the GPZ900R (from which your bike is derived) into the first sportsbike to crack 150mph. I also know that they employed accoustic engineers to design the airbox for the ZZR1100 which was THE fastest bike you could buy for a considerable period.
Small things can make a big difference, ask anyone who decided it would be a good idea to cut the small plastic baffles off the inside of the airbox on their NC30 in an attempt to 'derestrict' it.
So, I would suggest going no further than stage 2 which would involve a K&N filter and sporty pipe.
In all honesty though, they are fast enough for the chassis they are in as standard.
Simple
PostPosted: 22:42 - 28 Aug 2007    Post subject: Reply with quote
air filters we have sorted, exausts current best plan is to remove the rivets from the stock system and remove the baffles.
I dont think the motad system has much in the way of baffles left Twisted Evil
I wont be fitting the kit just yet, leaving it stock for winter plodding about to uni and back, however for tracktime next year I'd like more oomph from the same 'shitter'. So contemplating the kit now as it's cheap.
Simple
Insta - FemFeral
Ichy
PostPosted: 23:00 - 28 Aug 2007    Post subject: Reply with quote
stinkwheel wrote:
Stuff about GPZ's
I've got to agree, I've fitted a few different kits to various bikes and my ZL, which basically uses the same engine as the GPZ's was a real bitch to get running with pods and a stage three. You might as well chuck the standard settings out the window.
At a guess I would say it took 2 months to get it running how I felt it should. Yes I could of took it to a dyno but that would have been too easy Wink
bish777
PostPosted: 23:10 - 28 Aug 2007    Post subject: Reply with quote
I had no trouble getting my GPz750R running on pods, but i have had alot of experience with messing with carburetion.
You can get over the pressure wave effect of the airbox by adjusting the needle position and drilling the slide vacuum holes, but it does require alot of work and patience.
GSXR1100J
Simple
PostPosted: 23:35 - 28 Aug 2007    Post subject: Reply with quote
Hmm, mayb it's not worth all the agro and lost riding time for 10% more power?
those who've managed to pull it off, would you do it again for the same amount of time for the same end product?
Insta - FemFeral
bish777
PostPosted: 00:17 - 29 Aug 2007    Post subject: Reply with quote
Id leave the thing alone, if its running well and pulling how you like, leave it.
GSXR1100J
Simple
PostPosted: 00:22 - 29 Aug 2007    Post subject: Reply with quote
it runs well, just liked the idea of a bit more oomph, and its a subtle change ad the filters would be almost hidden by the fairings
Insta - FemFeral
bish777
PostPosted: 01:28 - 29 Aug 2007    Post subject: Reply with quote
fitting a more open pipe, then upjetting a little is the most likely route.
That or getting a bigger bike?
GSXR1100J
PostPosted: 02:28 - 29 Aug 2007    Post subject: Reply with quote
I would say the stage 3 kit is to get a bike which has been screwed around with in other ways to run decently again, rather than something you fit and then screw around with the bike to get it to work.
Airboxes and inlets are designed just as carefully as decent exhausts. Dumping the airbox and hacking out the baffles is not likely to give you anything much at all.
Simple
PostPosted: 11:29 - 29 Aug 2007    Post subject: Reply with quote
hoki, Value your opinions, I'll leave as is, I've looked at bigger bikes and they require a bigger budget and there's nothing quite like lapping ATGNI's on a GP-Shed
thanks you boys and girls
Insta - FemFeral
PostPosted: 11:46 - 29 Aug 2007    Post subject: Reply with quote
As I keep telling people. If you want to go faster on a GPZ500, spend your money on the brakes and suspension, not on the engine.
bish777
PostPosted: 11:49 - 29 Aug 2007    Post subject: Reply with quote
You could shoehorn a Z1300 motor in there?
GSXR1100J
Simple
PostPosted: 00:05 - 30 Aug 2007    Post subject: Reply with quote
I'm happy with the brakes, they're very good, I'm outbraking many on track, just the extra oomph I'd like.
Insta - FemFeral
Irezumi aka Reuben
Carrot Top
PostPosted: 02:40 - 30 Aug 2007    Post subject: Reply with quote
The weight balance of the whole chassis is too biased towards the rear and there is too much flex sideways at the front of the bike.
If I was going to mod the bike I'd get a bar mounted between the two spars towards the front of the frame and perhaps fit some stronger (triple?) yokes. Try raising the rear and dropping the front as well.
Or just buy a better bike. Laughing
As Stinkwheel said do the suspension if your on the cheap. New shock and stiffer springs, or at least make sure you have 15W oil in the forks.
Pictorgraphicalfantastical
tsmith
PostPosted: 06:47 - 30 Aug 2007    Post subject: Reply with quote
standard gpz500 will put out 52 rear wheel hp, you can get +2 hp by fitting slip on rear race cans from here: https://www.classicbikes.com/sarachu.html
carbon fibre model will shave 4kg off the bike
and another +2 hp by fitting K&N air filter, drilling a 1" hole in the airbox and setting the carb pilot screws to 2.5 turns out. instructions here:
https://www.stevemorley.com/ex500/airbox/
and here:
https://www.ex-500.com/index.php/topic,2311.msg678.html#msg678
and here:
https://www.ex-500.com/index.php/topic,124.25.html
don't fit pod filters and don't change the jets. way too much hassle and the bike doesn't run right.
Simple
PostPosted: 12:51 - 30 Aug 2007    Post subject: Reply with quote
mine makes 46.4 bhp at the rear wheel.
thanks for the advice guys I'm not into spending that kinda money will just look for a 600 to race instead.
Insta - FemFeral
The last post was made 18 years, 230 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.22 - MySQL Queries: 13 - Page Size: 108.45 Kb
