Need derestrict speed in Hornet 919
NewSol
PostPosted: 03:05 - 30 Aug 2007    Post subject: Need derestrict speed in Hornet 919 Reply with quote
I have a Hornet 919 date 2002 for Asia market-where the law limit speed under 180 km/h.
While the one for European can go maximum 260km/h (see pictures).
Anybody have ideas how to derestrict the limitter in my bike.
Thanks so much for your helping
https://i24.photobucket.com/albums/c1...t/IMG_0126.jpg
https://i24.photobucket.com/albums/c1...t/IMG_0313.jpg
I found a website show how to derestricted rev limitter in Honda RC51.Can we use for Hornet 919.Anybody have other ideas?Thanks again
https://i24.photobucket.com/albums/c1...huat/b2a15.jpg
This is the simple kit I put together & distribute
https://i24.photobucket.com/albums/c1...at/softkit.jpg
Remove your tail section & undo the T shaped cover attached (4 push pins) on the bottom of the tail section right behind the battery. Under that there will be a black ECU box with a gray connector & a black connector.
This mod is best done with the PCII, as you can do the mod by splicing into the PCII harness instead of the ECU harness & if you ever need to undo the mod you can make it look 100% stock
You can obtain your own connectors from a cd-audio cable (pictured below) as it has the perfect size connectors to match the ECU pins.
https://i24.photobucket.com/albums/c1...t/cd-audio.jpg
https://i24.photobucket.com/albums/c1...uat/wiring.jpg
https://i24.photobucket.com/albums/c1...uat/ecumod.jpg
https://i24.photobucket.com/albums/c1...uat/b2pcii.jpg
Source : https://www.rc51.org/b2a15.htm
Another solution that I'm thinking to use the speedohealer to convert from km to miles.When I go at 100 m/h the signal send to ECM only 100km/h it mean I can go maxinum 180 m/h -> 180x1.6 = 288 km/h.But I wonder if the signal from Speedo send to ECU only 180 km/h,ECU will give enough air/fuel to engine.
https://www.speedohealer.com/eng/intro.htm
I write an email to the techinal engineer of speedohealer for asking
And this is his answer
Hello,
Yes, if you enable the SH''s "kph to mph" conversion mode, e.g. 140 indicated
on your meter will mean 140 mph road speed.
Probably it will also by-pass the speed limiter.
However, we do not have information on whether there is another kind of
restiction (e.g. HP) on this bike for the Asian market.
Kind Regards,
/Norbert
HealTech Electronics
Anybody have experience with this problems.Please help me
Thanks a lot
hmmmnz
PostPosted: 06:34 - 30 Aug 2007    Post subject: Reply with quote
i would say that it is a speedo restriction, and that putting a kph/mph converter in, should solve your problems, failing that, mabee the power commander may serve the same purpose.
none of your pics work.
the humans are dead
I kick arse for the lord
NewSol
PostPosted: 12:01 - 30 Aug 2007    Post subject: Reply with quote
Another problem :I wonder if we fake ECU think 100 km/h while we at 100 m/h,it will give engine enough air/fuel,isn't it.
Because ECU only think it run at 100 km/h so it give air/fuel to engine like it work 100 km/h.
Help me
Liamo
PostPosted: 12:04 - 30 Aug 2007    Post subject: Reply with quote
Hi New sol,
I think if you can get a speedo healer on ebay or similar it will fix your problem.
Your speedometer will then read in MPH, and the speed limiter will not take effect until 180 mph, which then 919 will never do.
Hope this helps
Weather you are suffering from glaucoma or have just rented "The Matrix", medical marijuana can make things fabulous. Medically.
hmmmnz
PostPosted: 14:15 - 30 Aug 2007    Post subject: Reply with quote
Help me
the ecu doesn't change mixtures to do with speed. it does it on revs
the humans are dead
NewSol
PostPosted: 12:33 - 02 Sep 2007    Post subject: Reply with quote
Thanks so much for your advice
Will try with speedohealer.I hope Hornet 919 only has speed limitter,not have horsepower limitter
Thanks all
The last post was made 19 years, 39 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.46 - MySQL Queries: 13 - Page Size: 50.51 Kb
