Fork seals pissing with oil
joseph.griffin
PostPosted: 15:33 - 30 Aug 2007    Post subject: Fork seals pissing with oil Reply with quote
I tried to put new fork seals on my Honda NSR125R yesterday and thought I had managed OK. I looked at it today and there's loads of oil coming from under the dust seals and I don't know what I did wrong.
Could I have put the seals on upside down? I put them on so that I couldn't see the spring ring. Is this right? I know that the copper bushes are fucked and I've ordered some more but Honda have told me it might take a month to get them so I've had to put the old ones back on.
What might I have done wrong?
Joe
Liamo
PostPosted: 15:46 - 30 Aug 2007    Post subject: Reply with quote
Were they genuine honda seals?
Weather you are suffering from glaucoma or have just rented "The Matrix", medical marijuana can make things fabulous. Medically.
joseph.griffin
PostPosted: 15:53 - 30 Aug 2007    Post subject: Reply with quote
I got these ones...
ebay link
My bike is a nsr125rx which isn't listed but it's 1999 and it says they would fit 1992 to 2003 so it thought they would be OK. They just came in a plastic bag - no box or name.
You reckon the seals are to blame?
joseph.griffin
PostPosted: 16:07 - 30 Aug 2007    Post subject: Reply with quote
I assume that when it says ATF in the Haynes manual it means automatic transmission fluid. I have used Dexron II type. Is this right and is the specialised fork oil they sell in Halfrauds any better?
skinny
PostPosted: 16:28 - 30 Aug 2007    Post subject: Reply with quote
All the forks seals I have changed go in with the roll spring facing up( thats not to say yours should may be quick ring to your local honda dealer to find out) I have also aways used proper fork oil.
oops I did it again....
joseph.griffin
PostPosted: 20:21 - 30 Aug 2007    Post subject: Reply with quote
Has anyone else done fork seals on NSRs - there must be a few of you. Which way up did you put the seals?
Cheers. Joe
2t-Screamer
PostPosted: 20:23 - 30 Aug 2007    Post subject: Reply with quote
ive done it on 2 nsrs a cb a tzr an rd and kh and the spring ALWAYS goes face down
visit Collective Knowledge
joseph.griffin
PostPosted: 20:25 - 30 Aug 2007    Post subject: Reply with quote
I don't know what I have done then coz I definitely put them face down.
2t-Screamer
PostPosted: 20:28 - 30 Aug 2007    Post subject: Reply with quote
how did you press the seals in? even the slightest little nick caused by incorrect methods of fitting will have oil pissing out
joseph.griffin
PostPosted: 20:46 - 30 Aug 2007    Post subject: Reply with quote
i did it with a bit of steel tube that was in my garage. What are you supposed to use? i can't really afford expensive tools.
2t-Screamer
PostPosted: 20:53 - 30 Aug 2007    Post subject: Reply with quote
you need to use something that fits perfect to the outer edge of the seal and press it in straight, i use a socket as i have one that fits 100% perfect and just "very" gently tap the seal in with palm of my hand,
Liamo
PostPosted: 10:54 - 31 Aug 2007    Post subject: Reply with quote
They could be, they might not be exactly the correct size (difference might not even be big enough to notice by the eye)
certain bikes (Honda Bros for example) just dont like any other seals bar Genuine Honda ones.
sickpup
Old Timer
PostPosted: 13:05 - 31 Aug 2007    Post subject: Reply with quote
Absolute rubbish. I've owned 7 or 8 Bros's and always used after market seals.
Chances are the bushes need replacement, they normally do as no one bothers to do it, except me. Ask Itchy about the difference it made to his forks.
joseph.griffin
PostPosted: 13:48 - 31 Aug 2007    Post subject: Reply with quote
Yeah - I've got bushes on order from Honda but they could take a month. I've got my MOT coming up on the 15th and there's no chance of it passing in its current state.
Is it safe to ride like this?
2t-Screamer
PostPosted: 13:52 - 31 Aug 2007    Post subject: Reply with quote
not really recommended, without oil theres no damping making your front end very soft and liable to dip sharply if you hit a bump in the road or jam your front brake on
Liamo
PostPosted: 15:53 - 31 Aug 2007    Post subject: Reply with quote
Hmm ... interesting. It was a well respected mechanic that old me this. Said he'd tried a number of seals in the bros and the only ones he found that worked properly were OEM ones.
Ah well
loply
PostPosted: 16:53 - 31 Aug 2007    Post subject: Reply with quote
Riding with a fork seal that has been leaking a lot of oil is liable to cause you to lock you front wheel when you hit a bump under braking....
...Trust me, I know Thumbs Down (£££)
Yamaha SZR660 Caution to the wind, the throttle pinned!
Timmeh
PostPosted: 20:42 - 31 Aug 2007    Post subject: Reply with quote
not only that, but fork oil is an excellent lubricant so when it gets over your brakes it reduces their stopping power to around the zero mark.
The last post was made 18 years, 345 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.48 - MySQL Queries: 13 - Page Size: 98.78 Kb
