the final countdown
MaybeGuy
PostPosted: 22:01 - 31 Aug 2007    Post subject: the final countdown Reply with quote
well, MOT 10am tomorrow, putting my mechanical and electrical skills to the test when i get the ultimate budget bike tested.
grand total spent: £290
https://aycu26.webshots.com/image/27265/2002408643846422656_rs.jpg
the only thing i think it may fuck up on is the zorst as it says 'competition use only' on it, but ive got a cunning sticker there.
another possibility is the left fork seal as i went for a blast and saw some oil there. ill give it a wipe before it goes in.
anyone have any idea how long an MOT takes roughly?
cheers queers xxx
McJamweasel
BCF Junkie
PostPosted: 22:44 - 31 Aug 2007    Post subject: Reply with quote
Around 20 minutes.
Ichy
PostPosted: 22:46 - 31 Aug 2007    Post subject: Reply with quote
Roughly 30 minutes although I've had them from 10-45 minutes.
I think the new system means that they should take a certain amount of time which means the guy seems to be wandering aimlessly for a fair bit of the time.
ZRX61
Victor Meldrew
PostPosted: 22:48 - 31 Aug 2007    Post subject: Re: the final countdown Reply with quote
Pop the dustcap up a bit & stuff some cottonwool in there.. Wink
MaybeGuy
PostPosted: 23:01 - 31 Aug 2007    Post subject: Reply with quote
ZRX61, you sir are a fucking legend!!!!
ill do it tomorrow morning!
no karma because i ran out of it bashing someone earlier...
but ill marry ur daughter or something if it works.
MaybeGuy
PostPosted: 23:13 - 31 Aug 2007    Post subject: Reply with quote
EDIT:
just been out for a play with them damned forks...
at the moment it doesnt leak any out, but it makes a squirting noise???
any ideas before i go to bed?
cheers queers xxx
PostPosted: 23:35 - 31 Aug 2007    Post subject: Reply with quote
Some forks do this as fluid is moved around the internal valves.
MaybeGuy
PostPosted: 23:36 - 31 Aug 2007    Post subject: Reply with quote
cheers G, so theyre not going to fail it for weird noise?
its odd though, ive never noticed the noise before...
what exactly do they do when theyre checking the forks and rear shock?
PostPosted: 23:49 - 31 Aug 2007    Post subject: Reply with quote
Think they'll be checking straightness, any free play, suitable damping/spring and of course oil leaks Smile.
MaybeGuy
PostPosted: 23:56 - 31 Aug 2007    Post subject: Reply with quote
once again, cheers Very Happy
is that just a case of sit on it front brake on and rock?
because other than the very minor leak thats only apparant after serious abuse it dampens just fine.
bish777
PostPosted: 00:05 - 01 Sep 2007    Post subject: Reply with quote
That looks like what my bike would look like if it had suffered from prolonged starvation!
https://www.bikechatforums.com/files/gsxr1100_116.jpg
GSXR1100J
bish777
PostPosted: 00:11 - 01 Sep 2007    Post subject: Re: the final countdown Reply with quote
You can also remove the retaining clip and smear RTV siliconce sealer all over then put the retaining clip back. Wait for a few hours till it sets and your fork seals are good as new.
GSXR1100J
alun111
PostPosted: 07:43 - 01 Sep 2007    Post subject: Re: the final countdown Reply with quote
Is that a long term fix?
Timmeh
PostPosted: 10:28 - 02 Sep 2007    Post subject: Re: the final countdown Reply with quote
nope. RTV gets corroded by fork oil and slowly turns it into a big sticky orange mess.
MaybeGuy
PostPosted: 17:05 - 02 Sep 2007    Post subject: Reply with quote
well, it was a fail...
but by no fault of the work i did to it Very Happy
the forks i fluked a bit because i wiped them beforehand and he said 'hmm, theres fork oil down here, have you done the seals? because theres none at the top', so i said 'mmm...yeah?' and the shocks and forks passed Very Happy
it failed on a broken brake lever and 2 split tyres.
the others were badly aligned headlights (i think theyre the wrong way round, so ill sort it)
and i need to putty my blowing exhaust.
2 weeks for that i reckon, and its going to feel like an eternity as im currently bikeless until i can get the money.
Damon
PostPosted: 07:49 - 03 Sep 2007    Post subject: Reply with quote
At least they are only minors. You still done amazingly well to do that on £290. Well done to you
MaybeGuy
PostPosted: 18:51 - 03 Sep 2007    Post subject: Reply with quote
cheers Very Happy
the bike itsself was £200, and about £90 for parts...
its loads more now Sad
just shelled out £146.03 on a new set of tyres, brake lever and exhaust putty, so that brings the total to like £340 or something (didnt bother working it out, so dont be all knowitally if i got it wrong).
so yeah. im dropping it back after college tomorrow.
the only thing thats a little bit worrying at the moment is idling in traffic...
its fine when cold, but when its warm/hot it doesnt like to idle at anything much below 2000rpm, im guessing its tappets/valve spacings... anyone agree?
cheers queers xxx
Liamo
PostPosted: 10:17 - 04 Sep 2007    Post subject: Reply with quote
Older bikes that are air or oil cooled can be kinda hard to get to idle, if you set it low it struggled to idle when cold, if you raise it to compensate, it idles very high when warm, its a matter of finding the happy medium.
Weather you are suffering from glaucoma or have just rented "The Matrix", medical marijuana can make things fabulous. Medically.
The last post was made 19 years, 57 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.62 - MySQL Queries: 13 - Page Size: 102.7 Kb
