Adapter to attatch socket set parts to electric drill
loply
PostPosted: 22:35 - 03 Sep 2007    Post subject: Adapter to attatch socket set parts to electric drill Reply with quote
Hi folks,
My Halfords Pro socket set came with an "adapter" that resembled 5cm long 5mm wide hex bar. It would go into the chuck of any ordinary drill and allow you to put a 1/4" socket or socket extension bar onto the drill, thereby allowing me to use a drill to undo/redo light bolts.
Naturally enough this little adapter has gone AWOL.
I've searched high and low but I don't know what the thing is called or where to get one, any suggestions? It was bloody usefull!
I'm sure tooled-up.com have it but I can't figure out what to search for...
Thanks!
Yamaha SZR660 Caution to the wind, the throttle pinned!
timjim
PostPosted: 22:38 - 03 Sep 2007    Post subject: bit Reply with quote
its a 1/4 " drive socket adaptor,go back to halfords,show them the kit/tool and get them to order you another one,theyre not TOO expensive and quite handy.tim
PostPosted: 23:01 - 03 Sep 2007    Post subject: Re: Adapter to attatch socket set parts to electric drill Reply with quote
Something like this.
https://www.whdirect.co.uk does them for a quid I think - but postage isn't so great unless you order loads of stuff.
Think screwfix do too, but can't find them, if not machine mart should.
Definitely very useful Thumbs Up.
Liamo
PostPosted: 10:08 - 04 Sep 2007    Post subject: Reply with quote
Bodge I know, but if its a 5cm long 5mm hex piece, why not saw a 5cm bit off a 5mm allen key?
Weather you are suffering from glaucoma or have just rented "The Matrix", medical marijuana can make things fabulous. Medically.
PostPosted: 10:12 - 04 Sep 2007    Post subject: Reply with quote
Because he wants it to have a 1/4" square end, not a 5mm hex end?
For the record, the size of the Hex-bit is actually 1/4" - so the screw driver bits will fit in a 1/4" socket if you want to adapt the other way.
That comes in at 6.35mm I believe.
loply
PostPosted: 19:59 - 04 Sep 2007    Post subject: Reply with quote
Doh, thanks for the help folks. Unfortunately I ordered it from some website prior to seeing that one on eBay, where a 1/4" and 3/8" one came to £6.
Not that the electric drill has the power for 1/2" sockets anyway.
If anybody doesn't have one of these bits, it's highly recommended. Makes things so much quicker and more convenient.
PostPosted: 20:57 - 04 Sep 2007    Post subject: Reply with quote
My (£25, 24V) electric drill does big sockets fine - still tightens them fairly tight but I'll generally start/finish it by hand anyway to be sure.
The last post was made 18 years, 221 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 51.68 Kb
