gilera clocks playing up
louis
PostPosted: 17:42 - 05 Sep 2007    Post subject: gilera clocks playing up Reply with quote
i have a gilera runner 180cc and the oil light is constantly on never comes of, no idea why its brimmed with oil and also the heat gage never moves any one got any ideas its just plain annoying
Thanks alot your help will be appreciate
louis
clubgilera.co.uk - scooter forum
Foxy
PostPosted: 17:44 - 05 Sep 2007    Post subject: Reply with quote
Is it a level light or a pressure light?
To give you a clue, on virtually all bikes it's a pressure warning light.
2t-Screamer
PostPosted: 18:00 - 05 Sep 2007    Post subject: Reply with quote
the 180cc is a 2 stroke, therefore its a level light, its a simple wire between the light and the tank sensor, the sensor should pull out of the oil bottle, just pull it out and check it and its connections
visit Collective Knowledge
sickpup
Old Timer
PostPosted: 18:11 - 05 Sep 2007    Post subject: Reply with quote
As the man says above for the 2T tank and the Heat guage will either be a blown bulb, damaged wire or a dodgy switch.
louis
PostPosted: 19:51 - 05 Sep 2007    Post subject: Reply with quote
thanks for that guys ill have to have a little look round and test the wires, ethier way ill just check the oil regulary
davidlewtas16
PostPosted: 21:40 - 24 Dec 2007    Post subject: Reply with quote
oil i dont no but iv got the same problem with the clock its your thermostat its roted away u just need a new 1 and when you get it u need to use anty freez
MaybeGuy
PostPosted: 22:29 - 24 Dec 2007    Post subject: Reply with quote
i had the same thing happen to my RXS100...
RXS100_chris pointed out it is a test light, as soon as you put the bike in gear it goes out.
divuk83
PostPosted: 17:13 - 25 Dec 2007    Post subject: Reply with quote
There is a 180 4 stroke as well.
Dave
PostPosted: 19:51 - 25 Dec 2007    Post subject: Reply with quote
I have the same problem and the only way to knock off the oil light is to turn the ignition key a bit and it disappears. No idea why and it's baffled me since I have owned the scooter.
The last post was made 18 years, 304 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 59.11 Kb
