exhaust wrap
Keir
PostPosted: 10:20 - 06 Sep 2007    Post subject: exhaust wrap Reply with quote
what are the benifits of this? I wouldnt bother on the road but m considering it for my track bike.
Current : '08 Yamaha FZ1s
Chriss
PostPosted: 10:23 - 06 Sep 2007    Post subject: Reply with quote
I've got some on the SV, purely to keep the shock cool as it runs right next to the exhaust. It's pretty effective, but not sure what it's *designed* for. Seems a bit like go faster stripes to me.
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
Robby
Dirty Old Man
PostPosted: 10:28 - 06 Sep 2007    Post subject: Reply with quote
Its good for disguising downpipes that are paper thin and starting to hole.
McGee
O RLY?
PostPosted: 10:58 - 06 Sep 2007    Post subject: Reply with quote
Hetzer wrote:
Isn't it supposed to maintain an even temperature through the pipes, which benefits the motor's operation? Think I read that somewhere.
Basically what you said.
It helps keep the heat in the exhaust which is supposed to be "good for the back pressure" and it helps keep the bike much cooler since the heat is kept more with in the exhaust. Also helps with over heating as such that it directs it into the pipe.
Its pronounced Jixxer!
sickpup
Old Timer
PostPosted: 06:04 - 09 Sep 2007    Post subject: Reply with quote
Supposed to help with exhaust temps which is all a bit strange as cool air takes up less space than hot.
Best used in cars to stop bu;kheads getting hot.
Retains water and helps your exhausts rot.
bish777
PostPosted: 15:23 - 09 Sep 2007    Post subject: Reply with quote
Cold air is more dense and will not flow as easily. I cant see the wrap making much of a difference at manifold temps mind.
GSXR1100J
sickpup
Old Timer
PostPosted: 15:26 - 09 Sep 2007    Post subject: Reply with quote
bish777 wrote:
Cold air is more dense .
Correct
I think you should rethink that one.
bish777
PostPosted: 15:30 - 09 Sep 2007    Post subject: Reply with quote
How so? You only need to cool it when trying to compress it into a vessel (ie induction) rather than just shoving it out of an open ended exhaust pipe.
Cooler air is more dense flows less easily, but intercooling in forced indution is beneficial as the compressor has relatively far more force and can shove it in the cylinder.
Put your engine oil in the freezer and try and and pour it.
GSXR1100J
sickpup
Old Timer
PostPosted: 19:58 - 09 Sep 2007    Post subject: Reply with quote
The colder the air the denser it is the less area it takes up meaning a given amount of exhaust gas if denser will go through the exhaust quicker for the same given velocity as a less dense charge.
The quicker you can exit exhaust gas from the system the less restrictive it is. This is why Honda started using water injection in exhaust systems on the NSR500 to cool the exiting charge..
bish777
PostPosted: 20:04 - 09 Sep 2007    Post subject: Reply with quote
lol that told me.
GSXR1100J
lozzypop1
Certified MILF!
PostPosted: 20:09 - 09 Sep 2007    Post subject: Reply with quote
bish777 wrote:
lol that told me.
You can understand that???? Confused
He's explained it to me a number of times over the course of the day and I just don't. Doh!
sickpup
Old Timer
PostPosted: 20:10 - 09 Sep 2007    Post subject: Reply with quote
Thumbs Up Cool
bish777
PostPosted: 22:03 - 09 Sep 2007    Post subject: Reply with quote
lozzypop1 wrote:
bish777 wrote:
lol that told me.
Yes, understood it fine, i was barking up the wrong treeand applying fluid dynamics to a gas.
GSXR1100J
The last post was made 19 years, 47 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 78.15 Kb
