| squishio |
 squishio Spanner Monkey
| McGee |
 McGee O RLY?
| squishio |
| virus |
 virus World Chat Champion
 Posted: 11:28 - 06 Sep 2007 Post subject: |
not enough air to the engine, check that the filter and air box isnt blocked and the filter is clean, that should stop it running rich.
if the worst comes to the worst then strip down the slides in the carbs and lower the needles a notch each, this will lean off the mixture a bit.
Cheers
John ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| MarcZZR |
 MarcZZR Derestricted Danger
| squishio |
| McGee |
 McGee O RLY?
| MarcZZR |
 Posted: 12:03 - 06 Sep 2007 Post subject: |
Have you got a manual?
Basically you take off the float bowls and measure the float hight,(Usually with the carb upside down) all the measurements and exactly how to do it will be in the manual.
Have a look here for your bikes manual if you don't have one
https://www.bikechatforums.com/viewtopic.php?t=41567 |
| virus |
 Posted: 16:10 - 06 Sep 2007 Post subject: |
ok, just re read it and it sounds as though its running too lean, either way, check the floats are working and set propperly, all jets are clear and that there are no air leaks anywere between the airbox snorkel and the engine. then if needs must adjust the mixture by raising or lowering the needle height.
Hope this helps
| Finglonga |
 Finglonga World Chat Champion
 Posted: 16:44 - 06 Sep 2007 Post subject: |
Lean , Rich Why would it change because the float was sticking?
Sounds like a simple case of something hasn't been put back together properly. As long as you have fixed the sticking float valve and put everything as you found it, it should run exactly like it did before the fuel leak.
I would strip it down and re assemble it carefully.  ____________________ Andy Sez....
F.Y.Y.F.F. |
| squishio |
| TUG |
 TUG World Chat Champion
 Posted: 00:48 - 07 Sep 2007 Post subject: |
wish i had the cash to get sumone to do it all for me, done all the work on the bike myself due to funds i had same problem i had float bowls open and just pushed them right in lmao i was in a temper and couldnt be arsed taking em apart for the 100th time, and its never leaked since and runs fine, just need to set the air/fuel mixture and will be fine, any of that twaddle helped anyone?
had a bit of a life story moment there, apologies. ____________________ Haz ER-5, innit! |
| squishio |
The last post was made 19 years, 43 days ago. Instead of replying here, would creating a new thread be more useful? |
