fzr400 "squeeky"
TUG
PostPosted: 16:10 - 07 Sep 2007    Post subject: fzr400 "squeeky" Reply with quote
ok, i just put a different shock on my fzr, it drops like 20mm so thats good, but theres a horrid squeek coming from the bike, it also rises gradually not straight away, i'm thinking maybe swing arm bearings causing this?
any ideas?
cheers, ben. Very Happy
Haz ER-5, innit!
Trixie
PostPosted: 16:13 - 07 Sep 2007    Post subject: Reply with quote
If it didn't squeak before changing the shock, I would take a guess that it's your shock that's squeaking. It sounds like it needs adjusting. Suspension is not my strong point, so I'm not going to make myself look like an idiot trying to tell you what to do Laughing ...there are lots of bods on this board who are very knowledgeable on these things and will be able to help you.
Dead nobodies in company cars...
TUG
PostPosted: 16:15 - 07 Sep 2007    Post subject: Reply with quote
sorry forgot to put old shock is shagged, and the new one is fine, it squeeked before leading me to believe it was the shock, but needed a new one anyway, but i dunno y its squeeking. Confused
Haz ER-5, innit!
Trixie
PostPosted: 16:22 - 07 Sep 2007    Post subject: Reply with quote
Then yeah, it could be the swingarm bearings - or it could well be the swingarm pivot.
My ex's bike (T509) suffered a similar thing, the shock was fine, but the rear end was a right old bone shaker. He was talking about getting the swingarm drilled and a grease nipple fitted, as there was no other way of maintaining it apart from taking the rear end apart.
TUG
PostPosted: 16:28 - 07 Sep 2007    Post subject: Reply with quote
possibly the pivot bearings have died and rusted like my rear wheel bearings did, causing a squeek from friction?
anyone else agree?
Haz ER-5, innit!
TUG
PostPosted: 16:51 - 07 Sep 2007    Post subject: Reply with quote
anyone?
Question
Haz ER-5, innit!
PostPosted: 18:08 - 07 Sep 2007    Post subject: Re: fzr400 "squeeky" Reply with quote
Push down on it while off the bike - how long does it take to return to it's original position?
TUG
PostPosted: 18:16 - 07 Sep 2007    Post subject: Reply with quote
it raises like 1-3 seconds, then it still raises gradually, like theres sumthing stopping it.
Haz ER-5, innit!
TUG
PostPosted: 18:31 - 07 Sep 2007    Post subject: Reply with quote
still no ideas? ooo this is worrying, best not fail mot.
Sad
Haz ER-5, innit!
PostPosted: 18:38 - 07 Sep 2007    Post subject: Reply with quote
Is it adjustable?
It's possible the rebound damping is turned up far too high and the squeaking you are hearing is oil being forced to this.
Or the spring could be a bit knackered, of course.
TUG
PostPosted: 18:47 - 07 Sep 2007    Post subject: Reply with quote
hmm, its possible, the springs on the second notch, and re rebound is on god knows what lol, i'll try turning it down, thats if it works, so the squeeking is definatly coming from both shocks? the old one and the new one?
Haz ER-5, innit!
PostPosted: 18:57 - 07 Sep 2007    Post subject: Reply with quote
Oops, didn't see that it squeaked before, my bad.
It's possible, but with that more likely a bearing or bushing is knackered.
When you had it off would have been an ideal time to have a poke around, but too late now.
If you can get hold of a mechanics stethoscope, it'd make it a bit easier to diagnose which bit is squeaking, if it's not obvious otherwise.
TUG
PostPosted: 18:59 - 07 Sep 2007    Post subject: Reply with quote
thanks G, i'd say its deffo a seize/ ready to seize bearing in the swing arm area, maybe the bush that hold the botom join on thats connected to the dogbones and shock?
Haz ER-5, innit!
PostPosted: 19:09 - 07 Sep 2007    Post subject: Reply with quote
There's a lot of possible things it could be.
I've also seen plenty of cases where people have heard a terminal-sounding rattle or squeak for it to turn out to be a loose nut or cable, etc.
However does sound like something around there. Ideally, get the shock out again and move bits until you find which one creaks Smile.
TUG
PostPosted: 19:11 - 07 Sep 2007    Post subject: Reply with quote
lol all i have do is touch my bike mate Wink
am with you though, will take it to a mech who will most probably know what it is instantly, he knows everything, its amazing, wish he'd take me on tho Sad
i'll take it him tomoz, cheers again G
Haz ER-5, innit!
The last post was made 19 years, 39 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 81.83 Kb
