Datatool problem
lllN30lll
PostPosted: 08:57 - 09 Sep 2007    Post subject: Datatool problem Reply with quote
I left my bike on park a few days ago by accident and it drained the battery, now after charging it back up, when i'm riding the bike the alarm will randomly set itself! it even starts panicking and going off properly when i'm going down the road.
any ideas?
not sure of the location of all the fuses on my bike (05 R1) and I don't have a manual.
cheers
Turbo R1
CRF450R
sickpup
Old Timer
PostPosted: 12:16 - 09 Sep 2007    Post subject: Reply with quote
Sounds like you may have killed the bikes battery.
lllN30lll
PostPosted: 12:22 - 09 Sep 2007    Post subject: Reply with quote
i might also add that i've noticed my horns stopped working as well.
batterys fine now fully charged, lights come on and everything as usual.
Turbo R1
CRF450R
sickpup
Old Timer
PostPosted: 12:39 - 09 Sep 2007    Post subject: Reply with quote
It seems to me the alarm is sensing voltage drops on the battery, thats where I would look first.
The horn is probably a fuse.
I would also check the alarm earth's.
TUG
PostPosted: 18:55 - 09 Sep 2007    Post subject: Reply with quote
i'd check all the fuses, does the data tool alarm come with its own fuse? and like sickpup said check that its earthed propperly on something clean (and obviously metal).
Karma
Haz ER-5, innit!
lllN30lll
PostPosted: 19:00 - 09 Sep 2007    Post subject: Reply with quote
sorted Very Happy
turned out it was the f*cking indicator fuse, WHY!!!!!!!
abd why the f*ck did yamaha put the fuse box behind a sodding side panel that needs 10 odd bolts bloody removing.
Turbo R1
CRF450R
TUG
PostPosted: 19:08 - 09 Sep 2007    Post subject: Reply with quote
balanceing out weight? my fuse box is under rear seat on the fzr.
Haz ER-5, innit!
sickpup
Old Timer
PostPosted: 20:00 - 09 Sep 2007    Post subject: Reply with quote
If it was the indicator fuse there should be a seperate diode added into the system when fitted to prevent this happening.
TUG
PostPosted: 20:43 - 09 Sep 2007    Post subject: Reply with quote
the diode has gone too? causing the fuse to blow? am i right or wrong?
Haz ER-5, innit!
MattEMulsion
PostPosted: 21:49 - 09 Sep 2007    Post subject: Reply with quote
Did the alarm start going off whenever you flicked the indicators on then?
Yamaha YZF-R6
sickpup
Old Timer
PostPosted: 22:05 - 09 Sep 2007    Post subject: Reply with quote
No I mean the diode may not have been fitted in the first place.
lllN30lll
PostPosted: 22:06 - 09 Sep 2007    Post subject: Reply with quote
nope the alarm would arm itself as usual after 30 odd secs, but it would arm itself as i'm pulling off etc. lol
tis a weird one, but sorted now thankfully.
Turbo R1
CRF450R
TUG
ahhh right, am with you. Thumbs Up Very Happy
Haz ER-5, innit!
sickpup
Old Timer
PostPosted: 22:12 - 09 Sep 2007    Post subject: Reply with quote
Sorry, to explain better the diode is an optional part not normally needed I just remember I needed to fit it on the only R1 I fitted an S3 Data-tool to.
The last post was made 19 years, 52 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.17 - MySQL Queries: 13 - Page Size: 77.72 Kb
