Pinking (if thats how you spell it!)
short1uk
PostPosted: 15:07 - 09 Sep 2007    Post subject: Pinking (if thats how you spell it!) Reply with quote
Bike went in for its 8000 mile service and when I got it back its now pinking.
Idling it goes pink pink pink. (Thats probably not how you spell it I know)
Any ideas? It didnt do it before it so I am not sure what they have done!
Catherine
bish777
PostPosted: 15:16 - 09 Sep 2007    Post subject: Reply with quote
I doubt its pinking.
Its probably a loose mechanical noise from summat that needs tightening.
GSXR1100J
.Chris.
PostPosted: 15:19 - 09 Sep 2007    Post subject: Reply with quote
Usual causes are the timing being too far advanced, the compression is too high for the grade of fuel being used or the mixture is very weak.
At least that's what's usually the matter when a car engine is pinking. However the pinking is usually worst not at idle, but when the engine is under load.
As bish says, it's likely to be something else.
Chris
1985 Kawasaki Z550F
PostPosted: 15:23 - 09 Sep 2007    Post subject: Reply with quote
As above. Pinking will be most noticable under load, and I suspect the ignition timing on a Hornet will be a long way from being that critical on fuel used.
short1uk
PostPosted: 15:25 - 09 Sep 2007    Post subject: Reply with quote
Cant hear much on the move tbh so i dunno. But didnt do it before its service!
PostPosted: 15:46 - 09 Sep 2007    Post subject: Reply with quote
Take it back and ask. Don't mention the word pinking though, just a noise that has appeared.
short1uk
PostPosted: 15:52 - 09 Sep 2007    Post subject: Reply with quote
Already rang em and said its making a noise sounds like pinking. But tbh they will have forgot by next week.
Running down next Sat so they can have a look. Hopefully it wont take long to fix. As I have only just got back on the road I wanna ride not sit in garages again!
TUG
PostPosted: 17:07 - 09 Sep 2007    Post subject: Reply with quote
i vote runnins lean as mine is and is making a pinking sound. Very Happy Thumbs Up
Karma
Haz ER-5, innit!
short1uk
PostPosted: 17:12 - 09 Sep 2007    Post subject: Reply with quote
How do we fix it?
TUG
PostPosted: 17:15 - 09 Sep 2007    Post subject: Reply with quote
turn the mixture screws on the carbs, but if they did it wrong go back and tell them to fix it propper, their fault.
Haz ER-5, innit!
bish777
PostPosted: 18:24 - 09 Sep 2007    Post subject: Reply with quote
If the motor was pinking it would be running pretty roughly. If its running ok its 99% likely to NOT be pinking.
GSXR1100J
short1uk
PostPosted: 18:53 - 10 Sep 2007    Post subject: Reply with quote
IMO she wasnt running right. I accelerated fast up the link road and she didnt seem as fast as she normally was. Normally 70 appears in a second but it seemed to take ages to get there
Could be me of course with being off the bike for a while
bugsy46
Village Idiot
PostPosted: 19:36 - 10 Sep 2007    Post subject: Reply with quote
Well let me tell you now, nothing on that bike during a normal 8000 mile service will have caused your engine to detonate. Firstly id check the fuel you are using.
Laura - "And where did looks come into this and bugsy leave steven alone. You are not gods gift to women you may think you are but you're not."
Keith - "All the best"
short1uk
PostPosted: 20:51 - 26 Sep 2007    Post subject: Reply with quote
Could this be the cam chain tensioner? Its not pinking me dad says. Could it be this thing?
How can i check?
brianmcewan.co.uk
PostPosted: 00:13 - 27 Sep 2007    Post subject: Reply with quote
Out of interest, what the feck is pinking? Karma Laughing
Kawasaki Z1000 '05
Honda Fireblade 954 '03
PostPosted: 02:04 - 27 Sep 2007    Post subject: Reply with quote
It's when the fuel in the engine explodes too early. Normally you set the spark so the fuel is ignited slightly before the piston goes over top dead centre so the piston is forced down through the entire power stroke.
Pinking occurrs when this happens too early (too far before top dead centre), either because the ignition timing is wrong, the fuel burns too quickly or the fuel is too highly compressed. This tries to force the piston back down the way it came and makes a noise called 'pinking' because that's what it sounds like. It is also known as predetonation and knocks hell out of the bearings and the piston. Can lead to a piston looking like this or much worse:
https://i48.photobucket.com/albums/f216/stinkwheel/piston.jpg
That's one out of my Jawa 350 when the timing slipped.
So common causes are maladjusted timing or using fuel with too low an octane rating for the state of tune of the engine. If you significantly tune an engine, one of the things you usually do is increase the compression, this makes the fuel tend to explode more quickly. To compensate you need to either adjust the timing (which kind of defeats the purpose by loosing all the power you just gained) or use a higher octane fuel which burns more slowly (which is the correct solution).
Putting crappy fuel in a highly tuned engine can cause pinking under high load. Most standard engines are set up to run on crappy fuel though (ie, unleaded). It used to be more common when you could still buy 2 and 3 star petrol, people would try to economise and put it in their bike then wonder why it ran like a bag of shite
veeeffarr
PostPosted: 02:10 - 27 Sep 2007    Post subject: Reply with quote
Are you sure it's not the legendary Honda CCT?
Does the problem go away when the engine is warm?
short1uk
PostPosted: 08:56 - 27 Sep 2007    Post subject: Reply with quote
How can i check?
Can you not read lad Laughing
pmsl
love the little wheelie in your avator
Very Happy
prawny1
PostPosted: 17:56 - 27 Sep 2007    Post subject: Reply with quote
Were the valves checked/ adjusted at the service?
If so there is a chance (if the cams had to come out) that the mechanic has the cam timing out by a tooth, sounds likely if your bike is down on power and running rough.
Might be worth checking your plugs are in tight too, be sure to make sure they are not loose or been cross threaded and that they are the right heat grade..
hellkat wrote:
short1uk
PostPosted: 09:11 - 28 Sep 2007    Post subject: Reply with quote
The guy took the plugs out checked them and said i didnt need new ones so possibly didnt stick them back in right.
Valves possibly not sure?
When I get a spare minute I will take her back the garage and get her looked at.
Catherine
veeeffarr
PostPosted: 10:19 - 28 Sep 2007    Post subject: Reply with quote
Catherine
Do you have a Haynes? They DID refill the bike with oil when they drained it didn't they? Shocked
The last post was made 18 years, 326 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 108.45 Kb
