Backfiring Flames
madassbore
PostPosted: 21:20 - 14 Sep 2007    Post subject: Backfiring Flames Reply with quote
Hiya,
I have a problem, well not so much a problem i think it looks quite cool but as the title says when i backfire my bike (the normal kill button trick) dunno why i do i just do lol, i get flams shoot out the exhaust, i was wondering if this is normal or is it just me?
thanks
Dave.
Passed Theory - 35/35 -Passed Practical - 0 Minors - 23rd July - Yamaha Diversion XJ600S
Four Deadly Words "I DIDN'T SEE HIM"
instigator
PostPosted: 21:28 - 14 Sep 2007    Post subject: Reply with quote
Normal
Finglonga
PostPosted: 22:37 - 14 Sep 2007    Post subject: Reply with quote
What do you think causes the backfire? (clue is in the wrd Backfire). Wink
Andy Sez....
F.Y.Y.F.F.
mattjs895
PostPosted: 23:03 - 14 Sep 2007    Post subject: Reply with quote
on this not, can a spark plug spark straight off a 12v battery and if it were drilled into the exhaust would doing this backfire business damage the engine in any way
cheers
matt
chris_millars
PostPosted: 00:07 - 15 Sep 2007    Post subject: Reply with quote
correct me if i'm being naive and simplistic here but if you can ignite your exhaust gases in the exhaust you're probably running waaaaay too rich or riding around with the engine choked off.
by the time they reach the back of the exhuast you hopefully have mainly CO2, and any unburnt fuel aint gonna ignite in there.
Unless you're running a two stroke with a large hole in the exhaust to draw in oxygen, which probably won't work too well either.
and no, you can't spark a plug off a 12V battery the HT leads provide about 120,000 V (or something, it's high!) from the secondary coil.
that is all.
Past>> Kawasaki ER-5 A3 (stolen/recovered/written off) Current>> Kawasaki ER-5 A4 (well I liked the last one so why not.)
Chriss
PostPosted: 01:13 - 15 Sep 2007    Post subject: Reply with quote
Isn't it just CO from the engine, doesn't the catalytic converter, well, convert it into CO2?
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
teampots
PostPosted: 13:16 - 15 Sep 2007    Post subject: Reply with quote
that is all.
theres a simple trick for carb'd bikes
simply ride down the road at high revs flick the kill switch (or the ignition) for a few seconds (you can pump the throttle to help) as it is mechanical the fuel mixture is still drawn through the cylinders and since there is no spark it gets pushed out the exhaust ports etc and it goes bang when you flick the switch back on
Current - Fazer 600
Prev - Bandit x2 (Killed) CB400 (Superfour) CBR125
Currently Restoring - Kawasaki S1 250 Triple (Slowly but surely)
lllN30lll
PostPosted: 13:23 - 15 Sep 2007    Post subject: Reply with quote
I used to do this about 20 times a day.
after a few months this happened.
good excuse for me to stubby it though. Thumbs Up
https://img.photobucket.com/albums/v707/lllN30lll/piccy-0304.jpg
Turbo R1
CRF450R
teampots
PostPosted: 17:53 - 15 Sep 2007    Post subject: Reply with quote
doyou reckon it causes any damage to the engine? cause i do it a fair few times a day Razz
Current - Fazer 600
Cptn. Awesome
PostPosted: 13:27 - 17 Sep 2007    Post subject: Reply with quote
A mate of a mate had an NC30 and he buggered the engine on his bike using the killswitch trick.
I have an NC24 and even when I get the body panels and stuff finished and the bike is on the road, I won't be doing the killswitch trick.
PostPosted: 09:08 - 18 Sep 2007    Post subject: Reply with quote
Didn't someone off here do there valves or something by doing this??
Timmeh
PostPosted: 21:21 - 19 Sep 2007    Post subject: Reply with quote
aye.
And I've seen someone down the Ace break an RD350 by doing it.
Not big or clever IMO.
freestyler_onli
PostPosted: 22:42 - 19 Sep 2007    Post subject: Reply with quote
I took the silencer off mine and when i change down gear i hear bangs/pops. Confused
TUG
PostPosted: 23:09 - 19 Sep 2007    Post subject: Reply with quote
i used to do it but it got boring, i dont do it anymore plus it stops the killswitch from working if used all the time.
Haz ER-5, innit!
Marcg868
PostPosted: 02:40 - 20 Sep 2007    Post subject: Reply with quote
My cbr has a tendency to do it everytime i change gear and also if i let off the throttle above 6k. Nice big pops.
And nice blue flames Smile
JACK, MISS YOU LOADS YOU LEGEND.
PostPosted: 09:19 - 20 Sep 2007    Post subject: Reply with quote
That's just it running a bit lean, because it can flow more air, but the fuel wasn't added to compensate. Thumbs Up
veeeffarr
PostPosted: 12:23 - 20 Sep 2007    Post subject: Reply with quote
Won't it be the PAIR system?
PostPosted: 14:44 - 20 Sep 2007    Post subject: Reply with quote
Why would that make it pop?
just for the record my CBR600F has had a race can on standard jetting and that still pops on the overrun, no PAIR system on it.
veeeffarr
PostPosted: 15:07 - 20 Sep 2007    Post subject: Reply with quote
Do you know what PAIR is? AFAIK it should make that popping sound...
thegubner
PostPosted: 15:10 - 20 Sep 2007    Post subject: Reply with quote
What is PAIR?
veeeffarr
PostPosted: 15:24 - 20 Sep 2007    Post subject: Reply with quote
the_guvnor_1_uk wrote:
What is PAIR?
Air from airbox is injected into exhaust to ignite unburnt gases.
thegubner
PostPosted: 19:02 - 20 Sep 2007    Post subject: Reply with quote
Aha, cheers Toby.
freestyler_onli
PostPosted: 19:40 - 20 Sep 2007    Post subject: Reply with quote
https://www.youtube.com/watch?v=qoNpfjJIg6k
Like this.......
PostPosted: 09:01 - 21 Sep 2007    Post subject: Reply with quote
My hornet never did it when i had the standard can, when I put the el cheapo ebay can on, pop, pop ,pop, put an Akra on pop, pop, pop.
As I say the CBR600F does it with no air bleed into the exhaust......
Timmeh
PostPosted: 17:41 - 23 Sep 2007    Post subject: Reply with quote
You only find PAIR on the california-mode CBRs.
The last post was made 18 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 125.45 Kb
