Clunky Gearchange 1st - 2nd
Huambo81a
PostPosted: 22:05 - 17 Sep 2007    Post subject: Clunky Gearchange 1st - 2nd Reply with quote
Hi all!
My ZX6R 2003 (19000 miles) has developed a somewhat clunky change from 1st into 2nd, any idea what this could be? it use to be almost silent in comparison, could it be clutch cable tension? (clutching at straws here, no pun intended)
Thanks
Sam
Present: 2017 KTM Super Adventure S
Past: 97 Bandit 600 / 05 Bandit 1200 / 03 ZX6-R / 2006 Tuono R / 2001 VFR 800 / 2010 Street Triple R / 2013 Speed Triple S / 2017 S1000XR
Mudskipper
PostPosted: 22:24 - 17 Sep 2007    Post subject: Reply with quote
In need of an oil change?
Or chain need adjusting?
Huambo81a
PostPosted: 22:40 - 17 Sep 2007    Post subject: Reply with quote
Oil change probably 2k ago so should be ok, i`ll certainly check the chain tomorrow though, thanks for the tip
hmmmnz
PostPosted: 22:57 - 17 Sep 2007    Post subject: Reply with quote
is the oil full?
mine clunks like a tank when its not Thumbs Up
the humans are dead
I kick arse for the lord
TUG
PostPosted: 23:46 - 17 Sep 2007    Post subject: Reply with quote
normally worn dogs on the gears make for a noisey box. Thumbs Up
Haz ER-5, innit!
Huambo81a
PostPosted: 00:09 - 18 Sep 2007    Post subject: Reply with quote
Thaks for the replies guys, it seems Mudskipper was spot on, the chain is slacker than an alcoholic student in a room full of job papers.
no idea how i`ve let it get so bad, probably checked it two weeks ago. Chain and sprockets are only a couple of thousand miles old too, nevermind its my own fault for missing it.
Thanks!
ram_doom
PostPosted: 08:41 - 18 Sep 2007    Post subject: Reply with quote
Is the R pin in tightly? If it lets the axle nut move even just a little it'll cock it Wink
TL1000s, KDX200
Huambo81a
PostPosted: 20:21 - 20 Sep 2007    Post subject: Reply with quote
Ok, its not the chain, its perfectly adjusted now and still changing up into 2nd feels like the clunk from neutral to 1st.
Could it be anything to do with the clutch cable, do they need adjusting ever?
Please explain to me as you would a child.
cheers Thumbs Up Very Happy
Faldo
PostPosted: 20:50 - 20 Sep 2007    Post subject: Reply with quote
Might sound daft, but my 7r is always the same when it needs a service. Just had mine serviced and 'box is like a new one again.
Try an oil change before exploring further. If it don't cure it you've not really lost out
Good luck Thumbs Up
Current: ZZR1400
Huambo81a
PostPosted: 18:12 - 22 Sep 2007    Post subject: Reply with quote
Went to a garage today and they suggested that the Gear Lever had too much play, and i would need a new one. Any thoughts?
Huambo81a
PostPosted: 18:42 - 22 Sep 2007    Post subject: Reply with quote
Vincent wrote:
I wouldn't have thought that would make it more noisy, might make it harder to select a gear and/or neutral. If the gear lever has a fair bit of play before moving the selector shaft it's well worth getting it sorted. What's the mileage on the bike?
Mileage is 18742, 2003 ZX6R
TUG
PostPosted: 22:48 - 22 Sep 2007    Post subject: Reply with quote
normally worn dogs make it noisey, just age an wear and tear, my fzr's box is very noisey, but then again the box is due for replacing.
hope you sort it Thumbs Up
Haz ER-5, innit!
binge
Emo Kiddy
PostPosted: 21:45 - 23 Sep 2007    Post subject: Reply with quote
My NC29 had a clunky 1st to 2nd change. 20k kilometers. As long as the chain is adjusted right, and there is oil in it, I don't let it bother me. It doesn't jump out of gear or anything, So as far as im concerned its ok. Thumbs Up
Louise
PostPosted: 22:30 - 23 Sep 2007    Post subject: Reply with quote
My bandit sometimes runs smooth from 1st to 2nd but somedays it will clunk, and quite loud at that too - some people asked 'is that normal'
Ive been told it is, just finding the 1st gear.
Still runs fine ect.
Robby This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
TUG
PostPosted: 00:50 - 24 Sep 2007    Post subject: Reply with quote
only passing info on what the plausable cause is, why? do you know the problem and whats causing it? have you stripped the bike? worn dogs make for noisey changes, i've read it 100s of times, its only info, am not saying that is the 100% sure thats the problem. all i know is when the gearbox is done over winter in mine my bike will be complete, all done by me, so for knowing jack i've done quite well Thumbs Up
Haz ER-5, innit!
bish777
PostPosted: 01:45 - 24 Sep 2007    Post subject: Reply with quote
1st to second is often clunky
frsh oil and a well adjusted chain lessen it, but it will worsen with wear as the engine tots up miles.
Check the clutch cable is adjusted properly as a slightly draggin clutch will make things worse.
GSXR1100J
The last post was made 18 years, 352 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.36 - MySQL Queries: 14 - Page Size: 103.33 Kb
