Led indicators for a suzuki
Keir
PostPosted: 13:06 - 19 Sep 2007    Post subject: Led indicators for a suzuki Reply with quote
i want to 'upgrade' to LED indicators on my GSXR i have found the ones want (flush fronts and mini rears) but when im looking for a relay the suzuki ones are always universal ones for some reason when kwak,hon and yam are all specific. Id prefer plug in fixes to wire cutting.
Has anyone done this? how did you get round it?
Current : '08 Yamaha FZ1s
banksy
PostPosted: 00:58 - 22 Sep 2007    Post subject: Reply with quote
and does anyone know where the relay is on a gs500 because im not sure what to replace
banksy
-CG125 07- -GS500F 04- -CBR600 98- -FJ1200 86- -XT350 91- -CBR900RR 01-
hmmmnz
PostPosted: 01:54 - 22 Sep 2007    Post subject: Reply with quote
under the right hand seat panel next to the reg/rect
the humans are dead
I kick arse for the lord
hmmmnz
PostPosted: 01:56 - 22 Sep 2007    Post subject: Re: Led indicators for a suzuki Reply with quote
attach spade connectors and press them into the plug Very Happy no cutting required
the humans are dead
banksy
PostPosted: 23:43 - 22 Sep 2007    Post subject: Reply with quote
sorry....
next to the what?
banksy
hmmmnz
PostPosted: 00:34 - 23 Sep 2007    Post subject: Reply with quote
regulator/rectifier, the metal thing with the heat sinc built in,
it looks like this
https://www.hiperform.com/rvfweb/regrec.jpg
just to the right of that
the humans are dead
banksy
PostPosted: 23:53 - 23 Sep 2007    Post subject: Reply with quote
kl thanks
banksy
D O G
PostPosted: 11:17 - 24 Sep 2007    Post subject: Re: Led indicators for a suzuki Reply with quote
The only way to do this is by the use of resistors, those universal relays do not work i'm afraid - I wired one up and it blew loads of fuses until I took it out. Very annoying.
Motrax LED indy's generally come with resistors, so you will be ok with those. Faiing that, you should be able to get the resistors from ebay, I'm looking for some new ones at the moment (as the last lot were somwhat shoddy, and teh terminals came out).
You will definitely need to do soem wire cutting - get a cutter/stripper if you dont have one already, and I used bullet connectors and shrink wrap.
DO NOT use Scotchlocks - 100% cowboy crap.
banksy
PostPosted: 00:34 - 28 Sep 2007    Post subject: Reply with quote
right i got the motrax ones but wheres the resistor, inside it?
i plugged 1 in to the front and 3 of the bulbs flashed brightly and the rest were very dim
the flash rate was also fast
what do i do? what resistors do i need?
i have the universal flash it... are you saying this wont work?
banksy
The last post was made 18 years, 326 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 65.25 Kb
