Installing renthals, drill or remove the nub from controls?
Reppyboyo
PostPosted: 15:53 - 19 Sep 2007    Post subject: Installing renthals, drill or remove the nub from controls? Reply with quote
Hi,
Im currently changing my Speed Four to bars.
The controls have a small nub which goes into a hole in the clip ons, the renthals dont have this hole.
Should I drill my renthals (which is apparently not reccomended by them) or grind off the nub? (Also been told if I do grind the nub off, but some tape arounf the bar where the controls are placed so they dont slip.)
Help please.
PostPosted: 16:10 - 19 Sep 2007    Post subject: Reply with quote
If it's a metal pin, you can often push them back through.
This means you are neither drilling nor grinding.
I usually remove/push through the pin and wrap some tape round the bars to stop them slipping.
Reppyboyo
PostPosted: 16:24 - 19 Sep 2007    Post subject: Reply with quote
Its moulded into the controls.
veeeffarr
PostPosted: 16:37 - 19 Sep 2007    Post subject: Reply with quote
Buy a Plastech repair kit and use the putty to mould around the nub
File away nub
When you need to replace Nub, use mould and Plastech to create a new one
T
PostPosted: 17:45 - 19 Sep 2007    Post subject: Reply with quote
I've always just ground it off.
As mentioned, tape around the bars if it's an issue.
You could probably get a small self tapper in there if you needed a locating pin back.
jimbothe
PostPosted: 17:50 - 19 Sep 2007    Post subject: Reply with quote
I ground it off on my Ninja and put some tape round the bars and it works perfectly and doesnt slip Thumbs Up
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
Reppyboyo
PostPosted: 18:07 - 19 Sep 2007    Post subject: Reply with quote
Grinding it is!
Thanks all.
Quick question, how much fluid does a front brake system usually need?
Is 500ml enough? (Just got 500ml of DOT 4)
KLR600
PostPosted: 19:26 - 19 Sep 2007    Post subject: Reply with quote
I just fitted renthals to my bike the other week and I just filed the nubs off, took about 2 minutes and it's all fine so far Thumbs Up
<Take Cool Photos!>
PostPosted: 21:08 - 19 Sep 2007    Post subject: Reply with quote
Depends on the brake system etc.
Should be ok, but I'd have gone for the litre just in case (infact, I've got a 5lt bottle somewhere so I don't need to worry Smile ).
mr jamez
PostPosted: 21:15 - 19 Sep 2007    Post subject: Reply with quote
Buy it in the small bottles, otherwise you just end up with brake fluid sat around absorbing water.
Odie
PostPosted: 18:58 - 01 Oct 2007    Post subject: Reply with quote
I ground them off on my NTV 650 and then the switch gear wouldnt tighten up! Thumbs Down
Got some dowl pins from work (work for a fastener supllier) and retro fitted the pins and drilled the bars, sorted now! Thumbs Up
The last post was made 19 years, 32 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 67.85 Kb
