starter motor not working ** job done**
befdelta7
PostPosted: 18:41 - 19 Sep 2007    Post subject: starter motor not working ** job done** Reply with quote
hi,
my starter motor on my cagiva supercity isnt working.
i have put a new starter solenoid on the bike but the starter still doesnt turn over. theres no sound when i pust the button, but when i touch the terminals with a screw driver the starter motor spings to life and turns the engine over with a blaze of sparks!
any ideas what could be the problem?
the batterys charged up and in perfect working order.
im getting fed up of having to run down the road to start it like i just stole it from someone.
cheers for the replys and help Thumbs Up
Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine.
alains
PostPosted: 19:02 - 19 Sep 2007    Post subject: Reply with quote
change brushes and spring , clean comutator , dig bakelite between each cupper strip , oil bearing and ends
bugsy46
Village Idiot
PostPosted: 19:30 - 19 Sep 2007    Post subject: Reply with quote
Shocked
thought he said it worked when he bridged the starter relay??!!
Laura - "And where did looks come into this and bugsy leave steven alone. You are not gods gift to women you may think you are but you're not."
Keith - "All the best"
cagiva gezzer
PostPosted: 19:33 - 19 Sep 2007    Post subject: Reply with quote
Hit the relay and make sure the starter switch is making a circuit.
PostPosted: 00:42 - 20 Sep 2007    Post subject: Reply with quote
If the starter turned over when you connected it directly and you have fitted a new starter solenoid then:-
1: You haven't wired up the new solenoid correctly (press your starter button, you should hear a click from the soilenoid)
2: Your starter button is fucked ( jump 12v across the solenoid control connections from the battery and see if it works)
3: Your new solenoid is defective. (If you have a multimeter you can check this easily, if you don't, get down to Maplins as they sell them for about a fiver)
Shay HTFC
PostPosted: 10:39 - 20 Sep 2007    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=126943
Have 2 for 6 quid if you want. Give the other one to your girlfriend or someone. Wink
befdelta7
PostPosted: 21:01 - 20 Sep 2007    Post subject: Reply with quote
thanks for your replys!!
cheers but i got the job sorted. Embarassed tbh i dont know how to use one anyway Embarassed
**update**
took a look at the relay, and found that the little metal 'flap' with the tiny magnet on it wasnt moving when pressing the starter like it should. so i pressed the 'flap' with my thumb against the electro-magnet and pressed the started... the bike started. so i wedged a small washer between the outer plastic casing and the 'flap' and glued it there to make a complete circit. so jobs a good'n!
thanks Thumbs Up
The last post was made 19 years, 9 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.85 - MySQL Queries: 13 - Page Size: 53.79 Kb
