cannot take seat off motorbike
jasinoz
PostPosted: 06:20 - 23 Sep 2007    Post subject: cannot take seat off motorbike Reply with quote
I feel a bit stupid here but I cannot take the seat off my Spada vt250
I was trying to see what battery it needs (which is under the seat). I know nothing about bikes and am relitively new to all this but come on, it's a seat!!
There are no latches or anything it just looks like it 'clicks' off (I've actually managed to get the front bit praised up a bit but the back part is stuck like glue.
Any ideas folks?
lllN30lll
PostPosted: 07:45 - 23 Sep 2007    Post subject: Reply with quote
no idea for that bike, try lifting the corners of the seat and see if there's 2 allen key bolts holding it down.
Turbo R1
CRF450R
thegubner
PostPosted: 11:06 - 23 Sep 2007    Post subject: Reply with quote
Tis might be a stupid question, but have you checked for a lock?
*edit***
I know you said there are no latches but I thought that about mine. Embarassed
PostPosted: 11:14 - 23 Sep 2007    Post subject: Reply with quote
Sometimes have a latch built into the helmet lock. You open the helmet lock and turn the key a bit further to pop the saddle off. Sometimes there's a lever behind the helmet lock, unlock the lock then pull the lever down.
Also can be held on with two bolts at the back of the saddle, you usually need to take the side plastics off to get at them.
jasinoz
PostPosted: 09:08 - 24 Sep 2007    Post subject: Reply with quote
There's no lock (that I can see), tried it with the key in the ignition, tried the helmet lock but no other function than locking the helmet exist there
I have the two bolts at the back of the saddle but I know this seats comes off as I have seen a mechanic do it, it sort of clicks into place (next time I'll watch very closely)
I'll keep trying. Thanks for the response guys
lozzypop1
Certified MILF!
PostPosted: 09:27 - 24 Sep 2007    Post subject: Reply with quote
Hey jas... The seat lock is part of the helmet holder. It looks like it uses the same lock as the BROS 400/650... (I've seen the 'Pup sort out the 'donkey's a few times before passing it on to Annabella!! Laughing )
https://www.wemoto.com/library/spadafiche/033.gif
Turn the key clock wise (opposite way to how you'd normally undo something Laughing ) and push down the latch on the back of the lock mechanism. As far as I know, These are quite fond of seizing due to the rear wheel flicking crap up into them.
Rit
PostPosted: 00:57 - 25 Sep 2007    Post subject: Reply with quote
If you get really stuck go back to your friendly mechanic or any bike shop will show you for free.
Stuff the Embarassed you only gotta do it once Thumbs Up
You watching this rubbish?
Naaaa, switch over, Neighbours is on in a minute!
www.ritzbitz.co.uk
jasinoz
PostPosted: 10:54 - 25 Sep 2007    Post subject: Reply with quote
Hey folks
Yes your right, there is a latch behind the helmet lock that you push down. The seat came off real easy!
Thanks to all, esp lozzypop1 for the diagram which really helped.
Now to try and change the battery!
The last post was made 19 years, 3 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.26 Sec - Server Load: 2.83 - MySQL Queries: 13 - Page Size: 60.02 Kb
