Stiff front wheel
loply
PostPosted: 15:17 - 23 Sep 2007    Post subject: Stiff front wheel Reply with quote
Hi folks,
The front wheel on my SV650 is very stiff. You can turn it by hand but it won't carry on spinning after you let go, and it's a bit stiff to roll the bike around the garage.
It's not the brakes because I've taken them off.
The wheel spins freely, though perhaps not as freely as others, when you first mount it. But as you torque the axle up to 65nm it gets stiffer and stiffer.
I loosened the forks and jiggle-wiggled them a bit incase they were misaligned, but it made no difference.
Is this just normal? The wheel on my SZR660 has no resistance almost. This SV is an '04 model so it's not ancient and worn out.
Thanks for any tips.
Yamaha SZR660 Caution to the wind, the throttle pinned!
PostPosted: 15:34 - 23 Sep 2007    Post subject: Reply with quote
bearings???
is there any free play in the wheel? (side to side)
DRZ-400sm
instigator
PostPosted: 15:43 - 23 Sep 2007    Post subject: Reply with quote
Try and try again
Happened once on my last sv650. Take the wheel off again and put it back on. Smile God knows why the hell it does it.
loply
PostPosted: 16:29 - 23 Sep 2007    Post subject: Reply with quote
I'll check for free-play in the wheel.
I'm not sure why taking it off and putting it back on would change things, there's only the speedo that could be wrong and that's right Confused
bish777
PostPosted: 16:35 - 23 Sep 2007    Post subject: Reply with quote
You dropped any spacers somewhere?
GSXR1100J
instigator
Chances are it's probably not. Laughing Trust me, I've gone through this same experience before and it baffled me. Take the front wheel right off and slowly put it back on.
TUG
PostPosted: 16:41 - 23 Sep 2007    Post subject: Reply with quote
stiff front wheel? sounds like a brake binding situationor could be a done bearing.
Haz ER-5, innit!
The last post was made 18 years, 351 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 50.76 Kb
