Xl125 rear wheel
donkey
PostPosted: 08:14 - 24 Sep 2007    Post subject: Xl125 rear wheel Reply with quote
Hi does anybody know if a honda mtx125 rear wheel is the same as the xl125r or if not is there a way of repairing the sprocket studs the studs are all lose in the wheel and just the big circlip is holding the sprocket in place
Jamie S
PostPosted: 10:44 - 24 Sep 2007    Post subject: Reply with quote
It's a cush drive , I have had mine welded full (ie so the hole for the rubber is not there any more) and drilled and tapped to fit 4 big bolts , much safer, can post some pictures later on if you want ?
Reason for doing this is that on trials bikes the rubber wears really quickly in side, Plus the circlip groove worn away. ( same wheels as an Xl)
Cost me £10 to have done (mates rates). You need to find some one who has an ally welder. Thumbs Up
Jamie S
PostPosted: 11:02 - 24 Sep 2007    Post subject: Reply with quote
Just to add on what I said up there^ I found that you could replace the stubs on the sprocket and a week or so later 2 or 3 of them would of snapped meaning that it is only driving on one and could break any min.( Think the circlip grove being worn had something to do with this though )
Here are pictures of what I had done. ( been like this 12 months now and no propblems what so ever.)
Ps them marks on the sprocket were cause when the circlip came off.
Pic one : The 4 bolts , 17mm heads.
https://i155.photobucket.com/albums/s297/honda_tlr/DSC00668.jpg
Pic 2 , the old circlip grove.
https://i155.photobucket.com/albums/s297/honda_tlr/DSC00670.jpg
Pic 3 , the drilled and tapped holes were the rubber cush drive used to be.
https://i155.photobucket.com/albums/s297/honda_tlr/DSC00672.jpg
Hope this helps.
veeeffarr
PostPosted: 11:28 - 24 Sep 2007    Post subject: Reply with quote
I'm sure not having a cush drive on a trials bike is fine... This is a road bike.
T
donkey
PostPosted: 12:18 - 24 Sep 2007    Post subject: Reply with quote
thanks for the help i will have to see if i can find sombody who has an ally welder
donkey
PostPosted: 13:04 - 24 Sep 2007    Post subject: Reply with quote
next question is how on earth do you get the old ones out they seem pretty well stuck
Jamie S
PostPosted: 13:07 - 24 Sep 2007    Post subject: Reply with quote
Get what out ? The rubbers ? or the stubs off the sprockets ?
veeeffarr
PostPosted: 14:00 - 24 Sep 2007    Post subject: Reply with quote
You need a cush drive... They don't just put them in for a laugh...
donkey
PostPosted: 14:28 - 24 Sep 2007    Post subject: Reply with quote
get the rubbers out
donkey
PostPosted: 14:31 - 24 Sep 2007    Post subject: Reply with quote
i need to get the old rubbers out to install new ones or to try the modifation above in the manual it says the wheel has to be sent away to a honda specialist but then the manual also says i have only four studs that hold the wheel on when infact there is 5
Jamie S
PostPosted: 16:50 - 24 Sep 2007    Post subject: Reply with quote
The rubbers are just pushed in , get some needle nose pliers and pull them out.
There is a gap of 2 years, 79 days between these two posts...
heskencren
PostPosted: 13:14 - 12 Dec 2009    Post subject: Reply with quote
just found this topic- very interesting. is it still a successful mod?
I posted a new topic re 4 or 5 lug wheel interchangeability if anyone can help. ta!!!
The last post was made 16 years, 311 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 69.04 Kb
