97 ER5 A1 "output shaft" oil leak
Phil_G
PostPosted: 22:29 - 24 Sep 2007    Post subject: 97 ER5 A1 "output shaft" oil leak Reply with quote
Hiya,
My Er has developed a SLIGHT drip from the area of the front sprocket. Its engine oil for certain (as opposed to an overlubed chain) as there is no spray from the chain elsewhere, and I will only get a tiny drip when parked up (by that I mean the spot is about 2-3mm across).
How do I go about sorting this leak out? Is it a case of chain/sprocket off then remove a push in seal, clean seat and replace with new? If so does anyone have any idea how much it would cost at a dealership?
Failing that, is it something I could do myself without ballsing up too badly? Ive got a good socket set but no access to an airline for impact wrenches (which I would be loathe to use anyhow as I dont think that bearings would take too kindly to it) I also have a basic mechanical knowledge.
Thanks for any help in advance
Phil Smile
1997 Kawasaki ER 500 A1:- Once again, Its merely crap Smile
sickpup
Old Timer
PostPosted: 22:31 - 24 Sep 2007    Post subject: Reply with quote
Mine does the same except its the gear change shaft. I'd leave it a long as its not to bad.
cheekythomas
PostPosted: 22:39 - 24 Sep 2007    Post subject: Reply with quote
As long as its a externally replaceable seal then yes its not a hard job... remove the sprocket, dig the oil seal out taking care not to mark the inner shaft, clean it all up... then refit the new seal. Try to find something that can be put over the shaft to tap the seal in.
Another tip is to cover the splines on the gearbox shaft with insulation tape while you are refitting the seal to prevent the seals lip getting damaged as some times the edges of the splines can be razor sharp! Wink
Phil_G
PostPosted: 22:55 - 24 Sep 2007    Post subject: Reply with quote
Good way of talking yourself out a sale there Wink
oh and Cheeky Thomas - I use varying bores of PVC pipe at work - I thought one of them would suit nicely to make a seating tool Smile
thanks for the advice peeps Thumbs Up
sickpup
Old Timer
PostPosted: 23:03 - 24 Sep 2007    Post subject: Reply with quote
It's just a bitch of a job. I think the output seal is lipped so it's a split the crank case job.
The last post was made 18 years, 359 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.45 - MySQL Queries: 13 - Page Size: 44.08 Kb
