A rejuvinating charge over night
Do you use (or will you be using) a trickle charger this winter?
Yes
37%
 37%  [ 6 ]
No
62%
 62%  [ 10 ]
Total Votes : 16
Whosthedaddy
PostPosted: 10:47 - 25 Sep 2007    Post subject: A rejuvinating charge over night Reply with quote
Its funny how things play on your mind and the same bad luck seems to follow from one bike to another, or is it just me?
Walking to the bike, putting the key in and pressing the button had always left me with butterflies as will it start or wont it start?
The ZX rumbled into life after being out in the rain overnight rather than roaring on the push of the button. It turned easily, if not a little lack luster. I had only been on very short trips, lights on and ignition on and off again to test this whole starting when hot thing.
Would a trickle charger be any good, even if the bikes charging system is up to scratch?
Are there any detrimental effects of constantly charging a system?
I know that many people have bought ones from Aldi when in stock, but what ones do you use / or would consider?
NSR Mick
PostPosted: 10:55 - 25 Sep 2007    Post subject: Reply with quote
I'll just disconect it, or leave it if I forget.
It's a kickstart anyhow so battery power isn't to important.
druidsam
PostPosted: 10:58 - 25 Sep 2007    Post subject: Reply with quote
i have an oxford optimiser,but only use it if my bike is going to be unused for a week or two,last winter when the bike was laid up for long periods the charger was connected at all times and my battery was always fully charged and suffered no ill effects.
...........................Sam
trust me! I'm a druid
https://www.bikerforum.co.uk/
veeeffarr
PostPosted: 12:05 - 25 Sep 2007    Post subject: Reply with quote
Optimates really are that good.
They can be connected permanantly.
T
Whosthedaddy
PostPosted: 12:11 - 25 Sep 2007    Post subject: Reply with quote
T
Must be a bloody long cable if you want to go for a ride then Laughing
veeeffarr
PostPosted: 12:16 - 25 Sep 2007    Post subject: Reply with quote
T
Nah, Bluetooth connection innit
hmmmnz
PostPosted: 12:30 - 25 Sep 2007    Post subject: Reply with quote
your battery is being charged permanently when you are riding it,
a trickle charger is sweet, and will do no harm, ive never had the need, the zxr is easy enough to bump start,
to check if your charging system is working (this is not recomended by every one, but i've done it to my zxr, although i wouldn't do it to a fi bike) when the bike is running disconnect one of the leads fromn the battery, if the bike dies something is wrong with your charging circuit,
if not then chances are its sweet Very Happy
still not sorted the bike then??
the humans are dead
I kick arse for the lord
LeeR
PostPosted: 12:45 - 25 Sep 2007    Post subject: Reply with quote
I've had mine on charge over the weekend and back on again last night. I think my alarm is either taking too much juice or there's not enough left in the battery, as the alarm does an extra warning beep when I switch it on/off. Or it could be the battery is on the way out as it's the original one and it is 5 years old. The Halfords charger I'm using is good but I have to un-clip the leads and put the seat back on so I might invest in an Optimizer for the winter as I've heard you can leave the really long leads in situ... Wink
My claim to fame: Austin Vince nicked my pen...
Whosthedaddy
PostPosted: 18:42 - 25 Sep 2007    Post subject: Reply with quote
Been ok Eh?Thinking
Not really had the time as working to sort out some of the fiddly bits yet.
Arrow New headlamp bulb
Arrow Check right hand caliper as brake bad loose and wiggles when moving, yet bites the disc when pressure applied?
Arrow Check the clutch cable (went to adjust the biting point and found a screw screwed into the cable and into the space with the lever as if to hold it in place. A quick glance seems that the cable still works but knowing my luck will snap next time I'm out Rolling Eyes)
garyd
PostPosted: 20:00 - 25 Sep 2007    Post subject: Reply with quote
Get the optimiser ,excellent bit of kit,plug in when you get home and put in garage,bang on the money in the morning,never let me down in 4 years(same battery) Thumbs Up
ace_tweety
PostPosted: 20:31 - 25 Sep 2007    Post subject: Reply with quote
If im not riding the bike for a while, ill just charge the battery the night before i go out and its fine. Thumbs Up
But the trickle charger sounds handy to have. Thumbs Up
Suzuki SV 650 (blue of course!) Very Happy
Ant
PostPosted: 21:10 - 25 Sep 2007    Post subject: Reply with quote
i stick mine on a optimate since the imobiliser drained the battery last year!
04 ZX10R ~
NSR Mick
PostPosted: 21:13 - 25 Sep 2007    Post subject: Reply with quote
A flat battery will perform the same function unless you can jump it. Wink
Syx
PostPosted: 01:37 - 26 Sep 2007    Post subject: Reply with quote
I'll usually ride the bike a couple of times a week at least (unless the weather is truly ridiculous!) - so I've never needed a charger yet.
Louise
PostPosted: 02:39 - 26 Sep 2007    Post subject: Reply with quote
Used a charger (trickle) for the old 125. worked good - Not used a charger for the 600 at all yet - But having probs allready - with just being a 'tad' cold its having problems starting. Even after 45 mines hot riding its still asking for more. So yes - trickle charger tommorow - Or brand new battery.
LeeR
PostPosted: 07:14 - 26 Sep 2007    Post subject: Reply with quote
I had exactly the same problem last week, rode for 30 mins on the M5 from work. When I stopped at the petrol station as I got off the motorway, it was as though the battery was dead, it took about 7/8 attempts to start. Thinking
The last post was made 18 years, 329 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.32 - MySQL Queries: 15 - Page Size: 95.06 Kb
