idling revs?
David-lee
PostPosted: 12:51 - 26 Sep 2007    Post subject: idling revs? Reply with quote
when you kick a bike up and then let it idle...what rev count should it be idling at?
Thanks
David-lee
PostPosted: 12:53 - 26 Sep 2007    Post subject: Reply with quote
also another question about my electric start...It has just stopped working last ngiht but luckly i have a back up kick start on it
Thanks
Kal
PostPosted: 13:04 - 26 Sep 2007    Post subject: Reply with quote
It should burble at you with out dying off.
For mine its around 11,000 on the trike and slightly higher on the GB.
How are the rest of your electrics?
Kal...
David-lee
PostPosted: 13:06 - 26 Sep 2007    Post subject: Reply with quote
when you say 11000 isnt that a bit high cause mine idles at 2000 when the bike is standing after its warmed up
yeh all electrics are fine apart from electric start
Thanks
Kal
PostPosted: 13:12 - 26 Sep 2007    Post subject: Reply with quote
Sorry thats the joy of posting at work should have read 1,100 on the trike. The GB is sub 2,000
Kal...
David-lee
PostPosted: 13:18 - 26 Sep 2007    Post subject: Reply with quote
Ok mate lol i take it your always rushing when replying whilst at work incase management should walk past behind you lol
The GB is sub 2,000 what do you mean by this?
cheers
Kal
PostPosted: 13:27 - 26 Sep 2007    Post subject: Reply with quote
She has to idle high because every so often she misses a beat and the engine can die if she is set too low so I have her idling at under 2k.
Hopefully when I've replaced the headgasket that problem will evaporate.
Anythig happen with the starter or has it just packed it in?
Kal...
David-lee
PostPosted: 13:40 - 26 Sep 2007    Post subject: Reply with quote
Ok thanks
Problem started just last night and wont electric start
iooi
PostPosted: 13:53 - 26 Sep 2007    Post subject: Reply with quote
Might help if you say what bike ?
Mines around 1,000 rpm some can be lower, some higher.
Kick or eletric start will make no diffrence.
David-lee
PostPosted: 14:24 - 26 Sep 2007    Post subject: Reply with quote
Its a kymco stryker 125 trial
ace_tweety
PostPosted: 17:48 - 26 Sep 2007    Post subject: Reply with quote
Mine idles at 1,000 once its warm, its a GSX 400s
Suzuki SV 650 (blue of course!) Very Happy
Finglonga
PostPosted: 19:56 - 26 Sep 2007    Post subject: Reply with quote
A single will idle at around 1k when warm and choke off.
Andy Sez....
F.Y.Y.F.F.
deanoet
PostPosted: 21:32 - 26 Sep 2007    Post subject: Reply with quote
Yeah, when warm it should be a healthy tick over so it doesnt sound like it is struggling, or revving either.
No idea on the numbers as my bike doesnt have a rev counter. Smile
My car idles at 1,500 when cold and about 800 when warm
MaybeGuy
PostPosted: 21:49 - 26 Sep 2007    Post subject: Reply with quote
basically, go for a nice long ride, fully warm the thing up, then adjust your idle jet so that the bike isnt about to stall and struggling to carry on, but not so high that its racing a bit.
once you've found those 2 points, you need to find a mid-point so that the throttle response is still quite fast, yet the engine still isnt racing.
Noxious89123
PostPosted: 22:52 - 26 Sep 2007    Post subject: Reply with quote
Modern cars have an automatic "choke" Wink
My cbr idles at about 1,250rpm when warmed up.
when shes cold she'll usually sit at about 800rpm and then miss a beat and die. Then i put the choke on and start her back up, will idle at about 2,000rpm.
I find that if i start the bike with the choke, and then blip the throttle (upto about 5-6k) that the revs drops back down to about 3k, then carry on back down to 2k really slowly...
bish777
PostPosted: 23:13 - 26 Sep 2007    Post subject: Reply with quote
When fully warm, larger capacity engines should be set to idle between 1050-1250rpm. Singles need to be at the higher end of the scale for a reliable idle.
Smaller capacity motors may need higher idles, but ive yet to see an idle much over 1500rpm.
GSXR1100J
The last post was made 18 years, 274 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.40 Sec - Server Load: 10.24 - MySQL Queries: 13 - Page Size: 88.98 Kb
